Normal Condition Hazards in Risk Analysis
Hi there, is there a document uses to record the "Normal Condition Hazards' required by ISO 13485, similar to the ones used for FMEA? Would it be sufficient to use our existing FMEA to document the NCH?
indubioush
I think the OP means ISO 14971.
There are many different document types and risk analysis methods that can be used to demonstrate compliance to ISO 14971. You can document risks associated with normal use in any way you want as long as you are compliant. Note that ISO 14971 does not require the use of FMEA, it only lists it as a possible technique that supports risk analysis.
silentmonkey
Normal condition hazards can be covered by a Hazards Analysis. An FMEA looks at hazards from a failure modes perspective i.e. What could fail and what hazards and harm could result from the failure?
Hazards Analysis involves thinking about hazards in general and determining where they might be in your product. This would include both normal and fault condition risks.
FMEA = Part/System > Function > Failure Modes > Effects/Hazards > Risk Estimation/Evaluation > Risk Control
HA = Hazard > Hazardous situation > Risk Estimation/Evaluation > Risk Control
U Nonnormal vs. Normal Operating Condition Aspect for each Environmental Aspect? Miscellaneous Environmental Standards and EMS Related Discussions 4
gohyl Printed Circuit Board - Unusual sighting between pads, is it normal. Manufacturing and Related Processes 19
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
adir88 Tools for Normal and Fault Conditions ISO 14971 - Medical Device Risk Management 9
qualprod What is the Normal Flow in an ERP for Manufacturing? Manufacturing and Related Processes 0
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Non Normal Data in a historically normal process Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
J Is a stable process also normal at the same time? Manufacturing and Related Processes 7
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
R Non-normal Distribution Selection where the system is constantly being corrected Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Is My AS9100 certification Auditor Normal? Registrars and Notified Bodies 9
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
D Interpreting Normal vs Weibull Capabilities Capability, Accuracy and Stability - Processes, Machines, etc. 4
P Should Data be Normal before Computing Baselines? Statistical Analysis Tools, Techniques and SPC 4
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Is normal for FORD EU ask for the PSW every year APQP and PPAP 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M t-test with Non Normal Data Statistical Analysis Tools, Techniques and SPC 16
T Normal Distribution Test for Cpk (Minitab) Six Sigma 6
U Theory and Practice Behind Expecting a Distribution for my Data (specially the normal Statistical Analysis Tools, Techniques and SPC 48
K Computing Cpk with out determining if my data is normal Capability, Accuracy and Stability - Processes, Machines, etc. 7
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Handling Normal Capacitor Production Fallout AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
M Is it possible to get Natural Tolerance (Tn) with Non Normal Distribution? Statistical Analysis Tools, Techniques and SPC 9
B Is this Data a Normal Distribution? Statistical Analysis Tools, Techniques and SPC 10
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
R Drawing a Normal Plot of the Effects for Multilevel Factorial Design Using Minitab Software 3
B Test of Means or Medians for Non Normal Populations? Using Minitab Software 6
B Is it normal for a procedure to begin with a conditional directive? (if statement) Document Control Systems, Procedures, Forms and Templates 30
S Relationship between Normal Distribution and AQL AQL - Acceptable Quality Level 13
R Transforming or not Transforming - Dealing with Non-Normal Data Statistical Analysis Tools, Techniques and SPC 10
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
optomist1 Non-Normal Data F test and T test Capability, Accuracy and Stability - Processes, Machines, etc. 19
2 Medical Device Hazard Risks - Normal Use Risks vs. Faulty Use Risks ISO 14971 - Medical Device Risk Management 4
P Approved Suppliers - ISO 13485 Normal Supplier Qualification Process Requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
S "Normal" vs. "Between/Within" Capability Analysis Capability, Accuracy and Stability - Processes, Machines, etc. 2
