Not having Training Records for Documentation Changes - ISO 13485 Clause 4.2.3
I
ISO tired
Our auditor wrote us a nonconformance for not have training documentation for every time time there is a document change. I cannot find the requirment for this. I thought that if the department heads/supervisors was signing the change document this would satisfy the requirement.
arios
Re: Iso 13485 4.2.3
Revised documents can introduce additional training needs. There are different types of changes which rank form minor typographical errors (on which training may not be needed), up to significant method changes (which could require training)
Document approval is occasionally used to demonstrate awareness, however the individuals who sign a change approval are not necessarily the ones who need to be trained, and this method alone may not be as effective as a more formal training. E.g. a supervisor may be approving a change, but his or her workers may not be aware of what the change was and the impact.
It would be beneficial to check how your training procedure explains that training needs will be identified.
Re: Iso 13485 4.2.3
OMG!:mg:
I'm guessing you don't have this in any procedure...do you? I have worked in a place where someone thought it was a requirement - turns out, she was 'making work' to keep from being terminated!
It's not a requirement of the standard, that's for sure, so your auditor sounds like they're over reaching, here. Time for a new one!
MIREGMGR
Re: Iso 13485 4.2.3
On the other hand, as Arios notes, it makes sense and clearly strengthens your QMS and your company's operations.
So what's your goal: maintaining your certificate with as little work as possible, or...?
Re: Not have training documentation for documentation changes - ISO 13485 Clause 4.2
Why is it that people insist on 'training' when a document changes? I don't understand. It has nothing to do with a 'better system' or anything like that. Training is only necessary when competency has not been demonstrated.
I'd agree that making some awareness of the changes is an important part of this change to a document, but not, repeat NOT, training! If you do, you'll soon bury yourself in a pile of records of, basically, nothing useful!
Auditors who ask for training after revisions to work instructions etc. are dinosaurs and deserve to be shown the door...
arios
On the context of the Medical device sector, the ISO/TIR 14969 can be used as the guideline for the application of ISO 13485. This guideline document refers to "...follow-up or refresher training, as needed and planned"
On the context of the FDA's 21 CFR 820.40 we could also refer to the following requirement:
"Approved changes shall be communicated to the appropriate personnel in a timely manner"
So, I would not say this is necessarily a repeat training, rather it is keeping the people effectively aware of the relevant changes to their processes. The QSR also refers to: "ensure that all personnel are trained to adequately perform their assigned responsibilities". If the responsibilities change, then training is appropriate. This is why in my opinion this system needs to be robust. In the medical device sector the worst enemy could be one self, I mean, one self in case of un-compliance could have a person's life at risk, so I think it is worth the effort to apply training on prevention of mistakes.
I read and understand. I just can't get to where you are making a case, from here...
If the auditor found some lack of awareness, some problems etc. then I'd agree, but it says 'every time there is a document change'. This is unqualified by a statement of associated risk, etc.
DrM2u
:agree1:I second Andy's last two statement!:agree1:
There are no grounds for a finding unless you state the requirement for the specified training in an internal procedure. Challenge the auditor to quote where the requirement is stated and/or to provide evidence that failing to meet his 'expectation' has a negative impact on processes and/or customer.
Jason PCSwitches
As already stated, unless you have this requirement in your procedures, it's not a requirement. That is why documents "shall be controlled, approved, reviewed, updated" etc.
Your document control procedures should ensure all changes are circulated to relevant departments. If deemed necessary (by you) then training may be appropriate. Listen to Andy...sound advise. :agree1:
somashekar
Re: Not having training documentation for documentation changes - ISO 13485 Clause 4
Yes, while any document change gets formalized we have a system to review if the change warrants a new training. If it is felt necessary the training activity about the new procedure is provided to the relevant people at the same time as the release of the new procedure and its training records follow. As we have experienced, most of the changes has not called for a training need.
Please see how you have addressed your training procedure.
U QS 9000 Audit - Trainer of internal auditors not having formal training QS-9000 - American Automotive Manufacturers Standard 6
NDesouza No Quality Professional vs Having a Quality Professional Benchmarking 24
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
O Inspecting paint and having workable standards in the supply chain Supplier Quality Assurance and other Supplier Issues 1
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
N GDP - Having to provide a reason when writing N/A? ISO 13485:2016 - Medical Device Quality Management Systems 1
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
D Having got ISO 13485:2016 are you dropping ISO 9001? ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Partial non applicability of ISO 9001 Cl. 7.1.5 (not having services)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Not having an internal audit during the year ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Having Fun While Learning ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
I Not having "effectiveness" in the Quality Policy ISO 13485:2016 - Medical Device Quality Management Systems 8
U Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
M How to compare 2 independent samples having 3 factors 3 levels Statistical Analysis Tools, Techniques and SPC 5
W Thoughts on having Safety Shower in ISO Class 7 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 5
T Customer Escape of a part having features reversed 180 degrees Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
ScottK Is anyone else having problems uploading Proprietary Names into the DRLM? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Calibration Standards - Master weight having more tolerance than our gram scale General Measurement Device and Calibration Topics 3
D Having trouble with corrective action on external audit nonconformance Nonconformance and Corrective Action 8
S Minor NC for Not Having Management Review When Scheduled Management Review Meetings and related Processes 12
B Example of Production Process Change having Significant Consequences AS9100C 7.5.1.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C Can a Company get away with not having Employees Trained to the Processes they use? Training - Internal, External, Online and Distance Learning 2
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
B Having trouble writing a directive (procedure) that points to the right place ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
J Ever heard of having a Controlled SOP template? Document Control Systems, Procedures, Forms and Templates 12
J What is the advantage of having an NCA 3800 Quality Certificate Various Other Specifications, Standards, and related Requirements 3
N Benefits of having an EDMS in a Construction Company Various Other Specifications, Standards, and related Requirements 5
S CE Label having the indication for the applied part EU Medical Device Regulations 7
Marc Florida Professor Arrested for Having a "Suspicious" Bagel on a Plane Travel - Hotels, Motels, Planes and Trains 14
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
D What is the basis for having 1 or 6 Quality Manuals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Having quality in your resume in today's economy. Imported Legacy Blogs 3
C What is the Purpose of or Requirement for having a Gage Glossary? IATF 16949 - Automotive Quality Systems Standard 2
C Objective Evidence of Internal Auditors having Audit Clause 4.1. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S Feasibility of having one Quality Manual that documents 2 businesses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ajit Basrur Anyone having procedure on "Handling Regulatory Audits" ? US Food and Drug Administration (FDA) 2
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
Q 510k for Exempt Class I Medical Device - Industry Advantage to having a 510k Approval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
L Having faith in your Layered Process Auditors - Pencil whipping audits Process Audits and Layered Process Audits 8
P Having only influential control for some Legal needs. Miscellaneous Environmental Standards and EMS Related Discussions 2
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Advantage of having 2 marks - RvA and ANAB, for example Registrars and Notified Bodies 5
L Objectives: Measurable or having a tangible value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Evaluate Customer Satisfaction without having to send questionnaires Supplier Quality Assurance and other Supplier Issues 2
eternal_atlas Is not having a controlled copy of ISO 9001 standard a NonConformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 114
Ajit Basrur Anyone having ppt file on Advisory Notices ? ISO 13485:2016 - Medical Device Quality Management Systems 2
Ajit Basrur Can you recommend websites having GMP posters? Training - Internal, External, Online and Distance Learning 6
MarilynJ6354 Observed Audit Behavior - Internal auditors having lunch with the auditees Internal Auditing 32
