Corrective action time will be stipulated in the body of the audit report and becomes a requirement that must be fulfilled and that's where the date comes from.
Right here is what is contained within our report format....
A nonconformity requiring attention was identified. This, along with other findings, is contained within subsequent sections of the report.
A minor nonconformity relates to a single identified lapse, which in itself would not indicate a breakdown in the management system's ability to effectively control the processes for which it was intended. It is necessary to investigate the underlying cause of any issue to determine corrective action. The proposed action will be reviewed for effective implementation at the next assessment.
Please submit a plan detailing the nonconformity, the cause and your proposed corrective action, with responsibilities and timescales allocated. The plan is to be submitted no later than x/x/xxxx by e-mail or fax to your assessor, referencing the report number.
If it's not done then there is a failure to fulfill a system requirement (contractural). In fact I had to notify a client not 15 minutes ago about this very subject.
Perfectly acceptable and also required by the CB's Accreditation Body
Or....
The organization has a requirement it has set for action to be taken that stipulates a time frame
Or....
