Nonconformance about MSA (Measurement Systems Analysis) in ISO/TS16949:2009
berseak
I got an NC for MSA.
I implemented only GR&R variable. But auditor gave NC. Comment is: "Shall implement GR&R attribute, bias, linearity and stability. Refer MSA Manual 4th ed.
What do you think about this?
qusys
Re: NC about MSA in ISO/TS16949:2009
If formulated in this way, it can be questionable or have more details.
I do not know what you have agreed with your customer based upon 7.6.1.
Statistical studies shall be done for measurement equipment and test recalled in the control plan.
I do not know how you proceed in your calibration system but if you have a regular calibration program with demonstrable results, together with GR&Rs variable done, you should be ok
:bigwave:
I've had a similar experience where all 3 studies were expected! My understanding is that not all 3 are appropriate to all equipment, all of the time.
What equipment type was the subject of the GR&R study? What types of study had you performed?
bobdoering
Stop X-bar/R Madness!!
They are pretty much are quoting TS 16949:2009 7.6.1, and yes, they state studies SHALL be conducted per and conform to the REFERENCE manual, which suddenly makes the reference manual a standard. :rolleyes: Bias and linearity are calibration, and even the basic ISO standard requires that.
It sounds to me like the auditor is quoting the PPAP manual, not 16949. PPAP 4th Edition, page 6: "The organization shall have applicable Measurement System Analysis studies, e.g., gage R&R, bias, linearity, stability..."
That "e.g." means "for example," and is not prescriptive in all cases. The key word is "applicable." Studies should be appropriate to the device and system.
Note 1 says, "Gage R&R acceptability criteria are defined in the Measurement Systems Analysis reference manual." (Emphasis in the original)
So the only reference to the manual is for GR&R acceptance criteria, which is the weakest part of the manual.
bobdoering
Since the standard states "The analytical methods and acceptance criteria used shall conform to those in customer reference manuals on measurement systems analysis, " so you can include any applicable manual, including the CSRs which can be even more prescriptive. At the AIAG MSA rollout, their warning is NOT to make it a requirement in your own QM, or you can be held to it. Some customers have done that to you anyway. IATF holds no further clarification in their guide...so they think it is pretty clear (to them).
But, you always have the option to have the auditor clarify specifically what in the standard they are referring to.
Q
QualityQ
Does any of you, use any statistical methods for destructive measurement systems, such as burst test?
I've read the chapter IV of the MSA manual, forth edition. As far as I understood, I can follow the cpk+cp and if the process is under control, etc.
As the total sigma is a function of measurement system's sigma and the process sigma, this method seems ok to me?
I really think that standard GRR study is not applicable in this case.
What do you think?
berseak
Thank you for all comment.
Actually I refer customer manual. In manual request only GR&R veriable.
(I show auditor already both manual and 7.6.1
The analytical methods and acceptance criteria used shall conform to those in customer reference manuals on measurement systems analysis​
) But it's waste.
What ever will be will be.
berseak
. (4) GRR (attribute) for visual inspection (deformation) did not include Kappa, miss rate and false alarm rate.
I copy some wording from CB auditor. I disagree with Kappa. He said because refer MSA 4th edition shall implement.
really?
JuneFoo
Hi, berseak,
To share an audit experience during my TS2 audit July this year, we did conduct Kappa study but customer reference manual did not specific type of GRR shall conduct, the CB advise us to get customer agree on our MSA method during PPAP submission, then the issue is solve. Cause the TS clause ask everything's refer to customer manual, not AIAG manual.
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
E When to generate a nonconformance report ISO 13485:2016 - Medical Device Quality Management Systems 6
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
qualprod Ineffective follow up of people performance - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Timing allowed by IATF to close a Remote Site Minor Nonconformance IATF 16949 - Automotive Quality Systems Standard 2
R Visually impacting graphics for Nonconformance status metrics for Management Report Nonconformance and Corrective Action 5
J ISO 13485 Audit Nonconformance written against 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 25
PastorBee13 IATF 16949 Audit Nonconformance Responses per 5.1.1.2 - Format IATF 16949 - Automotive Quality Systems Standard 11
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
S Nonconformance to a Note in ISO13485 clause 6.2 Human Resources Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 13
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
Ajit Basrur Are inputs to the nonconformance process required to be identified? Nonconformance and Corrective Action 21
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
qualprod Should I initiate CAPA for a nonconformance not recorded? Nonconformance and Corrective Action 25
K Nonconformance on training - Not following own processes (IATF 16949) Internal Auditing 14
J Audit opportunity for improvement raised to nonconformance months after the audit General Auditing Discussions 7
GStough Pushback on a Nonconformance Found in a Supplier Audit General Auditing Discussions 22
K NCR or CA? We're taking any issue we have and saying its a nonconformance Nonconformance and Corrective Action 11
GStough Nonconformance Found Outside the Audit Scope - Supplier Audit General Auditing Discussions 16
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Nonconformance Raw Material Treatment in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
N Laboratory Audit Nonconformance - Maintenance of Standards ISO 17025 related Discussions 10
K Internal Auditing a previous Nonconformance? Internal Auditing 19
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 2
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
P Ratio of Supplier with a nonconformance vs. Supplier without a nonconfomance Supplier Quality Assurance and other Supplier Issues 10
W Nonconformance Recurrence Response Help General Auditing Discussions 4
dubrizo If Quality Objectives are not known to employees, is it a Nonconformance? General Auditing Discussions 7
xfngrs Automotive Industry Nonconformance Database wanted - Preferably SharePoint based Quality Assurance and Compliance Software Tools and Solutions 5
Gman2 Processes sharing the same nonconformance during an audit General Auditing Discussions 13
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
