No Nonconformances issued from audit activity
#11
This type of situation is possibly caused through the auditor not doing a complete job of auditing! We haven't found out, yet, if what the people are doing is causing any problems or not, regardless of what the procedure says.
I'm always concerned when I read the audit was against 'the standard'. This isn't good criteria for an internal auditor to use. It should be they're auditing the qms documentation. Furthermore, if the auditor had determined that there is resistance to the procedure, then maybe it's because of the way it's written or introduced to people. We can't tell from what's reported.
The auditor should be reporting the facts - not 'grading' findings to ameliorate the situation. Call it like it is (as Brad says) - this is one of the downsides of 'allowing' auditors to 'grade' findings! It shouldn't be there call. The 'grade' comes from the nature of what's reported!
I agree with Jen, that 'retraining' isn't likely to be worthwhile. What are you going to 'retain' on - the same behaviours? I think the way you select criteria and scope may be part of it, plus the amount of planning and how that's done needs scrutiny. Just arming the auditor with the standard etc. is not going to work!
Did anyone ever coach this auditor to know how to audit? Just being in a training class isn't sufficient to get an effective audit.
Sidney Vianna
Post Responsibly
#12
In the first audit (1st visit), which mainly documental auditing, the auditor will not write any nonconformance. He will only write the situation founded without the word nonconformance.
In the 2nd visit (normally 2 weeks after the first visit), it’s a normal audit.
That is what ISO 17021:2006 prescribes for Stage 1 and Stage 2 audits.
Sandra Gauvin
#13
I agree with Brad. :agree1:
Instead, it seems there is a cultural force that they hesitate to press against. A retraining could do more damage than good, if they feel they are being somehow punished for something not in their control. :whip:
:2cents:
Good point about the cultural force....Sandra
Antonio Vieira
Involved - Posts
#14
Yes Sidney, in fact that’s what registrars now have to do.
In the case of one Organization that is to be audited having a poor QMS, this new procedure might be good.
On the other hand for an Organization that has a great QMS this is no more that a total waste of time.
I faced this situation last week, on the first stage audit there were no notes. On the second stage audit, the auditor has nothing more to see…
:notme:
Sidney Vianna
Post Responsibly
#15
It seems that the auditor does not know what s/he is doing.
Not sure what you mean by "no notes". A documented report from Stage 1 audit is a requirement.
selena15
#16
Hi cove
i'm agree with you Brad and this is why i notified this issue here. for to be more a clear the problem is that the procedure is correct and approved by management but as Jennifer said " Instead, it seems there is a cultural force that they hesitate to press against." and honestly this idea that the cultural force is enough tough that it make audits or any others component which can have an effect on the Quality Management
system is frustring me :mad:. and here i will ask you to read, if it isn't already done, one very exciting thread that i issued before called "corporate culture" and i wish if Wes can reply here :cool:
http://elsmar.com/Forums/showthread.php?t=30493
Inderstang me, if you are aware that there is any kind of resistance and you accept to let some procedure or some of their manner in order to be gentle and permit to, indeed, this culture to stay confort, what will be the gain of to established one QMS and use some components whitout to benefit of their result, what we will win? :confused:
"A retraining could do more damage than good, if they feel they are being somehow punished for something not in their control. " I didn't htink about this possibility !!! when i approuve the suggestion of retrainning, it was just in the idea to correct some manner ..etc. But you are right to suggest that others have to be retrained.
ISO 17021:2006 is relating to the certification and the first stage before the certification, does its guidelines is working for an internal audit?!
"Did anyone ever coach this auditor to know how to audit? Just being in a training class isn't sufficient to get an effective audit." good point Andyn, the trainning was done internally and as i know no coach. You know how it is the trainning in general, read together the standard
#17
Selena:
It's so good to see you come here with problems and see how our advice is helping you! It's very gratifying to know we help, even so far away...
Your comment is very interesting. I have made similar comments when talking about ISO/IEC 17021 that the 2 phase approach could be used to such advantage in an internal audit situation.
Why can't internal auditors spend time with the management of the process they are to audit, to check for 'readiness', understanding of the scope, criteria etc? It would certainly help to ensure a much more successful outcome than we get today!
Try it - you might like it!
JaneB
#18
The outcome required of any effective training isn't just that the people were simply 'trained', it's that they are assessed as competent.
If I have understood what you said correctly, it seems to say that the training consisted of reading the Standard together. Just doing that that really isn't enough for effective training, nor for your auditors acquiring real competency. And 'retraining' them the same way? :nope: Won't work.
It sounds like there may be issues on both sides of the equation...
selena15
#19
Good morning Cove
you are welcome AndyN, i will tell you , of course the Cove is master in sharing and learning and also sometimes, i start a thread just to inform about some behave; discrepancy ...because i know that many Folks here are member in the revision or whatever organizations of the standards and this is my manner to notify, if usefull, about this facts even from so far, in order to contribute :)
About the approach of ISO 17021, my inderstanding of that is when we ask for a certification, The QMS is enough implemented and we know that the comments issued from the first step is important to be fixed and it is enough to be commited to it.
