Non-Conformances Found After 3rd Party Sorting
Ac101118
Hello! Long time lurker, first time poster. I’ve recently started working for a new company as a Quality Engineer. We recently had a quality issue at a customer facility. There was poor fill visible in a mounting hole of a bracket. We contracted an outside company to go into the customer to certify all of their product. We recently got called into the customers facility as they have found multiple castings with the same condition in their certified material. We are currently performing an additional sort for this. To date we have found twenty castings in the certified material. The company I work for has no process in place for an issue like this. I was hoping to get some advice on how to handle this situation with the sort company.
Tagin
1) Open a corrective action, if there isn't one already.
2) If your system is 9001, I would look at 8.4.2 & 8.4.3 (Control of externally provided processes, products and services - Type and extent of control and Information for external providers). Did your company implement the necessary controls on the service provider or not? Did your company specify the processes and sorting criteria properly, etc.? Did the service provider fail or did your company set them up to fail?
3) If the controls and processes, criteria, etc. were appropriate, I would issue a SCAR to the service provider.
4) In your containment ("We are currently performing an additional sort for this. "), are you doing the same inspection/sorting process as you directed the service provider to perform? If so, what makes you expect that your sort will be better than the service provider's sort?
You say 20 castings were NC. Was that 20 out of 50? 20 out of 1,000? 20 out of 1,000,000? Just trying to get some perspective.
Ac101118
We found 20 out of 1,000.
As far as the sort, we are performing the same sort. Unfortunately for this issue, it is a visual sort. As a general rule, I hate visual sorts and feel they only set you up for potential failure. However, the sort method was not up to me. Although if I am being honest, I don’t know if I would have a better solution. I do of course understand that a visual inspection will not be 100% effective but is 2% acceptable fallout post sort?
Sidney Vianna
Post Responsibly
I don’t understand why you said “a problem at a customer facility”. Wasn’t the defective castings poured in your plant, the foundry? The fact that your system allowed defective products to be shipped is a serious breakdown.
3rd party sorters don’t certify anything. They “sort” bad from good and apparently your outsourced sorter is not very good at sorting, either.
What is the application of these brackets? Structural? How critical are they?
Tagin
The percentage would be part of the criteria your company should have considered, and should consider now with regard to the second sort. The question should be considered with respect to the customer's requirements: what percentage NC does the customer expect, or allow?
Is the visual inspection criteria conveyed clearly to the inspectors? E.g., are they given instructions with multiple photos of example good, bad, and 'review further' conditions?
Ac101118
So naturally the customer expects 0% quality defects. The problem I am having is, my employer currently has no policy in place with regards to third party sorting. It is a fairly new company and obviously have some Quality System problems to clean up.
As far as work instructions, the were provided with detailed work instructions that displayed the areas the porosity was found as well as 5 pictures of the differing degrees of porosity found at our location.
Ac101118
I fully understand there were many serious failures in our internal systems to allow the escape of this material and they will be addressed. I am not trying to place the blame for this issue on the sort company. I do apologize if it came across that way.
John Broomfield
For this blemish to be a nonconformity you need evidence that it does not conform to the acceptance criteria.
But you have not mentioned any acceptance criteria. Without acceptance criteria you may be chasing perfection.
Be careful about calling this blemish a defect. A true defect would adversely affect the performance of the casting.
Tagin
Establishing a policy would be one of the actions you implement on your corrective action to prevent this in the future, assuming that third-party sorting will be an ongoing service you use. More generally, you would want to look at implementing better controls on selection, planning, controls, etc. on any outsourced services.
As for the third-party sorting company, have you asked them to investigate why they failed (or, did they think 2% was acceptable)? Are they responsive or stonewalling, looking to improve or denying all responsibility, etc? Does your company even want to use them again in the future? Or was this really caused by poorly communicated criteria and controls from your company? These kinds of questions factor into how you want address the issue with them from a quality perspective.
Even though the problems caused for the customer are negative, I always feel that it is the role of Quality to promote internally how such events can be used positively for teaching/mentoring your company on planning, risks and controls; as well as on how corrective actions should lead to beneficial results.
Ac101118
I have already started looking into creating a contract that clearly spells out our expectations with regards to defects, retained traceability information, reporting/communication etc. Essentially establishing our expectations.
