Re: NB Audits of Sub-Contractors and Critical Suppliers
I understand exactly where Pads38 is coming from.
We specify any number of safety critical devices such as fuses, opto-couplers, transformers, mains rated cable, etc.. All of these components are standard catalogue items and can be purchased from any number of distributors. So point one is that the distributor is our supplier, the original manufacturer is not. We fully specify the component to our supplier (the distributor) who is on our approved supplier list, they supply and we check at goods-in that the correct parts have been supplied. Through this very simple process we have full and demonstrable control of the supply of critical components without the need for any NB intervention. The specification of the parts has to be precise.
During the design process hazards are identified and, where appropriate, are mitigated by employing components which can be considered as safety critical. The efficacy of those components is verified and validated through in-house bench testing and type testing to the 60601 series of standards by an independent, accredited test house. Through that process the specifications of all components, including safety critical, are determined and detailed on the BoM. We can clearly demonstrate that if component part number 'A' with specification 'B' from manufacturer 'C' is fitted in position 'D' all the relevant safety criteria will be met irrespective of who the actual supplier is.
There's more...
We also sub-contract out the assembly of our surface mount PCBs. Contrary to some of the comments made earlier in this thread, our PCB sub-contractors are not classed as critical suppliers by our NB and are not in line for an unannounced audit. This is because of the way we manage them. They have been through our supplier approval process, so we are happy with the way they translate and transfer our BoM into their production control system, we are happy with their processes for managing engineering changes, we are happy with their manufacturing process controls and they supply us with a full traceability report for all of the components used in a manufacturing batch. We have a supply agreement in place with them which describes the regulatory requirements associated with the manufacture of the PCBs and assigns each one to either or both of our companies as appropriate. The crucial part of the process is that when the PCBs arrive we carry out 100% testing. This effectively transfers all of the risks away from the sub-contractor and onto us and for that reason our NB regards the sub-contractor as a significant supplier, but not a critical one.
We have consulted with our NB along the way and have no critical suppliers as a result.
MEDDEV 2.5/3 Rev 2,
Subcontracting - Quality systems related, is now quite an old document, but it is still current and effective. The guidance indicates that the NB should take into account the control exercised by the manufacturer over the sub-contractor when determining the requirements for auditing the latter. It would appear that our NB has noted the guidance and is acting accordingly.
