No standards exist for 7.6a of ISO 17025
Raffy
Hi everyone, :bigwave:
Good day!
Please enlightened me on clause 7.6a)...where no such standards exist, the basis used for calibration or verification shall be recorded.
Correct me if I'm wrong on my understanding, example,
1. if I calibrate an instrument or machine and the equipment I used for calibration is not traceable to a national standard, is the calibration process I made valid? Please advice.
2. I record all verification using a calibration form to document the said process, will that be enough as proof that the equipment I calibrate is valid? Please advice.
3. Is there any other way I can show an auditor that the calibration I made is valid? :frust:
Thank you very much in advance for the usual kind support regarding the matter.
Best regards,
Raffy:cool:
Big Jim
Re: No standards exist for 7.6a
Good day!
Best regards,
Raffy:cool:
This would be a somewhat unusual circumstance. It would be for an unusual measuring tool that has no reference standard. Usually that would be for some sort of measuring tool that what conceived in-house.
Strictly to the standard, you need to define the basis for what you are doing. To me, that would be to explain what you are doing, why you are doing it that way, and probably include the logic involved.
Keeping a record of the activity would not be enough.
BradM
How are you "calibrating" something if it's not traceable to a known standards?
If it's not traceable or a naturally accepted standard, to me it's not a Calibration.:)
John Broomfield
Good day!
Best regards,
Raffy:cool:
Raffy,
Name the food taster or chef and describe how that taster maintains his or her taste buds and how that taster would be replaced so the food continues to taste good instead of relying solely on customer feedback.
This is an example of an internal standard that is only traceable to international standards when the chef wins his or her first Michelin star.
Are you sure no national or international standard exists?
John
dwperron
Good day!
Best regards,
Raffy:cool:
I was wondering about the Clause 7.6 in 17025 that you referred to, because I could not remember any verbiage like that in 17025. I found that there is no Clause 7.6 there, it only goes up to 5.10.
What I did find is that I believe you are referring to Clause 7.6 in ISO 9001-2008. That does quote the phrase you questioned about "where no such standards exist...".
ISO 9001 is not a strong calibration document, and generally only provides broad guidance on what you should do. ISO 17025 section 5.6.2.1 gets more specific, and requires traceability to a national standard except in this case:
5.6.2.1.2 There are certain calibrations that currently cannot be strictly made in SI units. In these cases calibration shall provide confidence in measurements by establishing traceability to appropriate measurement standards such as:
the use of certified reference materials provided by a competent supplier to give a reliable physical or chemical characterization of a material;
the use of specified methods and/or consensus standards that are clearly described and agreed by all parties concerned.
Participation in a suitable programme of interlaboratory comparisons is required where possible.
This is the concept of "intrinsic" standards, where they are generally accepted in an industry. In a case like these you still have to prove that your measurements are "traceable" to measurements that others accept.
To be valid you must be able to relate your calibration results to other outside parties. The burden of proof is on you to show that your measurements are comparable to others.
Ah, but there is! For example, there's no "international" standard for how much a person breathes in, when smoking a cigar/cigarette. However, those organizations which manufacture such products, use machines which are "calibrated" on a lab "round-robin" basis. That is to say, they each share a machine and test data to "normalize" across various labs. This round-robin technique and normalization is well understood to be "calibration"...
BradM
I'm glad it works for them. However, I would never sign off on that being a calibration. :)
The example you state above is well recognized for lab-intercomparison. It is a good method to normalize results and detect variance. But if you don't have something that is considered the "standard", all you're really doing is making sure one is "more inaccurate" than another; it's the so-called blind leading the blind.
If in your example the industry developed some kind of standard measure traceable to an SI (maybe a puff of air measured in Pascals/ "H20), then that could be a standard.
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
M How detailed should procedures be if standards or guidance documents exist? Document Control Systems, Procedures, Forms and Templates 10
C Electric Signs Certification - UL standards exist - Are there any european ones? Various Other Specifications, Standards, and related Requirements 3
T Standards that exist regarding Sterilization of Polypropylene? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Where no standards exist the basis used for calibration shall be recorded General Measurement Device and Calibration Topics 4
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
M Why are EU harmonized particular standards so old & out-of-date? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
M MDR harmonized standards EU Medical Device Regulations 3
C Appendix Z in Harmonised Standards? EU Medical Device Regulations 13
Ajit Basrur Corporate management standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
R Applicable ISO standards - packaging and others Medical Device and FDA Regulations and Standards News 4
Q Standards for Shipping by Sea US Food and Drug Administration (FDA) 2
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
P Citing EN standards Other Medical Device Related Standards 6
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
N Harmonized Standards for MDR Certification EU Medical Device Regulations 7
A Some questions about voluntary consensus standards in traditional 510(k) submission US Food and Drug Administration (FDA) 6
D Imaging/Image Quality Standards Other Medical Device Related Standards 1
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
I Management review in conformity assessment standards - Certification Bodies Management Review Meetings and related Processes 6
Govind Informational ISO COVID-19 response: freely available ISO standards Other ISO and International Standards and European Regulations 1
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
Richard Regalado Informational ISO makes available relevant BCMS standards free for online access Business Continuity & Resiliency Planning (BCRP) 6
A Technical File - Updating Applied Standards EU Medical Device Regulations 4
A NB (Notified Body) Audit of Standards ISO 13485:2016 - Medical Device Quality Management Systems 3
R Applicability of new non-harmonized standards (MDD/MDR) EU Medical Device Regulations 14
dgrainger Informational EU published new Harmonised Standards List for the Directives (25/3/2020) Medical Device and FDA Regulations and Standards News 0
P Static Electricity/Pacemaker - Standards for static electricity generation CE Marking (Conformité Européene) / CB Scheme 3
M Referencing Harmonised Standards in Declarations of Conformity EU Medical Device Regulations 4
Pmarszal External Standards and Regulations Management Process Document Control Systems, Procedures, Forms and Templates 10
S IVF medical devices standards and test methods Medical Device and FDA Regulations and Standards News 4
M What are the standards for malls management? ISO 14001:2015 Specific Discussions 1
A Complaint alert levels - Industry standards pertaining to alert levels for complaints Customer Complaints 5
R MDR standards - which standards to comply with ? EU Medical Device Regulations 3
D Why does Official Journal list superseded standards? EU Medical Device Regulations 6
M MDR "Common Specifications" (CS) - If not standards, then what? EU Medical Device Regulations 5
L In house calibration - Our CMM's are outside certified can I use them to certify our standards General Measurement Device and Calibration Topics 4
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Industry Labelling Standards - non medical Manufacturing and Related Processes 0
J Medical device related standards or regulations - Disposed records log ISO 13485:2016 - Medical Device Quality Management Systems 2
S How many mandays required for the below mentioned standards IEC 27001 - Information Security Management Systems (ISMS) 3
M Standards Subscription Service and Standards Tracking Service Pros and Cons? Other US Medical Device Regulations 3