When I notified the sort company of the issue the response was “Oh, okay”. There was not even an attempt to defend or apologize, it was simply not a big deal. Unfortunately this is a customer directed sort company, the only one they allow on-site. While I do not like the company we will have no choice but to use them in the future if there is an issue. As mentioned elsewhere, the criteria was clearly laid out and there were multiple pictures. We are allowed a level 2 porosity in the mounting holes, I however instructed them to scrap anything that had visible porosity. I wanted to remove any and all subjectivity from the sort.
D Non-Conformances Problem Solving, Root Cause Fault and Failure Analysis 28
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
G Question about Non-conformances during New Product Introduction Nonconformance and Corrective Action 14
qualprod Internal Audits - Categories of non conformances Internal Auditing 12
Ed Panek Are audit non conformances also risk based? ISO 13485:2016 - Medical Device Quality Management Systems 1
E Example of 9001:2015 audit report with non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Non-conformances whilst in the Design and Development stage of a project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Corrective action on Non-conformances from a long time ago ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Non-conformances due to Human Error Nonconformance and Corrective Action 64
D Consequences of Major Non-Conformances during a Registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E Non-Conformances and the Relevant ISO 9001 Paragraph Nonconformance and Corrective Action 4
P Losing Accreditation - JAS-ANZ has changed the conditions of non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
P Complaints vs. Non Conformances - When is a Complaint a Nonconformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Objecting to Registrar Audit Non-conformances General Auditing Discussions 43
K Cost of Supplier Non-conformances Nonconformance and Corrective Action 5
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Supplier Non Conformances - Format for a Supplier Rejection Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Do ALL non conformances have to be documented? Nonconformance and Corrective Action 1
V Management Review Meeting - Statistics for Customer Complaints and Non Conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Internal Audit Concerns including Escalation of Non-Conformances General Auditing Discussions 6
D Non-Conformances in a Service based industry with no product Service Industry Specific Topics 9
P Interpreting the Process Gap - Open Non-Conformances & ISO Clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Pharmaceutical Non conformances SOP - Solid oral dose start up company Nonconformance and Corrective Action 2
B Internal Audits save you from Non-Conformances on external audits? General Auditing Discussions 16
B 19011 - Reporting Non-conformances: Grading of findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Examples of Non-conformances during ISO/TS 16949 pre/final audits IATF 16949 - Automotive Quality Systems Standard 2
S Priorizing Non-conformances - What is the best way? Nonconformance and Corrective Action 6
J QS-9000 System redesign - Several Major non-conformances - Where to start? QS-9000 - American Automotive Manufacturers Standard 8
austin_howell Non-ionizing electromagnetic hazards and harms ISO 14971 - Medical Device Risk Management 10
I Commercializing a non medical device software Medical Information Technology, Medical Software and Health Informatics 10
I Non-medical device software Preventive Action and Continuous Improvement 1
P Vendor for shipment critical or non-critical ISO 13485:2016 - Medical Device Quality Management Systems 6
I Design Verification Testing on Non-Validated Equipment ISO 13485:2016 - Medical Device Quality Management Systems 2
I Commercialize a non-medical product ISO 13485:2016 - Medical Device Quality Management Systems 5
G 8D on Audit Non Conformance -- Incomplete Document Nonconformance and Corrective Action 23
Leigh76 Regulatory Path for Providing Sterile Product in Bulk Non-Sterile Form to Kit Packers US Medical Device Regulations 3
G Clause 8.5.1 -- Is non Identification evidence of ineffective control of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
D Implementation deadline - non significant change acc. to MDCG 2020-3 EU Medical Device Regulations 3
J Is ISO 13485 certification necessary for Class I (non-sterile) medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 7
P Product label supplier, critical or non-critical vendor ISO 13485:2016 - Medical Device Quality Management Systems 6
C New 510(k) for non-patient contacting material change US Medical Device Regulations 2
D 10.2.3 Problem Solving - What to look for at a non production remote site? IATF 16949 - Automotive Quality Systems Standard 5
S File Conversion: Device or Non-Device? Japan Medical Device Regulations 0
J Maintaining site specific ISO Compliance/Certification within a non-certified organization & centralized processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Non-reportable customer complaints and CER EU Medical Device Regulations 2
M External audit non conformity related to applicable regulations ISO 13485:2016 - Medical Device Quality Management Systems 7
G Non-significant changes EU Medical Device Regulations 6
Ajit Basrur Electronic Records - leave non-mandatory fields blank? Qualification and Validation (including 21 CFR Part 11) 10
S Pros and cons to transition to AS9100 for non aerospace company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
