Not having Training Records for Documentation Changes - ISO 13485 Clause 4.2.3
bio_subbu
#11
Re: Not having training documentation for documentation changes - ISO 13485 Clause 4
Our auditor wrote us a nonconformance for not have training documentation for every time time there is a document change. I cannot find the requirment for this. I thought that if the department heads/supervisors was signing the change document this would satisfy the requirement.
Set of policies, procedures or requirements are defined as audit criteria as per the standard ISO 19011- 2004: Guidelines for quality and/or environmental management systems auditing. Since you are a medical devices industry, procedure for change control and training are mandatory requirement as required by ISO 13485:2003. The auditor can write non conformity, if your internal procedures (audit criteria) either training or change control called for the information stating that “Training required if there any revision changes in the documents”. But I don’t know what your procedure says.
In our organization, we described our internal training procedure that “procedural training for affected personnel is completed prior to employees using a new or revised procedure.” and also described in our document and change control procedure “Training records must be submitted when there is revision changes in the existing procedures. If training is not required, provide justification why not required”. (i.e.) as stated above by arios, if there is any administrative changes such as minor typographical errors, page alignment and etc.
Some organizations are maintaining integrated procedure (ISO 13485 & FDA QSR) and follow their requirements (e.g) 21 CFR 820.40 “Approved changes shall be communicated to the appropriate personnel in a timely manner”.
P
Phil Fields
#12
ISO tired,
Could you please provide the exact nonconformance as written by the auditor. This would help to focus the conversation on the facts.
Phil
arios
#13
Adding to Bio_Subbu's comments.
Per ISO 13485:2003 section 6.1
"The organization shall determine and provide the resources needed
b) to meet regulatory and customer requirements."
If this issue relates to a US marketed product then consideration needs to be given to the relevant or particular regulatory requirements applicable for that market. That implies 21 CFR 820.40
Please comment.
DesiQE
#14
My :2cents: is that a simple checkpoint in your change request form, where the requester and.or the approvers note whether the particular change warrants a training and/or notification.
DesiQE
jkuil
#16
Re: Not having Training Documentation for Documentation Changes - ISO 13485 Clause 4
How can a change in a procedure be effective if you do not inform the personnel that has to execute the procedure on the changed requirements.
Sure, it depends on the impact of the change.
  • Textual changes do not require training.
  • Significant changes in validated procedures may require qualification of personnel (ISO 13485 7.5.2.1b).
  • Other changes with product impact may be communicated e.g. during departmental meetings. Attendance should be recorded (ISO 13485 7.3.7) Also a read-and-understood statement by all employees that execute the changed procedure may sufice. If an annotaded copy identifying the changes is provided, the reading may take limited time.
  • Procedures document specific quality objectives. Management should ensure that changes to quality objectives are communicated (ISO 13485 5.4.1 and 5.4.2)
If any of the above mentioned changes introduces a personnel competence gap training should be part of the change implementation plan (ISO 13485 6.2). If not, it is adviceable to record in the implementation plan (especially where it potentially concers product safety and efficacy) that training was considered, but was deemed not applicable.
I
ISO tired
#17
I want to thank everyone for thier involvement in this post. I have decided to challenge the nonconformance. I do not see anywhere the specific requirement for training on documents. The FDA clause states "made aware"
not "trained" as stated in some of the reply's to my original post. There is nothing in any of my SOP'S that expressly state that I will train after each change to documents either.
To fully comply with the FDA requiremnent, I use a system (home grown) that is sent to all department personnel that requires them to click a box that they have been made aware of the document changes. This record is stored in the changed documents folder as objective evidence. I do not send this email for clerical changes, and I only sent it to the personnel that is impacted by any changes.
I tend to read ISO and FDA documents literally and not read into them hidden meanings. I also do not follow guides as regulatory law, since they are not auditable as well.
claire_b
#18
Re: Not have training documentation for documentation changes - ISO 13485 Clause 4.2
I have to say that I've always believed that when documents change, unless it is to correct typos etc, whoever uses them must get trained to the new revision. The whole procedure may have changed. Otherwise, what is the point of having documented procedures when you may not be trained to the latest revision and you may be doing things, for example, in the wrong order.
This would be covered in the regs in the effectiveness of training would it not?
