Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles?
Johnnymo62
Haste Makes Waste
I've been looking through this section but I don't see anything about non-aerospace QMSs. Is there anything for military trucks, trailers, Humvee type vehicles?
outdoorsNW
If you are AS9100, Aerospace is usually a significant part of your business. Military trucks, but not Humvee types, are usually modified commercial trucks. Commercial truck companies are more likely to fall under either ISO 9001 or IATF 16949.
NADCAP could be applied to military land vehicles processes, but I am not sure if there are any companies in this market, that are not also aerospace, with NADCAP or if there is a rule not allowing it.
You may need to scroll down further on the forum list and look in a different section. Or please give some more details of what problem you are trying to solve or information you are looking for.
Randy
Now I'm curious, which military trucks are just modified commercial vehicles?
mattador78
I saw something a while ago about the humvee replacement which would have more off the shelf parts used to make their repair and down time more cost effective maybe that's what outdoors is alluding to. Speaking from my own experience there is usually a marked difference between military and commercial vehicles (usually with British military ones they have a water boiling facility somewhere as standard, as how else do you make Tea)
Mike S.
Happy to be Alive
A9100D covers Quality Management Systems - Requirements for Aviation, Space, and Defense Organizations - defense can cover a lotta ground.
outdoorsNW
Randy,
To be clear, when I said “modified,” I meant the military truck design was derived/modified from a commercial truck design, not that a commercial truck was built and then parts taken off and new parts added.
I worked for Freightliner for several years. The military trucks were different than a highway truck, but shared many components with an off road truck package you might find on a dump truck, logging truck, oilfield truck, or similar.
I did a lot of work on the parts catalog that was sent to the military, which the military then used to create their own manuals, and I could identify parts similar to civilian applications because we tried to reuse preexisting documentation for an assembly whenever possible.
One model of military truck was based on the commercial FLD model. A second was based on a Western Star design. Even a bomb resistant truck shared parts. For the bomb resistant design, the cab body and cab mounting was custom, but the interior used some parts common to commercial off road trucks and the chassis, suspension and driveline were similar to off road commercial trucks.
Many military trucks are 6x6, which while not common, was an option for the base commercial truck. All the military trucks had lifting points and heavy steel utility boxes which I never saw on a civilian truck.
I found a photo of a M915A5 truck that is a Western Star derivative. Some to all versions of the M916 and M917 were built by Freightliner, and while looking up the military designations, I found references to Kenworth, International/Navistar, and Mack all building military trucks. While I did not find any information, I strongly suspect Oshkosh uses many parts that are either the same or close derivatives of off road commercial truck parts in order to gain the cost savings and reliability benefits of using an existing design.
A Special Procedures for Non Aerospace Customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q AS9100 Repairs - Approval from a non-aerospace customer prior to conducting a repair AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
Q Can a non AS9100 facility build a Aerospace product? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K AS9100 Certification of a Non-Aerospace Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9100C for Non-Aerospace Military Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9100 First Article - Does 7.5.1.1 revC or 8.2.4.2 revB apply to Non Aerospace Goods AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
B Traveler and Router Systems - AS9100 Aerospace Products vs. Non-Aerospace Products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
B 8.3 Non-Conforming Product Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
A Applicability of AS9100 Standards to Non Aerospace Products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Non-sterile reusable surgical instruments - FDA sterilization requirement Other Medical Device Related Standards 0
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
B Procedure packs with non-medical devices EU Medical Device Regulations 1
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
G Team to analyze a non conformance Customer Complaints 26
J Promoting and marketing of a non approved device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G 0 non conformities in registrar audits over 4 years Management Review Meetings and related Processes 12
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
R MDD x PPE Directive - Statement of Non-Applicability EU Medical Device Regulations 3
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
C Non-EU Language Requirements Other Medical Device Regulations World-Wide 3
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
M CE marking for NON-EU EU Medical Device Regulations 0
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
S Non-Conformance and Deviations ISO 13485:2016 - Medical Device Quality Management Systems 4
B Risk Assessment Checklist for Non product Software IEC 62304 - Medical Device Software Life Cycle Processes 1
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
R Applicability of new non-harmonized standards (MDD/MDR) EU Medical Device Regulations 14
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
D Do non-IATF customers need to be included in audit scope? IATF 16949 - Automotive Quality Systems Standard 23
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
