Non Conformity of Support Processes - Need another NC form?
Q
QAMTY
Hi everyone
Do you have any idea as to how to manage NC?s on the support processes?
For example NC?s of nonconforming product fall under 8.3, for that I plan to have a procedure and a form for catching the nc?s defining the dispositions.
But I?m not sure how to manage a nc of a user complaining against
HR because he didn?t receive a uniform at the right time, or
against IT because received a poor softwaer installation
I know 8.3 focuses on product not on the mentioned services.
Would be a good idea to have a form for NC product
and other form for the other NC?s (HR and IT)?
For the 8.3 I have a procedure and form.
Or such issues should fall into internal complaints?
I sell machinery for the Oil Industry
Any feedback is appreciated
Re: Non conformities of support processes
Hi everyone
You are always looking at your system.
What is wrong, what is the issue, what is the problem, what is the non-conformance.....
Can it be right away corrected ? Please do
Does my system desire that this does not happen again ?
What can I do to ensure that this typical problem does not resurface ?
Extend the same thought as for your product to your support services.
You are responsible to make your internal systems smooth and trouble free for quicker and smarter working that will result in better meeting your customer requirements and your business requirements.
The form you use can be any that suits you.
Remember that any corrective actions shall be appropriate to the effects of the nonconformities encountered.
harry
Does the phrase "wherever the term product occurs, it can also mean service" (see 3. Terms and definitions) ring a bell in you? You need not have a separate NC form - the service provided by supporting processes are considered as 'product' according the above.
Too many forms create nightmares for users and often serves to trap your own self if a wrong form is inadvertently used.
Q
QAMTY
Thanks Harry
But don?y you think that:
First:
When referring the product and services are the ones delivered to the client
not internal services.
Second:
When managing NC products is needed to define dispositions
and sometimes internal services, most of them don't apply dispositions.
That?s why I try to separate them.
Thanks Harry
First:
Second:
I can see you are clear about the product requirement.
However your question relates to analysis of data and then improvement.
8.4 Analysis of data
The organization shall determine, collect and analyse appropriate data to demonstrate the suitability and effectiveness of the quality management system and to evaluate where continual improvement of the effectiveness of the quality management system can be made. This shall include data generated as a result of monitoring and measurement and from other relevant sources.
Above from ISO9001; 8.4
If your concern is from a relevant source, consider it for continual improvement.
Use the steps as said in 8.5.2. This clause is general and not product specific.
Again, always remember that :
Corrective actions shall be appropriate to the effects of the nonconformities encountered.
The form is only a means. You can very well use the same form that you have for your product NC corrective action.
harry
Thanks Harry
First:
Second:
I think I understand your question better now - You tie your NC form to 8.3 Non Conforming Product. In my case, I tie my NC form (non conforming report form) to 'non-conforming' as defined in 3.6.2 of ISO 9000 - so I have the freedom to use it on any NC.
When referring the product and services are the ones delivered to the client not internal services.
In real life, do you think you can deliver a conforming product or service to your customer when you have non-conforming internal (product realization) process or processes? I am referring to the installation of software which can have an effect on your ability to satisfy customer requirements.
With regards to issuance of uniform at the right time, these are HR issues unless your system has provisions for it.
ssz102
in my opinon, whether the NC are come from product process or other support process, the nature of them are the same;
so the format is not query no matter which the NC format will be used, for they are including the description of issue and containment actions and root cause analysis and corrective actions taken etc.
the purpose of actions taken is prevent to this phenomenon are recurring
Randy Lefferts
Hi Qamty,
Why not have an identifier at the top of the form differentiating whether it?s a product or service nonconformance? You could have a check box for product and another one for service or however you choose to do it. Just check the one that it pertains to, fill out the appropriate sections of the form and then route it appropriately.
We used to use a corrective action form that had 6 or 7 checkboxes at the top of the form that we would mark. CAR?s can be issued for Safety, Audits, Customer Issue, Environmental, etc. and the appropriate header checked. These were completed and then routed appropriately so that trend analysis could be performed. Obviously there were areas of the form that weren?t filled out depending on the type of C.A.R. it was. Customer Issues involved parts and as such, part numbers, plant location, etc. were recorded on the form. These areas were blank when using the form for an audit C.A.R. or Safety Issue.
Bottom line, all pertinent information was captured on one form for various types. No need to have multiple forms.
