"Normal" vs. "Between/Within" Capability Analysis
steph4444
Dear all,
For my first post, I would like to address the issue of "normal" versus "between/within" capability study.
It all boils down to a) the presence of subgroups and b) the calculation of standard deviation
In an aeronautical context, I need to assess a process performance based on sample batches (3/4-samples) extracted from structural parts, hence I consider each part as coming from a different process stream. I also consider each sample batch as a subgroup.
The current method uses the minimum of 2 indices, PpK(ind) based on SD of individual values, and PpK(avg) based on SD of averages of each subgroup, to determine performance.
Here are my questions :
Does PpK(avg) make sense ? (SD calculated straightforwardly with (n-1))
Shouldn't one use "between/within" capability study ? (variation between subgroups is important)
How do you justify this ? And more importantly, how do you conduct it ? I now have several SD : "within", "between", and "between/within"
I was thinking of computing PpKs using "between/within" instead of "overall" SD, which is twice bigger, and also "between" SD to show variability in-between process streams...
I cannot find much documentation on the web on "between/within capability study", but you folks seem to have all the savvy needed, so please feel free to drop your 2 cents worth, Ill very much appreciate it.
bobdoering
Stop X-bar/R Madness!!
Re: Between/Within Capability analysis
It the case of multiple streams, my preference has always been to provide capability of each stream. Typically it is multi-modal enough, but combining them makes them so multi-modal that normality is totally out of the question and the statistics of such multi-modal distributions does not represent anything meaningful.
steph4444
Maybe I am misguided in the use of the term "process stream". I meant that two produced parts are released within a rather large time-frame (week/month). Hence common causes could be greater and also, process may seem to vary since parts may not be produced with the exact same machine tools, operator etc...
But essentially it can be considered as the same process.
Normality is verified on both individual values and subgroup averages...
D Normal vs. When a Between / Within Capability analysis should be used? Statistical Analysis Tools, Techniques and SPC 12
S Relationship between Normal Distribution and AQL AQL - Acceptable Quality Level 13
M Area Under Normal Curve between the Scores for z=2.20 and z=0.85 Statistical Analysis Tools, Techniques and SPC 5
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
adir88 Tools for Normal and Fault Conditions ISO 14971 - Medical Device Risk Management 9
qualprod What is the Normal Flow in an ERP for Manufacturing? Manufacturing and Related Processes 0
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Non Normal Data in a historically normal process Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
J Is a stable process also normal at the same time? Manufacturing and Related Processes 7
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
R Non-normal Distribution Selection where the system is constantly being corrected Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Is My AS9100 certification Auditor Normal? Registrars and Notified Bodies 9
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
D Interpreting Normal vs Weibull Capabilities Capability, Accuracy and Stability - Processes, Machines, etc. 4
P Should Data be Normal before Computing Baselines? Statistical Analysis Tools, Techniques and SPC 4
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Is normal for FORD EU ask for the PSW every year APQP and PPAP 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M t-test with Non Normal Data Statistical Analysis Tools, Techniques and SPC 16
T Normal Distribution Test for Cpk (Minitab) Six Sigma 6
U Theory and Practice Behind Expecting a Distribution for my Data (specially the normal Statistical Analysis Tools, Techniques and SPC 48
K Computing Cpk with out determining if my data is normal Capability, Accuracy and Stability - Processes, Machines, etc. 7
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Handling Normal Capacitor Production Fallout AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
M Is it possible to get Natural Tolerance (Tn) with Non Normal Distribution? Statistical Analysis Tools, Techniques and SPC 9
B Is this Data a Normal Distribution? Statistical Analysis Tools, Techniques and SPC 10
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
R Drawing a Normal Plot of the Effects for Multilevel Factorial Design Using Minitab Software 3
B Test of Means or Medians for Non Normal Populations? Using Minitab Software 6
B Is it normal for a procedure to begin with a conditional directive? (if statement) Document Control Systems, Procedures, Forms and Templates 30
R Transforming or not Transforming - Dealing with Non-Normal Data Statistical Analysis Tools, Techniques and SPC 10
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
optomist1 Non-Normal Data F test and T test Capability, Accuracy and Stability - Processes, Machines, etc. 19
2 Medical Device Hazard Risks - Normal Use Risks vs. Faulty Use Risks ISO 14971 - Medical Device Risk Management 4
P Approved Suppliers - ISO 13485 Normal Supplier Qualification Process Requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
S Which Normality Test more acceptable to FDA; Also, Non-Normal Threshold? Qualification and Validation (including 21 CFR Part 11) 5
