Re: Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our process
again I'm not certain of what is troubling you with this situation?
simply use 100 in the denominator for the second operation.
calculate FPY for each station/operation as the number of units that passed the operation without requiring rework (regardless of where or when the rework is performed) divided by the number units processed at the station/operation.
upliftpro brings up some old headache of mine related to RTY calculations.
There are cases when RTY for an entire process (FTY step 1 * FTY step 2 ...* FTY step n) can be confusing. I used to try to interpret the metric from a probability point of view.
FTY for one station can be considered the probability of passing the station. That is rather intuitive. So if you start with 100 units and 98 pass FTY and probability to pass the station is 98%. For step 2, 98 units are tested and 95 pass on first try gives about 97% probability. Third step, 95 tested and 91 pass, 95.8%. In this case the RTY is also the probability for one unit to pass all three steps which is 91/100 or the product of the above three FTY´s.
However, I have worked in businesses where the FTY yield is multiplied to RTY and measured in discrete time intervalls of days/weeks just because it is convenient to follow up and compare over time. But the measurements where hard to interpret since the manufacturing site ran 24h a day the units may go into the first steps before midnight and into the last steps on the next day and also sometimes they went into storage for several days in the middle of the process.
This means that the number of tested units in each step may vary and sometimes fewer units where tested in early steps compared to later ones. Also it was not necessarily the same units that where compared when the FTY of each step´s where multiplied to the RTY. This made the RTY comparison to the probability of passing test impossible to do, at least for me. I remember people insisting on measuring the RTY even though the volumes of the test steps where totally inconsistent with each other and nobody could say for certain if the same unit in step 1 was also put into the last step on the same day :mg:
RTY can be such a mess. Anyone else have any interesting observations or experiences with strange RTY measurements?
