Non-normal Distribution Selection where the system is constantly being corrected
bobdoering
Stop X-bar/R Madness!!
#11
Exactly - the ability to see process change is based on the resolution of the measuring instrument (GAGE R%R to %PV). Enough resolution will definitely see sawtooth...its physics. You would have to have a perfectly synced load to energy application to have it on...constantly...and not have it rise in temperature. Pretty rare, I would say.
Also, remember, ramp up and ramp down are special causes, and do not relate to the capability, only the steady state.
BradM
#12
I have a temperature controller. If I have it tuned properly, it's not going to swing; or at least not to a significant level.
Ramp up is also affected by the PID settings. The point at which the controller starts throttling back (and at what percent) also depends on the PID.
Bottom line, if your process equipment is not a nice line, including a smooth ramp up with no overshoot, the controller needs adjustment.
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
M Is it possible to get Natural Tolerance (Tn) with Non Normal Distribution? Statistical Analysis Tools, Techniques and SPC 9
A Finding Control Limits for a Non-Normal Distribution Statistical Analysis Tools, Techniques and SPC 3
R Torque Confidence Testing (Non-normal Distribution) Statistical Analysis Tools, Techniques and SPC 5
F Non-Normal Distribution vs. Gamma Distribution Statistical Analysis Tools, Techniques and SPC 18
M Cp, Cpk, Dpm, or other? Diameter of a Hole - Non-Normal Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 20
J Capability of Inherently Non-Normal Process - Plating Process Thickness Distribution Statistical Analysis Tools, Techniques and SPC 9
C Analyzing Data with a Non-Normal distribution Statistical Analysis Tools, Techniques and SPC 41
N Determining whether a process yeild is normal or non-normal distribution? Six Sigma 10
P Gage R&R and non-normal distribution - Alternatives to a standard gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Calculating Cp and Cpk on a Non-Normal Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 14
D Control Charts for Non-Normal Distribution Statistical Analysis Tools, Techniques and SPC 3
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
R Non Normal Data in a historically normal process Capability, Accuracy and Stability - Processes, Machines, etc. 6
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
M t-test with Non Normal Data Statistical Analysis Tools, Techniques and SPC 16
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
B Test of Means or Medians for Non Normal Populations? Using Minitab Software 6
R Transforming or not Transforming - Dealing with Non-Normal Data Statistical Analysis Tools, Techniques and SPC 10
optomist1 Non-Normal Data F test and T test Capability, Accuracy and Stability - Processes, Machines, etc. 19
S Which Normality Test more acceptable to FDA; Also, Non-Normal Threshold? Qualification and Validation (including 21 CFR Part 11) 5
M Non-Normal Data & Minitab Statistical Analysis Tools, Techniques and SPC 17
M Non Normal Data Managing - Clements Method to get Process Characteristics Statistical Analysis Tools, Techniques and SPC 8
S How you define 'Normal & Abnormal' Conditions and 'Routine & Non-routine' Activities ISO 14001:2015 Specific Discussions 8
M How to Do Ppk on Non-Normal Data Capability, Accuracy and Stability - Processes, Machines, etc. 10
T Non-normal data for Cp Cpk indices Statistical Analysis Tools, Techniques and SPC 1
U Calculate Z-Score for Non-Normal Data - I have two set of data Statistical Analysis Tools, Techniques and SPC 9
S Capability Analysis of Non-Normal Data Statistical Analysis Tools, Techniques and SPC 23
T Cp and Cpk calculation for Non-normal data? Statistical Analysis Tools, Techniques and SPC 11
F Process Capability for Non-Normal Process Statistical Analysis Tools, Techniques and SPC 5
T Capability with Non-Normal Data - Component Strength Statistical Analysis Tools, Techniques and SPC 11
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
Y Perform 2 ways ANOVA in minitab with non normal data involved Using Minitab Software 5
B How to identify whether my data is non-normal? Statistical Analysis Tools, Techniques and SPC 26
U Quality control with non-normal, censored and truncated data examples needed Statistical Analysis Tools, Techniques and SPC 0
A ANSI Z1.4 or Z1.9 for non-normal distributions? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
BradM Use of Non-Parametric Statistics and Non-Normal Data Statistical Analysis Tools, Techniques and SPC 33
D Ppk of non-normal bounded proccess, one sided specification Capability, Accuracy and Stability - Processes, Machines, etc. 3
N Analysis of non-normal stratified data for cpk/ppk? Rupture test Capability, Accuracy and Stability - Processes, Machines, etc. 6
D Control charts for non-normal distributions - Do I need to do anything special? Statistical Analysis Tools, Techniques and SPC 5
D Johnson's Transformation - Minitab 14 - How can I find out Ppk - Non-normal Distribu? Using Minitab Software 9
R P-value is 0.05 - Normal or non-normal data? Capability, Accuracy and Stability - Processes, Machines, etc. 31
L How to calculate tolerance intervals for non-normal data? Reliability Analysis - Predictions, Testing and Standards 13
J Is a t-test used in non-normal data analysis? Six Sigma 7
