Informational Nonconformances and Defects - Operator Error, System Error, or both?
In the event of a NC or defect, what/who is at fault?
  • "The system" is always at fault.
    Votes: 8 13.3%
  • "The system" is at fault ~ 90-96% of the time.
    Votes: 19 31.7%
  • "The system ~ 80%", operator ~ 20%.
    Votes: 21 35.0%
  • It's about even.
    Votes: 12 20.0%
  • Total voters
    60
  • Poll closed .
bobdoering
Stop X-bar/R Madness!!
The way I look at it is I do not blame the operator if the defect was caused by something that was not considered in the system. But, if the system specified that the operator is responsible for a task, the training has been done, and the operator does not perform that task, then you have operator error.
Now, as far as corrective action, you may find the risk or frequency of that error may justify a change in the system to further limit operator dependency. But a100% operator independent process just means machines will cause the problem or the people responsible for determining and performing the PM will be the next problem. A 100% operator independent process also means less employment (even lights out plants a few folks hanging around). But, that is an argument for the social responsibility standards people to address.
Matt Swartwood
I typically practice the Apollo approach to root cause analysis. I want to see due diligence to address the system where it all possible and operator error is the very last resort. We have our corrective actions set up where the only way you can use operator error as the root cause is if all system controls are in place to prevent the defect and the operator blatantly disregards procedure or bypasses current failsafes.
I'm not saying our way is the right way or the only way, but we have been very successful with it so far...
I'm not sure of your point.
are you saying that any error proofing we do won't reduce the defect rate because the cause will just shift from a human to the error proofing device to break down? The only way we don't reduce the defect rate is if the error proofing device is just as prone to 'break down' as the operator was.
Or are you saying that any reduction in defect rate isn't worth the effort because we can never achieve zero?
I always pursue reduction in defects regardless of the fact that I will never achieve perfection - I've gotten nicely close to it at times. (and NO, I don't go after a .0001% trivial effect defect rate when I have a 5% defect rate that is very upsetting the customer. occuring - I use common business sense to prioritize the work.
bobdoering
Let me clarify. Operators - even when well trained - are capable of making mistakes - whether accidental, whether changing the process on their own thinking they are "helping', via fatigue (either from work duties or what they did outside of work) or simple carelessness. They are responsible for their work.
So, to eliminate these root causes, you would have to eliminate the operator. That is possible to do in some scenarios. It may be more costly than using the operator (to the point of being unprofitable), but possible nonetheless.
If may require errorproofing - such as poke-a-yoked automated systems. But, even as the staunchest proponents of poke-a-yokes have found, you need to constantly verify them, because they wear out. So, human error has been replaced with mechanical error, to be supervised by a unfailing PM system. Until such time, though, you can take credit for incredibly low failure rates - and employment (but who is counting that?)
Are you saying that any error proofing we do won't reduce the defect rate because the cause will just shift from a human to the error proofing device to break down?
I am saying it will not eliminate defects for that reason. Will it reduce it? Perhaps - perhaps not.
It is not the only way. One other way is that the error proofing device 'breaks down' because people expect it to work, and it starts to fail. It can make defects for quite a long time. More than a human? Maybe.
No I am not. Have it 24/7.
I always pursue reduction in defects regardless of the fact that I will never achieve perfection - I've gotten nicely close to it at times. (and NO, I don't go after a .0001% trivial effect defect rate when I have a 5% defect rate that is very upsetting the customer. occurring - I use common business sense to prioritize the work.
It is a great goal. And if you can eliminate humans in the process - and their inherent human error - and it makes common business sense, then I am sure it will happen. However, it can be divergent economically.
bobbelden
What if an employee who is packaging parts knowingly raids the MRB cage and ships 5 bad parts to the Customer? The customer has since found the parts and is requesting corrective action. What would be the cause and corrective action?
Stijloor
Without having any knowledge and details about the context in which this error occurred, I would say that rarely people "willfully" do these things.
My first concern would be: "did someone pressure this person to complete a shipment to get stuff out the door?"
Difficult to answer without all the specific details.
Stijloor.
bobdoering
That's the kind of thing that makes customers demand locked MRB cabinets of everybody...even when it is not an issue for some (like us). It is maddening...
