Not sequentially following steps in a work instruction
Not sequentially following steps is an audit finding.
  • If there is evidence, "Yes" it's a finding
    Votes: 3 25.0%
  • Without more knowledge, I say "No", not a finding
    Votes: 1 8.3%
  • I would definitely dig deeper before any citation
    Votes: 8 66.7%
  • Given the limited information, no way to accurately say
    Votes: 3 25.0%
  • Total voters
    12
Paul Simpson
#81
I tried to use quotes in replying to Jim but his use of quotes turned it into a pile of poo, so I'll try from scratch.
IMHO if a particular method of operation is important then a work instruction is required. If it isn't it can be built from a print. So the example of use of gauges in Jim's example doesn't require a work instruction (again IMHO).
Similarly PPAP submission would not warrant a work instruction. The warrant and submission level define what is required and the APQP programme defines when the data are prepared - so why have a WI?
#82
How does a warrant define anything? Which (of possibly several) forms do you use for material test reports, dimensional reports, etc.? What information must those reports contain (which might be more than that called for in the PPAP manual)? How about the capability report? What format? Where does the data come from? Who signs the warrant and when? I could go on, but I assure you that there are no two companies that do PPAP the same, and if you don't have an work instruction you're asking for trouble.
#83
For purposes of this discussion, it doesn't make any difference if a WI is required or not. Perhaps the WI in question isn't necessary at all, but that doesn't alter the fact that it does exist.
Marc
#85
While having good substance, this seems to have evolved into a fairly rough, contentious thread. The needling and off topic information must immediately cease.
Marc
Paul Simpson
#86
....... and if you don't have an work instruction you're asking for trouble.
A lot of the documents you mentioned are collected at stages of the APQP process and should be called up in APQP procedures for (for example) phase sign off and might reference the forms etc. required (e.g. to produce a capability report). Similarly authority levels (such as for sign off) are procedural activities.
Jim, if you believe PPAP warrants a WI then by all means produce one. I don't believe it gets on the radar.
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
M Medical Device News Brexit - Withdrawal Agreement and Political Declaration laid before Parliament following political agreement. EU Medical Device Regulations 4
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
S Supplier Classifications - Please give me a good definition of the following terms ISO 13485:2016 - Medical Device Quality Management Systems 5
K Nonconformance on training - Not following own processes (IATF 16949) Internal Auditing 14
P Is the next revision of ISO 15378 following the High Level Structure? Other ISO and International Standards and European Regulations 5
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
C Following Order of Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 23
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
T What to do when Employees are not following Instructions Human Factors and Ergonomics in Engineering 65
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M QSR - Design Control on Existing Device not Designed following QSR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R QA Manager and Disciplining Employees for not following Processes Quality Manager and Management Related Issues 28
I Medical Device Registration details for the following Countries ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sampling Inspection at QA - Inputs on the following sampling plan Statistical Analysis Tools, Techniques and SPC 3
N My FDA auditor asked the following: Other US Medical Device Regulations 12
Q How to determine the average baseline for the following data in SPC Quality Tools, Improvement and Analysis 3
M 7.6.2 Revisions following Engineering Changes - What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 4
Marc Software gives visual representation of who?s following you online After Work and Weekend Discussion Topics 1
Ronen E European Commission calls for action following PIP's Breast Implant Saga EU Medical Device Regulations 1
T Employee not following Purchasing Process Other Medical Device Related Standards 27
Marc US east coast in chaos following rare October snowstorm - 2011 Coffee Break and Water Cooler Discussions 14
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
L Consultant not following Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
Q Can I use Regression Analysis in the following scenario Statistical Analysis Tools, Techniques and SPC 18
Q Supplier Disqualification - High Rejects and not following established Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Change Order Process - Stake holders not following through - Suggestions wanted Manufacturing and Related Processes 5
D Manufacturing Execution Systems (MES) - People Not Following Work Process (WPs) Manufacturing and Related Processes 5
L Fitted Splined Connections following DIN 5480 - Inspection Problems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
eternal_atlas Not following the Procedures is a Nonconformance? Sales department General Auditing Discussions 61
H Meeting following an interview, what should I expect? Career and Occupation Discussions 15
T Labeling Control and trouble with labelers not following procedure ISO 13485:2016 - Medical Device Quality Management Systems 11
Ajit Basrur Teva recalls drug following Jackson death probe Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A Audit NC (nonconformance) for not following guidelines on calibration! General Measurement Device and Calibration Topics 9
S Consequences of Shipping product with label not following CE rules EU Medical Device Regulations 2
Q Corrective Action - CAPA - Root Cause - Not following the training procedure! Problem Solving, Root Cause Fault and Failure Analysis 13
S Why people not following SPC charts regularly Training - Internal, External, Online and Distance Learning 10
Q Work Environment - Which of the following is to be addressed as nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
D How do we interpret the following XmR Trend Chart data? Statistical Analysis Tools, Techniques and SPC 3
L Corrective action following a wrong answer of the auditee ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
T In the following statement, what does "Z" stand for? ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Failure where the Root Cause was the Material Handler Not Following Procedure Problem Solving, Root Cause Fault and Failure Analysis 20
Q Personnel Not Following Procedures - How do you write up an audit finding? Internal Auditing 43
A Non-conformance logged following a TS16949 Stage 2 audit - APQP Control Plan IATF 16949 - Automotive Quality Systems Standard 15
