Nonconformity on managing documents for Electric Arc Furnace
Ettore
During the last Audit, the thirth parth Auditor has wrote down a "Non conformity" on point 4.2.3 of . ISO 9001:2000.
The object of "non conformity" was the Technical Specifications with the parameters used for the set-up of one of ours furnaces (EAF).
The specifications are managed by furnace managers that usually edit the specifications in a sql database ( they don't use papers).
After that from sql sever (liv III) the parameters are sended for every set- up (one specification for every kind of steel) to automation of the furnace (LIV II).
(if anybody is interested on here there is an exercitation with use of some of this specifications: http ://www .steeluniversity. org/content/html/eng/eaf-sim.asp - DEAD (404) LINK DECOUPLED)
The database takes note of the name of the manager that has changed the specifications but not of the scope of the changes, and they don’t use have registrations of obsolete specifications because in the last 20 years the managers haven’t had the necessity to have this kind of registrations.
Anyway the auditor said that isn’t easy understand:
who is tath has approved the last edition of the specifications,
the identifications of every specifications (that are called with the name of the steel),
the traceability of modifications.
Who is on the right side, the Auditor or the managers?
This kind of documents (technical) have to be controlled more than ours engineers are doing?
Ps. In the last 20 year the auditors (internal, second or tirth part ) have not seen this non conformity
:bigwave:
H
Houcka
While I can understand the frustration behind being told that current operating practices have been wrong for the past twenty years, that doesn't excuse the company from correcting a nonconformity now that it has been brought to attention. ISO Clause 4.2.3 Control of Documents specifically says that changes to a document must be identified and that obsolete documents must be prevented from unintended use.
Ettore
While I can understand the frustration behind being told that current operating practices have been wrong for the past twenty years.
I'm sorry but the auditor didn't said that current operating practices have been wrong but issued a NCR about the controls of practices
changes to a document must be identified .
The change are identifyed, but isn't necessary take note of why is changed
What obsolete documents if they haven't ?
Bye
Have a good night
SteelMaiden
Your database should have a date/time stamp and record the person making the changes, right? So that is your documentation, your control should be in user priveleges, and there isn't a way for obsolete documents to be used, because your automation systems should only be using the current database. Is your auditor familiar with steelmaking and automation? It appears you are doing basically what every EAF operation is doing.
Ettore
The Auditors should be familiary.
Anyway I have asked to the managers of EAF to write like correction for NCR a simple matrix flow chart that will explain exactly what are doing for control this kinds of documents, meanwile i wrote down quality system procedures that explaine the responsability for control the technical documentation whit a matrix that for every kind of document explain who have the responsaibility for control the document that could change after changiging of customers engeeneeng standards (as required by ISO/TS 16949 point 4.2) . The matrix recall also if there are other documents like the new flow that EAF manager have planned to do.
Bye
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K My question is, what/when is a nonconformity? Therefore what requires an NCR? Nonconformance and Corrective Action 9
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
M Measurement Unit Rounding Nonconformity - Notified Body Audit Registrars and Notified Bodies 6
qualprod Write down same nonconformity in several processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
L Nonconformity's risk is too low, so don't report it? General Auditing Discussions 25
K Nonconforming Output vs. Nonconformity vs. Nonconforming Product Nonconformance and Corrective Action 2
J Technical Documentation Review: Responding to a Nonconformity ISO 13485:2016 - Medical Device Quality Management Systems 14
J ISO 9001:2015 Clause10.2 Nonconformity and Corrective Action - Deal with Consequences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q 8.3 - Control of nonconformity product or material/part? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
S Is not keeping inspection record an ISO 9001 nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Corrective Action for Nonconformity in ISO/TS 16949 Recertification Audit IATF 16949 - Automotive Quality Systems Standard 2
H Internal Audit Major Nonconformity or Not? Quality Manager and Management Related Issues 24
L Audit Nonconformity for FMEA - Transit, Warehousing and Shipping ISO 13485:2016 - Medical Device Quality Management Systems 4
H API 8TH EDITION Nonconformity Help Oil and Gas Industry Standards and Regulations 2
G Nonconformity Reporting at Installation Sites Service Industry Specific Topics 8
M Definition Process Nonconformity - Definition and examples - AS1900 clause 8.2.3 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
S Definition Deviation and Nonconformity - What is difference? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J Does this constitute Nonconformity? Water Testing General Measurement Device and Calibration Topics 6
S Minor Nonconformity for Lack of Job Descriptions in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 62
A Supplier Nonconformity - Internal Auditor Statement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Audit Nonconformity on Defining 'Outsourced' Infrastructure Maintenance Quality Manager and Management Related Issues 21
D What should the QMS Auditor do if a Major Nonconformity is found during an Audit? Internal Auditing 11
U Customer Audit Nonconformity on Internal Audit Program done by Corporate QA General Auditing Discussions 19
B Does the recording of wrong entries amount to a nonconformity? Records and Data - Quality, Legal and Other Evidence 7
Q Waiting for Audits to raise Nonconformity Reports? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Is it a nonconformity if an auditor saw ant trails on wall inside the plant? Food Safety - ISO 22000, HACCP (21 CFR 120) 22
K Is there a "maximum time limit" for nonconformity to fix? Internal Auditing 11
K Observation - Potential Nonconformity - How to address this Audit Finding? General Auditing Discussions 9
K How can you relate this scenario to a Nonconformity? Occupational Health & Safety Management Standards 4
K Are Withdrawal and Recall a kind of Control of Nonconformity? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
P Process FMEA with the effect "brakes are broken" - Is it nonconformity? IATF 16949 - Automotive Quality Systems Standard 7
N Is a mass resignation and impending strike a form of nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
N Definition Nonconformity vs. Potential Nonconformity - Difference? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
L Legal Requirements - Nonconformity - TS 16949 Clause 4.1 IATF 16949 - Automotive Quality Systems Standard 7
P Two Questions about Nonconformity - Number of Minor Nonconformities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Procedure for "Controlling Nonconformity" for a software company Document Control Systems, Procedures, Forms and Templates 2
P Internal Audit NC (Nonconformance) is not closed - Is it a nonconformity? IATF 16949 - Automotive Quality Systems Standard 11
T Nonconformity Records - Nonconformity vs. Scrap - 8.3 Requirements Records and Data - Quality, Legal and Other Evidence 14
N How to handle a nonconformity for something we'd like to remove Nonconformance and Corrective Action 5
H Definition Major Nonconformity vs. Minor Nonconformity - Definition and Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
B Help with writing a Control of Nonconformity Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
E Do you consider this a Top Management Nonconformity? Nonconformance and Corrective Action 19
Q Work Environment - Which of the following is to be addressed as nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