T Justification of use of non-harmonized standards for MDR conformity Other Medical Device Related Standards 12
B Leadership non-conformity, Top Management's involvement in Problem Solving IATF 16949 - Automotive Quality Systems Standard 10
M Is this situation Non-Conformity??? General Auditing Discussions 8
G Not accepting a non conformity during an audit General Auditing Discussions 11
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
qualprod Non conformity, do nothing? Employee experiencing "hard times" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
M Auditing a Contractor in EMS and Non Conformity Report General Auditing Discussions 1
A IATF 16949 - Non-conformity on 5.1.1.2 Process effectiveness and efficiency IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949: Definition Major/Minor Non-conformity IATF 16949 - Automotive Quality Systems Standard 8
E Non Conformity due to Outsourced Internal Audit Error ISO 14001:2015 Specific Discussions 2
J Non-Conformity Overreach - We recently switched our EU Authorized Representative ISO 13485:2016 - Medical Device Quality Management Systems 6
R Non-Conformity Report from Notified Body - MEDDEV Guide is not Legally Binding EU Medical Device Regulations 16
B A question of Non-conformity specifics - AQAP2120 (The MOD's equivalent to ISO9001) General Auditing Discussions 1
Q Non Conformity in Audit: Missing Deputy Rule ISO 13485:2016 - Medical Device Quality Management Systems 10
S Internal Audit - Non conformity not easily fixable (Sales and Contracts) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
L Non Conformity (Nonconformance) Report & Preventive Action Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
S Some departments don't have Quality Objectives - Non Conformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 68
S HR Manager refusing to create Quality Objectives - Is this a Non-Conformity? Quality Manager and Management Related Issues 11
H Product Non-Conformity and Document Change Request Forms - Corrective Action needed? Nonconformance and Corrective Action 16
A Declaration of Conformity for non-CE Mark products CE Marking (Conformité Européene) / CB Scheme 2
Q How do you define repeated non conformity (aka Recurrence)? Nonconformance and Corrective Action 24
T A confusing Non-conformity - No defined QMS processes intended for 'Management' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Non-EU countries who use your EC Certificate & Declaration of Conformity Other Medical Device Related Standards 3
eternal_atlas Identification of ISO 9001 Clause to a specific Non-Conformity General Auditing Discussions 7
C Show cause letter given as a result of a minor non-conformity raised by CB Quality Manager and Management Related Issues 6
L Completed Non-conformity report examples needed! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
T Non-conformity - Not performing Supplier Development on one specific supplier IATF 16949 - Automotive Quality Systems Standard 25
A Communicating to our employees: consequences to customer of non-conformity IATF 16949 - Automotive Quality Systems Standard 3
D TS 16949: 2002 section 7.6.1 - MSA non conformity at registration audit IATF 16949 - Automotive Quality Systems Standard 2
K Major Non-Conformity During Initial TS16949 Audit Nonconformance and Corrective Action 2
M Record Falsification - What clause to raise a non-conformity? Records and Data - Quality, Legal and Other Evidence 20
F Using non-randomized clinical study for change in existing 510(k) device? US Food and Drug Administration (FDA) 1
L Non Applicability of Clauses in ISO13485 for Medical Devices Medical Device and FDA Regulations and Standards News 4
B Transport Validation For Non-sterile Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
W Posting Non-Quality System instructions on the Production Floor Manufacturing and Related Processes 13
L Saudi regulations for Japanese non sterile scopes Japan Medical Device Regulations 0
D Is a lost calibrated tool an non-conformance for an audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 58
malasuerte Performance of ISO 9001 certified vs. non-certified manufacturing companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
K Non-Device MDDS Clarifications (FDA) US Food and Drug Administration (FDA) 7
S Non-approved supplier? Supplier Quality Assurance and other Supplier Issues 3
R FMEA's for non-manufacturing sites FMEA and Control Plans 4
D Shelf life of non sterile class IIb product. ISO 13485:2016 - Medical Device Quality Management Systems 1
ChrisM Class 1 non-sterile device, need certified QMS or not? EU Medical Device Regulations 2
N Non-dairy Creamer US Food and Drug Administration (FDA) 3
G Shipping Validation of Non-Sterile Parts? Other Medical Device and Orthopedic Related Topics 9
Edward Reesor Class I non-sterile "Shelf Life" labeling (EU/UK) CE Marking (Conformité Européene) / CB Scheme 4
E Comparing process parameters on non-normal batches Capability, Accuracy and Stability - Processes, Machines, etc. 11