Now concerning the internal audit, as you said your self, this is component to be used effectively in order to get the best outcome, this is why i asked if is allowed to use the 17021 approach.
Why can't internal auditors spend time with the management of the process they are to audit, to check for 'readiness', understanding of the scope, criteria etc? It would certainly help to ensure a much more successful outcome than we get today! Jane This method is used as usual as possible and also the Quality manager try to be involved in the meetings of departement , sites to remember them again and again what should be done; the outcome is " yes ,yes you are right, i'm agree with you and so" after no feedback :confused:
But you are right to spend time and time on these.
I think that the commitment of the Top mangt have lot to do here. I'm not saying that there is no documented and communicated commitment or so;
I will tell, the Quality objectives is included in the descriptif poste of folks, but the deal is , what does this realy mean? during the annual evaluation; the question is : the manager of each will focuse on the responsability relating to the function and the quality ones separatly and with different level of focusing or it will be mixed and revaluated as one set ? i don't know if i explained enough or correctly my opinion
"If I have understood what you said correctly, it seems to say that the training consisted of reading the Standard together. Just doing that that really isn't enough for effective training, nor for your auditors acquiring real competency. And 'retraining' them the same way?" yes, this is kind of reading an audit; answering to the questions and also somme training audits; but as i read in one thread here; what about coaching and assisting a person until to feel her competent.
Let focuse on this point; after trainning and one obeservation audit; you can participate in audit and after 3 , you can be a responsible, but what about what product "these training audits" as Additional value. i mean more than following up the requirement of ISO 19011
.for example; if i get a participation in one audit , which is so classical , if i can use this word. No special situation will occur which can let me see what to do ( as instance: auditing an activity which don't have a documentation; get some :mad: behavors....etc) i'm sure that you can remember some situations which was not linear. I4m aware about this, what about the novice on this activity?
You are right to say that the retraining won't work in these case.
:agree1:
Antonio Vieira
Involved - Posts
#20
Of course there was a report on the stage 1 audit. What I meant with “no notes” was that as on the stage 1 the auditor can’t write nonconformances (just “notes”),
The QMS I was talking about, although new, was almost perfect.
So, to audit it twice (1st stage and 2nd stage) was a complete waste of time.
In fact, knowing that this was going to happen, we asked the Registrar that the two stages were made on continuous days, but unfortunately the auditor’s schedule didn’t allow it…
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
R Extension of product nonconformances - Construction project Nonconformance and Corrective Action 7
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M User Errors and Product Nonconformances Nonconformance and Corrective Action 22
K Notified Body - Minor Nonconformances - They have withheld all certificates General Auditing Discussions 3
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
N Nonconformances in the Construction Industry Nonconformance and Corrective Action 6
T Perishable Tooling Supplier - Nonconformances and Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Internal Audit Nonconformances - Your opinion? Internal Auditing 8
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
L Insurance to cover for nonconformances ? Misc. Quality Assurance and Business Systems Related Topics 2
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Second Registrar Visit to Confirm Major Nonconformances Fixed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Definitions for Minor & Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F Response to ISO 13485 Audit Minor Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 6
M Seven Document Review Nonconformances Document Control Systems, Procedures, Forms and Templates 9
J KPI for time to close NCs (Nonconformances) Quality Manager and Management Related Issues 17
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
J Question about GM special requirement - Open Major Nonconformances IATF 16949 - Automotive Quality Systems Standard 2
K CAPA Training for Process Nonconformances Nonconformance and Corrective Action 2
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
Fender1 Nonconformances that do not require Corrective Action Nonconformance and Corrective Action 21
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
T NonConformances as a Tool to Measure Employee Performance Nonconformance and Corrective Action 21
A Surveillance Audit Result - Multiple Audit Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Suspension of ISO 9001 Certificate - Major Nonconformances Identified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
L Non Conformance Register (aka Tracking Nonconformances and Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J How many Major Nonconformances could let the Audit be Terminated? General Auditing Discussions 9
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 14001 Surveillance Audit Nonconformances ISO 14001:2015 Specific Discussions 6
J Corrective Action Timeframe for Internal Nonconformances Nonconformance and Corrective Action 14
R Is it useful to adapt PFMEA's with nonconformances? FMEA and Control Plans 4
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
C System Root Cause and CA (Corrective Action) for ISO 13485 Audit Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 3
M Can a KPI (Key Process Indicator) be created against Nonconformances? Nonconformance and Corrective Action 8
J Certification Body follow up on clearing Audit Nonconformances Registrars and Notified Bodies 4
M NCR and Cost Collection - Capturing nonconformances in the field Nonconformance and Corrective Action 1
Q CTC (Critical to Customer) vs. CTQs (Critical to Quality) Nonconformances Nonconformance and Corrective Action 6
A Escalating Minor Nonconformances into Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D NCRs (Nonconformances) allowed during ISO 9001 Recertification Audit General Auditing Discussions 21
P Is Blaming Operators for Nonconformances correct? Quality Manager and Management Related Issues 62
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
