Not sequentially following steps in a work instruction
Not sequentially following steps is an audit finding.
  • If there is evidence, "Yes" it's a finding
    Votes: 3 25.0%
  • Without more knowledge, I say "No", not a finding
    Votes: 1 8.3%
  • I would definitely dig deeper before any citation
    Votes: 8 66.7%
  • Given the limited information, no way to accurately say
    Votes: 3 25.0%
  • Total voters
    12
#41
Helmut, I should have made it clearer that my comments were for an internal auditor, should know (having planned the audit carefully) a bit more about the process they were auditing than others.
It's true that if an external auditor stumbled over this one, they wouldn't have that backgound information on which to base a thought. So, that's were it becomes of critical importance that those audit trails are followed to determine the results - not just a rush to judgement that 'the process isn't followed'!
Richtich?
BradM
#42
Randy's work is typically third party auditing, while I do internal auditing.
Just for what it's worth, the original title had 9001:2000 audit finding. But... we still don't know whether the OP is talking about an external audit or internal.
It would be nice to get some more information from the OP on this. We seem like two brothers arguing about which one will carry the girl to the dance, without knowing if she is even going or has another date!:lol:
NOTE: I added a poll on this. There are plenty of moderators on this thread, so feel free to adjust wording, add titles, etc. as you see fit.
Sidney Vianna
Post Responsibly
#43
Such good comments so far. On one side there is the black-and-white approach, and on the other side the thinking ventures into the gray murky place that is risk based auditing. ....
....Randy's work is typically third party auditing, while I do internal auditing. So, I find Randy's simple approach quite correct in his context.
No auditing, internal or external, should be based on assumptions.
Helmut Jilling
Auditor / Consultant
#44
The principle is the same, however. It should be an audit trail until it is established (by whatever means) that sequence matters, then not following sequence would go from an audit trail to an NC.
BradM
#45
Agreed.:agree:As I stated, it seems we have little information surrounding this scenario, so I was just putting back in as much as we have however minute the relevance.
As I stated in post #3 or so, I think something should change in this process. Either the operators need to be trained and follow the sequence, or the procedure is too sequence-oriented. Hopefully by whatever means appropriate (which is the topic of interest) the owners of the system see an improvement is in order.
Randy
#46
If changes to procedures can be arbritarily made by the user (not the owner...the user) what purpose do they serve? From what I am seeing ya'll agree with the "make-it-up-as-you-go" way of doing things.
Apparently the process owner had his say when the procedure was written so either the work is being done improperly or the procedure is incorrect. This is kinda like the statement in the movie National Treasure --- "Somebody has to go to prison"
I'm looking at this from the perspective of a 3rd party, limited in time and needing to cover the audit plan in the time alloted and then having to write a report prior to the closing meeting, it's a judgement call based on the evidence and time available.
All we have is what was provided, nothing else and we were asked by the OP for feedback and how we would handle it. We have a clear requirement, and 2 pieces of evidence of non-fulfillment of that requirement...observation and a statement. Sure, talking to the process owner may reveal that the procedure is inaccurate or not important, but then that would require a corrective action with the procedure and corrective action is only required when nonconformance is identified....reverse thinking.
ISO 19011:2002 ( I know, it's just a guidance document but it is specifed for use by 3rd part CB's and must be used) contains in part this little piece
6.5.4 Collecting and verifying information
The audit evidence is based on samples of the available information. Therefore there is an element of uncertainty in auditing, and those acting upon the audit conclusions should be aware of this uncertainty.
Auditing is not an exact science and resists quantification mainly because the results of the audit are dependant upon the best judgement of the auditor. The judgement of the auditor is based upon the understanding of the requirement, the evidence presented, the requirements of the auditing organization and the auditors own training, education and experience...in the end many times there are no absolutes when it comes to the findings generated (positive or negative) and the conclusions developed. If the truth were to be acknowledged we are in fact just saying "Here is my opinion supported, by the evidence I found in the sample I used, according the criteria I had to follow".....
Sidney Vianna
Post Responsibly
#47
There is no evidence that the process is not delivering the results. So, why change? Steel had a great example about coffee-making.
