Bigfoot
Hello all,
I have a product (cast aluminum) which is susceptible to porosity. Our Customers acknowledge that it exists and have issued engineering specifications for leak rates due to this. They also are aware of the recovery process of impregnation with a solution / resin mixture to seal the cast part so the porosity is sealed & the leak rate meets the engineering spec. We are in the process of considering a different source for impregnation services which would result in a sizable cost savings in freight cost & piece price. This source is being used by a nearby OEM component plant, but they have no process approval (ie: PPAP or PSO) to show from them.
So I would like to :ca: on this and get some of your thoughts on how much or how little would be appropriate in making an evaluation of the supplier?
Is a PPAP appropriate? What about a PSO? I am looking for input in an attempt to make this a somewhat value added process for all parties ( I KNOW, IT'S AUTOMOTIVE SO WHAT DOES VALUE ADDED HAVE TO DO WITH ANYTHING UNLESS I PASS ON THE COST REDUCTION, RIGHT?)
What are all of your thoughts on this?
