Noob question regarding sample size
Hello everyone,
I am a newbie here and hoping someone can point me a direction regarding my questions.
I am a RA for a medical device manufacturer located in SEA. I am trying to figure out plans for several 510k submission, and not sure what to do with sample size. We have some consumables like sterile catheters, and some sterile media for lab. For local authorities, we use confidence/reliability based on RPN to decide sample size, it is usually 29 or 59 and we do 10 * 3lots or 20 * 3lots.
I am wondering if the same could be applied for 510ks, and if there is other ways to calculate the sample size. Some keywords and brief explanation would be much appreciated!
Thank you!
Steve Prevette
Deming Disciple
There are lots of ways to calculate sample sizes and sample plans. The 29 and 59 numbers are very common and reflect the sizes for c=0 plans. That is I sample 59 items and if I get zero defective, I am 95% "confident" (or "sure") that no more than 5% of the population are defective. You see 59 called out a lot, especially by the EPA. If I sample 29 items and I get zero defective, I am 95% confident that no more than 10% of the population are defective.
A common document used for sample plans was MIL-STD 105E, which was free. But it got canceled and rolled into ANSI/ASQ Z1.4 which you have to pay for to get a copy ($159).
I am no expert on 510k so will have to pass on that part of the question. But yes, there are lots of various sampling plans out there, all based around balancing false negatives and false positives (like the "problems" with the COVID tests). You end up looking at OC curves to judge how good a plan is, and what risks it represents. Whole textbooks are out there on the subject,
ASQ has this intro about acceptance sampling - ANSI/ASQ Z1.4 & Z1.9 Sampling Plan Standards for Quality Control | ASQ
Thank you for the tips! It is very helpful!
rayhope
Dear Steve,
Please suggest any literature which is freely available for C=0 sampling plan. above discussion is very helpful. Thanks
Steve Prevette
Deming Disciple
I ran the 29 and 59 numbers in Excel using Binomdist. If you wanted to know - how many do I need to sample to be 95% confident that no more than 5% are defective - you are solving for the number of samples:
=BINOMDIST(0,59,0.05,TRUE) gives you the result of 0.048 which is just a hair under the 5%. If you put in 60 instead of 59, you get a result higher than 59. Also you can calculate that from (1-0.05)^59. Binomdist does assume a very large population size, you can refine the result using the hypergeometric. Bottom line for a sample of 59 - if there is a 5% defect rate, I have a 95% chance of detecting one or more failed items. Pretty good assurance that we will detect it in just this one sample.
Zero Acceptance Number Sampling Plans, Fifth Edition | ASQ is an example result if you put "c=0 sampling plan" into Google.
IMPORTANT - there is a downside to c=0. Yes, it gives you the smallest possible sample size BUT is more susceptible to false detects than the MIL STD plans. For example, if the actual defect rate is 2% (not 5%), I have a 70% chance of getting a defective item in a sample of 59. By the way, this is how you develop the Operating Characteristic curve for an acceptance test. Also, MIL STD is based upon accumulating results across many sample runs.
As an alternative, I could choose to construct a c=2 plan (Accept on zero one or two defects). To get the 95% confident that no more than 5% are defective, I go with a sample size of 124. Double the sample size. BUT if my "true" defect rate was 2%, the chance of getting 3 or more defects drops to =1-BINOMDIST(2,124,0.02,TRUE) or 45%. Still pretty high, but better than 70% from the 59 sample size.
As you can see from this exercise, that is why go no-go sampling (versus inspection for variables) gives such high sample sizes. And when we talk detecting 1% or less defect rates, it requires very large sample sizes.
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 5
H Noob Frequency Distribution and establishing achievable goals Using Minitab Software 2
J Some noob ISO 14001 Questions ISO 14001:2015 Specific Discussions 9
sonflowerinwales Quick question M3 screw plug gauge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
B FDA regulations medical device prescription fulfillment DME question US Medical Device Regulations 0
M An interesting question about import company Other Medical Device Regulations World-Wide 5
Sam.F Question about training Training - Internal, External, Online and Distance Learning 17
B Labeling question about different manufacturers on a single label Manufacturing and Related Processes 4
J Question regarding classification of custom made device EU Medical Device Regulations 5
Sam.F Question about granite surface plates out of spec AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Ed Panek MDR question - Meaning of Stability CE Marking (Conformité Européene) / CB Scheme 6
B GD&T Question, True Position Confusion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Initial Importer question Other US Medical Device Regulations 1
Ed Panek Calibration question Manufacturing and Related Processes 4
M Class Exempt Medical Device Recall Question US Food and Drug Administration (FDA) 3
sonflowerinwales Metric or Imperial; that is the question... After Work and Weekend Discussion Topics 6
M Can someone help me with this CMM programming question? Manufacturing and Related Processes 2
A A strange question about predicate device selected in 510(k) submission Medical Device and FDA Regulations and Standards News 8
S Question regarding AQL - ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
JoeRandom11 Question about Customer Supplied Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M ISO 13485: 2016 Lot numbering question ISO 13485:2016 - Medical Device Quality Management Systems 4
S Nadcap - Heat Treatment Proof of Verification question for Digital results AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
JoeRandom11 Question of Calibration Cycles AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Software Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 10
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
C Document Identification Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Question regarding PCR workstation Fume Hood upon first use ISO 13485:2016 - Medical Device Quality Management Systems 0
Moncia ISO 9001 calibration question please ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Quality Specialist Quick question on the sequence of ISO 17025 external audits ISO 17025 related Discussions 14
D ISO 13485--Question regarding performing calibrations in house. ISO 13485:2016 - Medical Device Quality Management Systems 13
S Document numbering question? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Has the facility been inspected? question in Certificate to Foreign Government application Other US Medical Device Regulations 0
M ESTAR 510(k) submission question Medical Device and FDA Regulations and Standards News 0
J Question on clause 5.2.2 IEC 62304 - Medical Device Software Life Cycle Processes 2
Ed Panek ISO 15223 Question EU Medical Device Regulations 2
R Question: Cg/Cgk formula Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Quick question on responsible person's experience requirements UK Medical Device Regulations 3
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
3 Scope question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L Question regarding "Customer Property" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
K 510(k) Manufacturer question (private label and manufacture under another persons 510(k)) US Food and Drug Administration (FDA) 1
M Question About Rolled Throughput Yield Manufacturing and Related Processes 5
M Quick Gage R&R Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Question: Best alternatives to audits for ensuring compliance Quality Tools, Improvement and Analysis 5
Ed Panek Question from 13485 Auditor ISO 13485:2016 - Medical Device Quality Management Systems 2
C Question on KAFO (Knee Ankle Foot Orthosis device) classification CE Marking (Conformité Européene) / CB Scheme 0
T BMW GS 93010-2 Question Various Other Specifications, Standards, and related Requirements 1
S FDA 510(K) submission question US Food and Drug Administration (FDA) 4
Ron Rompen Question regarding CMM probe damage General Measurement Device and Calibration Topics 4
