Non Value Added Corrective Actions
Golfman25
So our last TS audit was a real doozy. Turns out for the last 15 years we have been doing control plans "wrong." We got hit on a couple of items which essentially amounted to terminology and reclassification. In addition, he hit us on the classic "gage r&r" for the eyes/visual inspection used for a simple damage check. None of the "corrections" affected what we actually do. We just reworded and reworked the control plan to "fix" the offending items.
But here's the rub. All of the "fixes" need to be done to 100 control plans before he shows up again. Otherwise, there's something about ineffective corrective actions and major non-conformances. Seems like a complete waste of time. I would rather update them as they need a substantive change.
Any words of wisdom to tell the guy when he comes back?
Jen Kirley
Quality and Auditing Expert
Ouch! Do you think he was correct about the terminology? If not, I would consider a dispute.
If so, Does the terminology affect product or service? If not, I would consider a dispute.
If so, Do these control plans get a periodic review? If not, are they reviewed at time to make the product again?
If so, I would propose to do the update of remaining control plans at time of periodic review or review when it is planned.
If this is truly a petty issue, a dispute could help. Auditors need more oversight than we sometimes get. There are two factors apparent to me here:
1) The auditor may be wrong.
2) If the auditor is correct, all the previous auditors have been wrong not to make the same finding.
The dispute process can help with both. Ideally, in addition to correcting a wayward auditor, it gives the CB something to include in annual training so as to reduce variation in auditors.
:2cents:
randomname
If the solution to the NC do not involve changes, then it is non-value added. I would consider contacting the CB about this.
And if you do need to revise them due to minor "incorrect terminology" (wonder if the auditor would also write you up for punctuation!?) then you should be able to do them based on an as-needed schedule ... e.g., before they are used again.
Golfman25
Ok. Let give an example. We have a step called "setup." We set the tooling,. make samples, verify the samples against the print, and make any tooling adjustments necessary. The CP form wants both process and product controls. As a tooling dominant process, we don't have a lot of process controls - i.e.; specific machine settings. Those that we do have, have been compiled in our routing/traveler structure over the years. So when we put together control plans, we used the product characteristics (the print) as opposed to process characteristics (machine settings). The net result is the same. Setup, verify, adjust.
Our "corrective action" was to simply rephrase the wording into "process characteristics" and move on. (I did file an appeal but the higher ups had no interest in listening). Absolutely provided zero value. Fine. As we make new plans (or change old ones) we make the change. No real issue there. The problem being the older plans. There is no value going back and updating.
QualitySpirit
what was the root cause you identified that led to the corrective action "simply rephrase the wording into "process characteristics" and move on"?
QualitySpirit
Probably, 3rd party auditor incompetence :notme:
:D
Seriously I want to know the root cause the client identified so that they came up with the corrective action like that.
It sounds to me that "simply rephrase the wording into "process characteristics" is a "correction" and not a systematic corrective action.
If the control plan describes product characteristics and process parameters inaccurately, if this is a fact - it indicates a systematic deficiency in control plan development process.
- If the CB accepts "simply rephrase the wording into "process characteristics" as an appropriate corrective action to close this NC, I agree that it is a totally no value added corrective action. But I doubt that they accept this?
- If it otherwise leads to a corrective action to fix why the control plan was developed in that incorrect way, it would not be a no value added corrective action.
If you have any good basis that the auditor understanding is wrong, you can argue at the closing meeting and refuse to sign the acceptance of the audit report/ NC report.
D Testing process is non value added process under TS16949? IATF 16949 - Automotive Quality Systems Standard 1
S PPAP can we say waiver? A bureaucratic, non value-added mess QS-9000 - American Automotive Manufacturers Standard 38
R P-value is 0.05 - Normal or non-normal data? Capability, Accuracy and Stability - Processes, Machines, etc. 31
M Selling non-CE marked devices for evaluation EU Medical Device Regulations 4
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
L "Shelf-Life" Class I Non-Sterile Products Expiration Date? CE Marking (Conformité Européene) / CB Scheme 3
B Process / Procedure - Radiographic (X-Ray) Non-Film Document Control Systems, Procedures, Forms and Templates 0
N How to find column number for the last non-empty column? Using Minitab Software 0
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Competent Authority non-EU Manufacturer EU Medical Device Regulations 7
F Non conforming locked? Manufacturing and Related Processes 13
M Changing Investigational Device from Non-Sterile to Sterile - what are the implications? Other Medical Device and Orthopedic Related Topics 3
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
J Informal vs formal scope creep... managing non-medical devices through system processes ISO 13485:2016 - Medical Device Quality Management Systems 2
G Not accepting a non conformity during an audit General Auditing Discussions 11
J In-house (NHS) manufacture and use (by staff) of non-medical devices.. any regulations apply? UK Medical Device Regulations 6
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
A Brexit Mandate for EU Authorised Representative for non medical devices CE Marking (Conformité Européene) / CB Scheme 7
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 4
L Water requirement for Non-sterile topical OTCs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
B Procedure packs with non-medical devices EU Medical Device Regulations 1
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
G Team to analyze a non conformance Customer Complaints 26
J Promoting and marketing of a non approved device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G 0 non conformities in registrar audits over 4 years Management Review Meetings and related Processes 12
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Johnnymo62 Non Aerospace topics - Anything for military trucks, trailers, Humvee type vehicles? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
R MDD x PPE Directive - Statement of Non-Applicability EU Medical Device Regulations 3
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
C Non-EU Language Requirements Other Medical Device Regulations World-Wide 3
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
