Sorry, if my question posted was not clear and did not sufficient data.
1. It was an internal Audit
2. Process audited was: Document & Record Control
NC raised was on the process: Document & Record Control. Internal auditor checked if to ensure previous NC's raised during inter audit were closed and found one NC that was raised to Marketing Dept still open. Marketing dept had mentioned the implementation date to close the date, but failed to meet the date for reasons unknown.
Hence NC was raised to MR reporting previous NC was still open.
No where we have mentione din any our process on the time lines for closing the NC.
Hope the information helps.
Anand
Thanks Anand, as you can see, the better the information and the background provided, the more it is possible to provide targeted information. (And avoid endless guessing)
So, the auditor raised an NC on just
one single unclosed NC? This seems possibly a bit over-zealous and rather thin on the evidence side to me.
As
audit manager,I would be asking the auditor:
* Is this the only evidence you have?
* On what basis is the NC issued (if there's no timing guidelines in the procedure for example)? Anything to quote or is it simply auditor belief/preference?
* How
important was this particular NC? eg, was it a high risk item that should have been actioned promptly? Or not? Is there a risk? If so, what is it, and how much of a risk?
* Have other NCs been closed in a timely fashion?
* Is there an apparent pattern of lengthy/untimely closure? What's the evidence for that?
* What action was required to close this one?
* Is there reasonable evidence (eg, executive away) of difficulty in closing/actioning this particular one?
* Why is
one single unclosed NC considered important enough to raise another NC on?
As you can see - there's no single, simple answer.
But I would be very wary of turning NCs into an endless vicious circle - eg, 1 NC not closed, then raising new NC to report previous one not closed, etc. Why not simply escalate and action this one? Also, sounds distinctly like you need some better guidelines.