Does it make a difference if you pour the water first and add the ground coffee later? No. Now, it does make a difference if you add the ground coffee first and THEN place the filter on top. Where was your filter, Steel?:tg:
I am amazed how some of you can reach any conclusion on this scenario about NC or no NC or operator discipline or process inefficacy without asking questions. That is not effective auditing, internal or external.
Jen Kirley
Quality and Auditing Expert
#48
My assumption was that the auditor had verified there was such a requirement, and that it was not being met. The questions then would be:
1) Who, and how many were not meeting the requirement, and
2) Why the requirement is important.
Sidney Vianna
Post Responsibly
#49
My assuption was that the auditor had verified there was such a requirement, and that it was not being met.
I rest my case. You made an assumption, without anything in the original post to support that. If we are free to make assumptions, I can lead this scenario anywhere. Now, in the real world of auditing, one must ask appropriate questions to the right people before reaching a conclusion.
Jen Kirley
#50
Oh I see what you mean. Well, my bad. I was trying to respond to the two scenario paths in a context, which would raise a potential of offering bad advice. I hope that does not turn out to be the case. It's always a risk here.
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
M Medical Device News Brexit - Withdrawal Agreement and Political Declaration laid before Parliament following political agreement. EU Medical Device Regulations 4
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
S Supplier Classifications - Please give me a good definition of the following terms ISO 13485:2016 - Medical Device Quality Management Systems 5
K Nonconformance on training - Not following own processes (IATF 16949) Internal Auditing 14
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
C Following Order of Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 23
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
T What to do when Employees are not following Instructions Human Factors and Ergonomics in Engineering 65
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R QA Manager and Disciplining Employees for not following Processes Quality Manager and Management Related Issues 28
I Medical Device Registration details for the following Countries ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sampling Inspection at QA - Inputs on the following sampling plan Statistical Analysis Tools, Techniques and SPC 3
N My FDA auditor asked the following: Other US Medical Device Regulations 12
Q How to determine the average baseline for the following data in SPC Quality Tools, Improvement and Analysis 3
M 7.6.2 Revisions following Engineering Changes - What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 4
Marc Software gives visual representation of who?s following you online After Work and Weekend Discussion Topics 1
Ronen E European Commission calls for action following PIP's Breast Implant Saga EU Medical Device Regulations 1
T Employee not following Purchasing Process Other Medical Device Related Standards 27
Marc US east coast in chaos following rare October snowstorm - 2011 Coffee Break and Water Cooler Discussions 14
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
L Consultant not following Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
Q Can I use Regression Analysis in the following scenario Statistical Analysis Tools, Techniques and SPC 18
Q Supplier Disqualification - High Rejects and not following established Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Change Order Process - Stake holders not following through - Suggestions wanted Manufacturing and Related Processes 5
D Manufacturing Execution Systems (MES) - People Not Following Work Process (WPs) Manufacturing and Related Processes 5
L Fitted Splined Connections following DIN 5480 - Inspection Problems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
eternal_atlas Not following the Procedures is a Nonconformance? Sales department General Auditing Discussions 61
H Meeting following an interview, what should I expect? Career and Occupation Discussions 15
T Labeling Control and trouble with labelers not following procedure ISO 13485:2016 - Medical Device Quality Management Systems 11
Ajit Basrur Teva recalls drug following Jackson death probe Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A Audit NC (nonconformance) for not following guidelines on calibration! General Measurement Device and Calibration Topics 9
S Consequences of Shipping product with label not following CE rules EU Medical Device Regulations 2
Q Corrective Action - CAPA - Root Cause - Not following the training procedure! Problem Solving, Root Cause Fault and Failure Analysis 13
S Why people not following SPC charts regularly Training - Internal, External, Online and Distance Learning 10
Q Work Environment - Which of the following is to be addressed as nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
D How do we interpret the following XmR Trend Chart data? Statistical Analysis Tools, Techniques and SPC 3
L Corrective action following a wrong answer of the auditee ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
T In the following statement, what does "Z" stand for? ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Failure where the Root Cause was the Material Handler Not Following Procedure Problem Solving, Root Cause Fault and Failure Analysis 20
Q Personnel Not Following Procedures - How do you write up an audit finding? Internal Auditing 43
A Non-conformance logged following a TS16949 Stage 2 audit - APQP Control Plan IATF 16949 - Automotive Quality Systems Standard 15