Sidney Vianna
Post Responsibly
#19
It should be noted that changes in the process and supporting documentation can range from inconsequential to critical and everything in between. If a procedure was revised to effect a minor change, where the people affected can easily comprehend the change by READING the revised document, why create a non value added training? The KISS approach still applies. Certainly, if the change is non trivial, it does make sense for a (formal?) training.
claire_b
#20
PS to moderator of this forum. The thread title would read better Not have training records for documentation changes - ISO 13485 Clause 4.2; I tried editing it, but it looks like I don't have moderator rights in this forum.
You know I'm starting to realise the problem here. We need to define what we all mean by training. I mean everything from formal training to a quick self study by reading a document.
Likes: db
U QS 9000 Audit - Trainer of internal auditors not having formal training QS-9000 - American Automotive Manufacturers Standard 6
NDesouza No Quality Professional vs Having a Quality Professional Benchmarking 24
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
O Inspecting paint and having workable standards in the supply chain Supplier Quality Assurance and other Supplier Issues 1
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
N GDP - Having to provide a reason when writing N/A? ISO 13485:2016 - Medical Device Quality Management Systems 1
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
D Having got ISO 13485:2016 are you dropping ISO 9001? ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Partial non applicability of ISO 9001 Cl. 7.1.5 (not having services)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Not having an internal audit during the year ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Having Fun While Learning ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Having a hard time closing CAR/ PAR Nonconformance and Corrective Action 13
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
I Not having "effectiveness" in the Quality Policy ISO 13485:2016 - Medical Device Quality Management Systems 8
U Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
M How to compare 2 independent samples having 3 factors 3 levels Statistical Analysis Tools, Techniques and SPC 5
W Thoughts on having Safety Shower in ISO Class 7 Cleanroom ISO 13485:2016 - Medical Device Quality Management Systems 5
T Customer Escape of a part having features reversed 180 degrees Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
ScottK Is anyone else having problems uploading Proprietary Names into the DRLM? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Calibration Standards - Master weight having more tolerance than our gram scale General Measurement Device and Calibration Topics 3
D Having trouble with corrective action on external audit nonconformance Nonconformance and Corrective Action 8
S Minor NC for Not Having Management Review When Scheduled Management Review Meetings and related Processes 12
B Example of Production Process Change having Significant Consequences AS9100C 7.5.1.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C Can a Company get away with not having Employees Trained to the Processes they use? Training - Internal, External, Online and Distance Learning 2
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
B Having trouble writing a directive (procedure) that points to the right place ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
J Ever heard of having a Controlled SOP template? Document Control Systems, Procedures, Forms and Templates 12
J What is the advantage of having an NCA 3800 Quality Certificate Various Other Specifications, Standards, and related Requirements 3
N Benefits of having an EDMS in a Construction Company Various Other Specifications, Standards, and related Requirements 5
S CE Label having the indication for the applied part EU Medical Device Regulations 7
Marc Florida Professor Arrested for Having a "Suspicious" Bagel on a Plane Travel - Hotels, Motels, Planes and Trains 14
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
D What is the basis for having 1 or 6 Quality Manuals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Having quality in your resume in today's economy. Imported Legacy Blogs 3
C What is the Purpose of or Requirement for having a Gage Glossary? IATF 16949 - Automotive Quality Systems Standard 2
C Objective Evidence of Internal Auditors having Audit Clause 4.1. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S Feasibility of having one Quality Manual that documents 2 businesses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ajit Basrur Anyone having procedure on "Handling Regulatory Audits" ? US Food and Drug Administration (FDA) 2
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
Q 510k for Exempt Class I Medical Device - Industry Advantage to having a 510k Approval 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
L Having faith in your Layered Process Auditors - Pencil whipping audits Process Audits and Layered Process Audits 8
P Having only influential control for some Legal needs. Miscellaneous Environmental Standards and EMS Related Discussions 2
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Advantage of having 2 marks - RvA and ANAB, for example Registrars and Notified Bodies 5
L Objectives: Measurable or having a tangible value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Evaluate Customer Satisfaction without having to send questionnaires Supplier Quality Assurance and other Supplier Issues 2
eternal_atlas Is not having a controlled copy of ISO 9001 standard a NonConformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 114
Ajit Basrur Anyone having ppt file on Advisory Notices ? ISO 13485:2016 - Medical Device Quality Management Systems 2
Ajit Basrur Can you recommend websites having GMP posters? Training - Internal, External, Online and Distance Learning 6
MarilynJ6354 Observed Audit Behavior - Internal auditors having lunch with the auditees Internal Auditing 32