What is the cause? Somewhere there is a perceived pressure (true or not) that making shipment is more important than anything else. Customers can create such pressures - in spite of their proclaimed desire for good product. JIT will really paint you in a corner. Not sure what this specific case is, though.
Mike S.
Happy to be Alive
In that case, I don’t know enough to say.
But I have had an AS9100 certified firm, a subsidiary of a HUGE corporation, admit verbally (after we caught bad parts at our receiving dock) to knowingly shipping me rejected parts because their company’s highest officer told them to do it. On the official corrective action report it was reported as a “mistake” resulting from a “desire to help” support our company. :rolleyes: I have a different word for it. :frust:
Don’t think it doesn’t happen – probably more than you know. If it looks like a duck, and quacks like a duck…open yourself up to the possibility that you just might have a duck on your hands, even if you don’t want to believe it.
and this is why we must have all of the facts. In this case, dropping this supplier if at all possible is worth consideration. YOU are ultimately responsible for your supplier's quality...who knows what this guy is having people do. Depending on your ultimate Customer for this part you might consider bringing them in if you want to simple 'fix' the supplier. AS9100 Customers are pretty intolerant of this.
The question comes from the supplier's point of view. As others have suggested, the motivation for taking known bad parts is important to know. It seems to me that this was either an obsessive-compulsive person who couldn't stand to see a partial box, or someone who had a gun at his head.
M Software "Nonconformances" ISO 13485:2016 - Medical Device Quality Management Systems 25
J Average number of Nonconformances during internal quality audit for Medical Device Manufacturers Internal Auditing 3
GStough Audit Nonconformances (?) for Suppliers Not Registered to ISO and No Supplier Quality Agreement Exists General Auditing Discussions 24
C Training for Manufacturing Nonconformances and CAPS with focus on the wording Nonconformance and Corrective Action 4
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 27
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 22
R Extension of product nonconformances - Construction project Nonconformance and Corrective Action 7
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M User Errors and Product Nonconformances Nonconformance and Corrective Action 22
K Notified Body - Minor Nonconformances - They have withheld all certificates General Auditing Discussions 3
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
N Nonconformances in the Construction Industry Nonconformance and Corrective Action 6
T Perishable Tooling Supplier - Nonconformances and Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Internal Audit Nonconformances - Your opinion? Internal Auditing 8
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
L Insurance to cover for nonconformances ? Misc. Quality Assurance and Business Systems Related Topics 2
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Second Registrar Visit to Confirm Major Nonconformances Fixed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Definitions for Minor & Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F Response to ISO 13485 Audit Minor Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 6
M Seven Document Review Nonconformances Document Control Systems, Procedures, Forms and Templates 9
J KPI for time to close NCs (Nonconformances) Quality Manager and Management Related Issues 17
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
J Question about GM special requirement - Open Major Nonconformances IATF 16949 - Automotive Quality Systems Standard 2
K CAPA Training for Process Nonconformances Nonconformance and Corrective Action 2
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
Fender1 Nonconformances that do not require Corrective Action Nonconformance and Corrective Action 21
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
T NonConformances as a Tool to Measure Employee Performance Nonconformance and Corrective Action 21
A Surveillance Audit Result - Multiple Audit Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Suspension of ISO 9001 Certificate - Major Nonconformances Identified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
L Non Conformance Register (aka Tracking Nonconformances and Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J How many Major Nonconformances could let the Audit be Terminated? General Auditing Discussions 9
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 14001 Surveillance Audit Nonconformances ISO 14001:2015 Specific Discussions 6
J Corrective Action Timeframe for Internal Nonconformances Nonconformance and Corrective Action 14
R Is it useful to adapt PFMEA's with nonconformances? FMEA and Control Plans 4
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
C System Root Cause and CA (Corrective Action) for ISO 13485 Audit Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 3
M Can a KPI (Key Process Indicator) be created against Nonconformances? Nonconformance and Corrective Action 8
J Certification Body follow up on clearing Audit Nonconformances Registrars and Notified Bodies 4
M NCR and Cost Collection - Capturing nonconformances in the field Nonconformance and Corrective Action 1
Q CTC (Critical to Customer) vs. CTQs (Critical to Quality) Nonconformances Nonconformance and Corrective Action 6
