Non parametric test for semi-quantitative data.
Hi everyone, I have a question about the sample size for paired comparison test. I want to compare multiple measurements from 2 machines, in order to demonstrate that there is no significant difference between these 2. Each day I can run these 2 machines in the same condition, so for each day I will have a pair of data from these 2 machines.
1. The first measurement I want to test is a semi-quantitative measurement, which have a limit of quantification (below that limit, the machine is not capable to give the exact result). Historically, we have around 13 data, which are all below this limit. For the testing, I want to consider this limit our acceptance criteria. But I don't know how many runs minimum I need to have.
2. The second measurement I want to test is a count data. Since we don't have a acceptance criteria, I am thinking about a non-parametric test for paired data. In that case, how many runs minimum I need to have?
Thanks for the help.
S.
If you run the machines at the same time using the sample batches of material (split the materials) adn if you randomly mix the operators between machines, you will only need to run the machines for 5 days, using all of the results for each machine each day. Then if all 5 of 1 machine’s results are better than all 5 of the results of the other machine then you will have an alpha of 5% that the machines are different from each other (subject to any othet confounding). This is a matched pair parametric test that use simple probability. It is like flipping a coin 5 times in a row and getting 5 heads. (Or 5 tails). It will work for all kinds of data.
We would need more details to give a more detailed answer...
Thanks Bev D for the answer. I see your point here, so we consider that for each run, one machine has 50% chance of getting a better result than the other one (if we suppose that the 2 machines are similar). The fact that all my data are below the limit of quantification can be a problem? (some null results and some positive results w/o the exact value).
For each day, the 2 machines will be run by the same operator in the same condition, in short interval of time. What details do you need to give a more detailed answer? Sorry I am not yet familiar with all this.
If one of your characteristics is so low that you only get zeros or a result below the limit of detection, why are you concerned if the machines are different on this characteristic? The test will tell you if there is a difference or if there isn’t...we never do a comparison test to prove one answer or the other we do it to know which answer is true.
Steve Prevette
Deming Disciple
Not having an acceptance criteria doesn't mean you need to shift to non-parametric tests. By the way, a good "guesstimate" for sample size is 25, given no other information.
L A "good" non-parametric test summary? Statistical Analysis Tools, Techniques and SPC 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
BradM Use of Non-Parametric Statistics and Non-Normal Data Statistical Analysis Tools, Techniques and SPC 33
F MSA for non-contact CMM - ISO10360 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M Using a Non Certified vendor Supplier Quality Assurance and other Supplier Issues 5
somashekar Justification for Non-applicable clause at Stage 2, in clause 4. ISO 13485:2016 - Medical Device Quality Management Systems 11
Z Swiss Authorized representative & non-medical device regulations Other Medical Device Regulations World-Wide 0
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
D Help Me. Non conformitty in External Audit IATF 16949 - Automotive Quality Systems Standard 13
S Electronic Signatures - Non-Conformance - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 30
S Do you follow your QMS for non-device software features? Medical Information Technology, Medical Software and Health Informatics 4
J Can we register non-device clinical decision support software under draft guidance? Other US Medical Device Regulations 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
M Selling non-CE marked devices for evaluation EU Medical Device Regulations 4
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
L "Shelf-Life" Class I Non-Sterile Products Expiration Date? CE Marking (Conformité Européene) / CB Scheme 3
B Process / Procedure - Radiographic (X-Ray) Non-Film Document Control Systems, Procedures, Forms and Templates 0
N How to find column number for the last non-empty column? Using Minitab Software 0
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
G Competent Authority non-EU Manufacturer EU Medical Device Regulations 7
F Non conforming locked? Manufacturing and Related Processes 13
M Changing Investigational Device from Non-Sterile to Sterile - what are the implications? Other Medical Device and Orthopedic Related Topics 3
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
J Informal vs formal scope creep... managing non-medical devices through system processes ISO 13485:2016 - Medical Device Quality Management Systems 2
G Not accepting a non conformity during an audit General Auditing Discussions 11
J In-house (NHS) manufacture and use (by staff) of non-medical devices.. any regulations apply? UK Medical Device Regulations 6
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
A Brexit Mandate for EU Authorised Representative for non medical devices CE Marking (Conformité Européene) / CB Scheme 7
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 4
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
B Procedure packs with non-medical devices EU Medical Device Regulations 1
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
G Team to analyze a non conformance Customer Complaints 26
J Promoting and marketing of a non approved device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
G 0 non conformities in registrar audits over 4 years Management Review Meetings and related Processes 12
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
