Non-destructive testing methods are special processes?
armani
I read on BINDT (British Institute of Non-Destructive Testing) site that NADCAP consider non-destructive testing methods (ultrasonic, coating thickness measurement etc.) as special processes.
NADCAP
Here is the quote:
"A special process is a QA term which refers to any process where the results of the process cannot be easily verified after completion of the process. Examples of special processes are: Non-Destructive Testing; Materials Testing; Heat Treatment; Coatings. The results of a special process are highly dependent on the control of the process and/or the skill of the operator."
I cannot fit these methods into special process definition - anyone can help?
dsanabria
re: Non-distructive testing methods are special processes?
Not sure what is it that you don't get so let's try this example.
Two pieces are welded but you need to know if the joints are good - so you include a "Special Process" - in this case - Non Destructive Testing - i.e. X-RAY to verify that the welds meet requirements.
Thus - welding is the action and X-Ray is the Special Process.
armani
Re: Non-distructive testing methods are special processes?
Welding is a special process by definition....why X-Ray??
ScottK
Not out of the crisis
The way I see it is that Welding is a special process, as you say, by definition because the only way to test a weld is destructively.
So you might use X-ray as verification method.
But you need to validate that verification method works - thus making that a special process in and of itself.
Ninja
Looking for Reality
A curiosity, stemming mostly from my ignorance on this topic...
So measuring (testing) the length of a machined part is a "special process"?
- Measuring color?
- Measuring brightness?
- Measuring weight on a balance? Diameter? Height?
- Measuring surface finish of a polished surface?
- Index of refraction?
- All Visual inspection?
- Measuring the distance between electrodes?
- Measuring electrical conductivity/resistance?
All of these are non destructive tests, as are many, many others...:read:
Sidney Vianna
Post Responsibly
If you do a Cove search for the words "special process" in the title of the thread, you will find numerous threads where this has been discussed.
dsanabria
X-Ray falls into the NDT (non Destructive Test).
X ray is able to detect is there are any imperfections in the weld or around the weld without destruction or taking the pieces apart.
Due to the fact that X-Ray is very intrigue - specialist are needed to read the results of the X-Ray - thus "Special Process.
Note: X-Ray is not the only method that can be used to detect imperfection it is only one of the many ways.
To bring simplicity - it's like going to a hospital to determine where the discomfort is at - X-Ray is one of the methods used for that process.
Hope this answer your question as to why...
ScottK
- Measuring color?
"Non-Destructive Testing" as we're talking about here is very specific to "Special Processes"... A "Special Process" is something that can't really be checked conventionally so NDT is used to look at characteristics that can show if the part will fail... like using X-rays for welding... the x-rays isn't testing the weld strength - it's looking for cracks that can correlate to a weak weld...
So in your examples pretty much all of them can be measured directly without destroying the part, so they are not the results of a "special process"
dig?
The closest I can see in your list is surface finish - in my new job we have some parts where conventional surface finish testing would scratch the part to make it unusable so that's a destructive test for us... we're looking into non-contact profilometers....
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Non Destructive Testing of plain Carbon steel castings using Eddy Current Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R NDT (Non-Destructive Testing) - How I can get at least Level 1 certified? Professional Certifications and Degrees 4
D 76/211/EEC 2.3.3.1 Criteria for Non-Destructive Testing Statistical Analysis Tools, Techniques and SPC 2
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 0
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
B Procedure packs with non-medical devices EU Medical Device Regulations 1
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
G Team to analyze a non conformance Customer Complaints 26
J Promoting and marketing of a non approved device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G 0 non conformities in registrar audits over 4 years Management Review Meetings and related Processes 12
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
R MDD x PPE Directive - Statement of Non-Applicability EU Medical Device Regulations 3
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
C Non-EU Language Requirements Other Medical Device Regulations World-Wide 3
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
M CE marking for NON-EU EU Medical Device Regulations 0
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
S Non-Conformance and Deviations ISO 13485:2016 - Medical Device Quality Management Systems 4
B Risk Assessment Checklist for Non product Software IEC 62304 - Medical Device Software Life Cycle Processes 1
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
