Nonconformance on document control - Unapproved document on production server
Dr RA
Hi All
A document that has not been approved was available in the production drive. The production has not used the document, but had access to the unapproved document. This manufacturing requires validation due to formulation change and has not been validated and approved yet. Production has enquired about this unapproved document and if this can be used as the current version(approved) has been removed from manufacturing access and also attached this document(unapproved) in electronic format..
Due to recent developments on electronic management system, the SOP does not mention of the electronic access to the documents and at the same time does not mention of the copies only available as hard copy. It clearly mentions the current version of documents will be approved and distributed and a master copy will be retained.
A NC has been raised on clause 4.
Do you agree this a non conformance - if yes under what basis?
Re: Non conformance on document control
Hi All
Yes I agree :yes:
If I say per the ISO13485, then the clause 4.2.3 a) To review and approve documents for adequacy prior to issue is violated.
4.2.3 d) To ensure that relevant version of applicable documents are available at the point of use. is also violated
Dr RA
Thanks Somasekhar,
Will argument that production has not manufactured a batch using this form waive this clauses?
Also the SOP not mentioning availability of the documents in electronic format with controlled access make the NC invalid?
Thanks again
RA
Thanks Somasekhar,
Thanks again
RA
Consequences of the NC can only add to the NC criticality rating.
Flaws within your setup can be part of your RC analysis.
The NC stays
P
PaulJSmith
If you caught it internally and not by some external auditor, I would worry less about what standard clause may have been violated, and worry more about how your own internal procedures may have failed. That's the real issue here. Somehow, an unapproved document made it into your approved documents. Whether or not it was used is almost irrelevant. This is most definitely worthy of a Non-Conformance. Find the flaw in your approval process and fix that.
D Missing Document in a TS 16949 Audit - Nonconformance IATF 16949 - Automotive Quality Systems Standard 5
M ISO 9001:2000 Audit Nonconformance - "Failure to have the document ISO 19011" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C NCR (Nonconformance System) Software Nonconformance and Corrective Action 7
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
E When to generate a nonconformance report ISO 13485:2016 - Medical Device Quality Management Systems 6
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
qualprod Ineffective follow up of people performance - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Timing allowed by IATF to close a Remote Site Minor Nonconformance IATF 16949 - Automotive Quality Systems Standard 2
R Visually impacting graphics for Nonconformance status metrics for Management Report Nonconformance and Corrective Action 5
J ISO 13485 Audit Nonconformance written against 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 25
PastorBee13 IATF 16949 Audit Nonconformance Responses per 5.1.1.2 - Format IATF 16949 - Automotive Quality Systems Standard 11
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
S Nonconformance to a Note in ISO13485 clause 6.2 Human Resources Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 13
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
A Where are the rules for when a repeat minor nonconformance becomes a major? IATF 16949 - Automotive Quality Systems Standard 36
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
Ajit Basrur Are inputs to the nonconformance process required to be identified? Nonconformance and Corrective Action 21
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
qualprod Should I initiate CAPA for a nonconformance not recorded? Nonconformance and Corrective Action 25
K Nonconformance on training - Not following own processes (IATF 16949) Internal Auditing 14
J Audit opportunity for improvement raised to nonconformance months after the audit General Auditing Discussions 7
GStough Pushback on a Nonconformance Found in a Supplier Audit General Auditing Discussions 22
K NCR or CA? We're taking any issue we have and saying its a nonconformance Nonconformance and Corrective Action 11
GStough Nonconformance Found Outside the Audit Scope - Supplier Audit General Auditing Discussions 16
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Nonconformance Raw Material Treatment in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
N Laboratory Audit Nonconformance - Maintenance of Standards ISO 17025 related Discussions 10
K Internal Auditing a previous Nonconformance? Internal Auditing 19
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 4
P Ratio of Supplier with a nonconformance vs. Supplier without a nonconfomance Supplier Quality Assurance and other Supplier Issues 10
W Nonconformance Recurrence Response Help General Auditing Discussions 4
dubrizo If Quality Objectives are not known to employees, is it a Nonconformance? General Auditing Discussions 7
xfngrs Automotive Industry Nonconformance Database wanted - Preferably SharePoint based Quality Assurance and Compliance Software Tools and Solutions 5
Gman2 Processes sharing the same nonconformance during an audit General Auditing Discussions 13
