Notification of Change of Material Supplier - PPAP Manual 4th Edition
#11
In conclusion, if I understand all:
1° Send the notification to customer
Yes.
2° To wait his approval of my notification to use a new supplier of same raw material
Up to you, but it's probably best to wait if you can, and if you're not sure about what the customer might expect.
3° Only after approval I can start with the production and in the same time I send a PPAP presentation
When you can start production and whether or not you'll need to submit a new PPAP will be decided by the customer, based on #2. You might want to start out with a phone call (with written confirmation) to speed things up a bit.
DrM2u
#12
Situation: PPAP is approved. Material certification in PPAP file is from raw material supplier "A", the material is 1234.
Either due to availability or cost reasons, we purchase material from a different raw material supplier "(B)", but the material is the same, 1234. This customer has no specific requirements beyond TS/PPAP regarding notification or PPAP resubmission.
Questions:
Am I required to notify my customer that I changed raw material suppliers? This change mest be approved by my customer and after this approval I submit a PPAP documentation?
Any help on this subject is most appreciated.
Thank you
Luca
Most customes have such a requirement that they be notified when anything changes related to the process (material, equipment, location, control plan, etc). Some just want to be notified while others require that they approve any changes. You would have to review your customer's requirements to know for sure.
Good practices would point toward notifying your customer simply because of potential liability concerns. It is usually agreed that there is variation within a material not only from supplier to supplier but from lot to lot form the same supplier. A formal approval to switch from the customer drastically reduces your liability and responsibility for the product.
DrM2u
#13
I agree with you about that the notification is obligatory (...)
Per the PPAP manual, in your case notification would be obligatory ONLY if you supply bulk materials and you change the supplier for one of the 'ingredient' materials used in producing the bulk material. Otherwise, it is obligatory only if required by customer.
I can use the other supplier only after approval by my customer?
You can use the material anytime if your customer does not require the approval of the new supplier. For example, GM or Ford have multiple qualified supplier for certain materials. An organization could switch between these approved suppliers whenever they choose without necesarily notifying or getting approval from the customer.
(...) and, after this approval Must I submitted PPAP?
Only if your customer requires you to do so.
Golfman25
#14
So add this twist. You buy from a distributor who buys from a steel mill. A handful of mills make the steel to an ASTM specification.
1) Distributor orders material from multiple mills -- Does this require notification and approval?
2) You change distributors, but material comes from the same mill -- still required notification and approval?
Any different if you supplied Fenders vs. washers?
dknox4
#15
We've been down this path with our customer and have agreement that "commodity" materials (meeting an agreed upon spec.) are not subject to the notification requirements. The agreement is based on the fact the material spec meets customer requirements and our process controls/testing of the final product protect the customer again.
DrM2u
#16
It depends you your customers' requirements and they should be the ones to answer these questions. Usually if the requirement is for a generic type of material (multiple mills) then no need for PPAP as long as you have the certs to prove that the materials are equivalent. If you are talking about a 'name brand' material or customer-specified mill then you are stuck to that mill or producer regardless of the vendor/distributor.
A Material Grade Change Notification to Brazil ANVISA Other Medical Device Regulations World-Wide 2
J FDA notification of address change US Food and Drug Administration (FDA) 2
R Change Notification - Registrar vs Notified body ISO 13485:2016 - Medical Device Quality Management Systems 1
D Customer and Company Specific Requirements for notification of Customers of a change in Management or Key Personnel Customer and Company Specific Requirements 3
supadrai Informational Japan Minor Change Notification Application Form - Found it? Japan Medical Device Regulations 0
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
A Customer Notification of Change Procedure Quality Manager and Management Related Issues 1
A Temporary Change of Manufacturing Site - Notified Body Notification Requirements EU Medical Device Regulations 3
M Class I Medical Device - 1st notification and change notification EU Medical Device Regulations 4
S Update on Change Notification for Registered Medical Devices in Singapore Other Medical Device Regulations World-Wide 0
B Process Change Notification (PCN) form to notify our customers of a change Document Control Systems, Procedures, Forms and Templates 3
J Complying with Change Notification Requests - Wholesale Distributor Quality Manager and Management Related Issues 7
S Customer PPAP notification and submission for a Change APQP and PPAP 2
J Supplier Change And Customer Notification IATF 16949 - Automotive Quality Systems Standard 1
L Notification of supplier change to our customers Supplier Quality Assurance and other Supplier Issues 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
P 21 CFR 807.81 When a premarket notification submission is required Other US Medical Device Regulations 0
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
M Informational ANVISA – Notification for Class 1 devices – Resolução da Diretoria Colegiada – RDC nº 270 de 28/02/2019 Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Final Guidance – Intent to Exempt Certain Unclassified Medical Devices from Premarket Notification Requirements Medical Device and FDA Regulations and Standards News 0
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
T External Standard Update Notification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Nemko AS & DQS - Concern over notification as a Medical Device NB Registrars and Notified Bodies 5
E Customer Letter/Notification - Is it a field action? Other US Medical Device Regulations 4
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
N Notification of Changes to a Class I Medical Device - Reporting Requirements EU Medical Device Regulations 4
O Regulatory Notification for IVD IFU Instructions Revision ISO 13485:2016 - Medical Device Quality Management Systems 3
L Notification and submission requirements for medical device material changes Registrars and Notified Bodies 2
T Notification of affected parties of Updated Documented Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J CRB (Certification Registration Body) Notification of Potential Escape AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
GStough Template for Supplier Notification of Audit Supplier Quality Assurance and other Supplier Issues 5
P Acquisition of a company that manufactures a PMA device-FDA notification requriements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
F Notification Procedure for Reimbursement Implants and Invasive Devices in Belgium EU Medical Device Regulations 4
S Audit Notification - Is it a obligation to notify people or just good practice Internal Auditing 18
M Is Notification of the Test Laboratory always necessary for Supplier Changes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
Stijloor GM (Supplier) and PPAP Requirement 3.1 Customer Notification APQP and PPAP 5
Ajit Basrur FDA: Industry Notification: Furlough Update (8 October 2013) US Food and Drug Administration (FDA) 8
J Process Changes - Customer Notification Requirements APQP and PPAP 12
N Notification Sample Regarding Record Retention ISO 13485:2016 - Medical Device Quality Management Systems 5
O Documenting Processes requiring Customer Notification Misc. Quality Assurance and Business Systems Related Topics 2
L How to track the NCR (Quality Notification, Services Notification) Nonconformance and Corrective Action 2
Hershal This morning I received notification that I have my third copyright Coffee Break and Water Cooler Discussions 11
B Control Plan Revision Requirements - Notification of and Approval by Customers FMEA and Control Plans 1
K Customer Notification Requirements - New Packaging Machine for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 1
A Do I need to send notification to Notified body and EC Rep? EU Medical Device Regulations 12
D Customer Notification: PCN - EOL ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Export "Simple Notification" required by the FDA under Section 802 of the Act Other US Medical Device Regulations 3
