Definition NPI (New Product Introduction) Readiness - Definition
charlize10k
I need some help! Can someone tell me what exactly NPI Readiness mean?
I think that is related to the procedure for a new product introduction involving work instructions, other client requirements procedures, documents, team assigning, and line layout and so on. It is correct? This is EMS related.
Thanks.
jeffrey_Chang
Re: NPI Readiness - Definition
Yes, NPI = New Product Introduction
Different industries will have different NPI requirements.
I'll try to explain NPI from a subcontractor (Test house) perspective.
Pls note that each company will have their own NPI system.
The purpose of NPI is basically
(1) to ensure the successful transfer of new products or introduction of new products
(2) to ensure capacity meets new product initial demands .
It covers all aspect of the operation from contract review through operational readiness.
Typically, NPI is leaded by an NPI coordinator and in our case by the
TPM (Technical Program Management) team. I would say, it is in some ways
relatively similar to APQA. Listed below are some of the roles of each
dept.
NPI Coordinator
To lead the NPI team for new product transfer.
To work with or liaise with respective customer representative/co-ordinator for necessary information and establish the transfer date.
To monitor and ensure customer 1st order is met and manufacturing readiness.
Product Engineering Representative
To ensure that test program, Golden Modules and DIB are available and ready based on transfer date.
To conduct Tester Correlation Test if required.
To follow up if customer qualification is required.
Planning Representative
To set up new part number and routing in SAP system.
To follow up on schedule of deliveries of modules in order to meet 1st order.
Industrial Engineering
To determine requirement for final earn hours (FEH) and if capacity is available.
Finance
To determine and set up cost roll-up for new part number.
Purchasing
To identify and order the required raw materials for production.
Equipment Engineering Representative
To conduct Equipment Qualification Test.
To coordinate and ensure the readiness of the Interface.
Quality Representative
To coordinate and follow up on First Article submission and approval.
To ensure all customer quality requirements are rec'd and understood.
Manufacturing Engineering Representative
To review and setup the MES for production use.
To provide First Article upon customer requirements and submit to QA representative for the necessary approval.
To determine if new process is required.
To determine if consumables for the products is available for qualification.
To follow up on availability of all drawings, specifications, requirements and instructions.
To coordinate and ensure dummy devices, for new form factor, are available for qualification.
Training
To follow up on all necessary training is carry out for the new product.
Customer Service Representative
To advise and provide pricing and PDL information for new part number.
Hopes that this helps.
thks.
jeffrey.
Q
quality1
Hi All,
I've read through many NPI threads and was wondering if anyone has an actual NPI process flow diagram they would like to share or a process of concept to delivery of a product.
Thanks in advance :)
reynald
It has only been a year since NPI dept was introduced in our organization. I have'nt seen any NPI process flow yet. However my perception of thier function is not very much different to overseeing a Product Design Review or Engineering Change Review. In addition to owning the Quality of the new product though, they also own the input planning, prototype building, and customer qualification (which used to be owned by several groups like QA, Manufacturing, and others). After all aspects of manufacturing has stabilized, the product is turned-over to the usual/mass-pro depts (PPIC/QA/Operations, etc). So far that is all i understand about this function.
Raffy
Hi quality1,
Our organization established NPI and they are considered as the authorized body to make sure that all new product activities are being track, monitor and synchronize within the Organization. NPI activities includes the following: Creation of an over-all project timeline for new projects from conceptualization to customer closure.; Formation of task force group for every new project from Customers. Group members include but not limited to, depending on project requirements: R&D, Production Engineering, Quality Assurance, Electrical & Maintenance, NPI, Process Engineering, etc. They also serve as a liason of new project activities with internal and external customers. Responsible in consolidating all project documentations and ensure that the conclusion of project closure is approved by the customer.
Hope this helps.
Best regards,
raffy
Hi All,
Q
quality1
Thank you for your responses, I understand what you're saying, but was actually looking for a flow diagram. :)
S New Product Introduction Procedure - NPI Document Control Systems, Procedures, Forms and Templates 1
K NPI (New Product Introduction) Quality Plan Outsourced Manufacturer/Supplier APQP and PPAP 3
T Raw Parts Inspections for NPI (New Product Introduction) Phase Supplier Quality Assurance and other Supplier Issues 1
S Monozukuri Rules for NPI (New product Introduction) - Help to get Lean in Manufacturing and Service Industries 3
Q Procedure for New Product Introduction (NPI) - Build to print shop Various Other Specifications, Standards, and related Requirements 6
S NPI (New Product Introduction) in Electronics Industries Document Control Systems, Procedures, Forms and Templates 10
Y NPI (New Product Introduction) Process Qualification System Required Document Control Systems, Procedures, Forms and Templates 8
Q Internal Program audit Scope for NPI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
N Have any different between NPI and APQP ? APQP and PPAP 1
K Definition NPI, PPCR, QFD, NCR, DOE - Abbreviations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Extension to shelf life of new product under MDR EU Medical Device Regulations 1
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
R Compatibility studies - combination product CE Marking (Conformité Européene) / CB Scheme 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
dinaroxentool Selling a product in Both UK and EU after Brexit UK Medical Device Regulations 8
P EU MDR Translation of Product Name EU Medical Device Regulations 0
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
D Classification of product for clinical trials EU Medical Device Regulations 14
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
B Internal Auditor Competency - Product Auditors Internal Auditing 9
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
S AS9120B - 8.5.2 Delivering Split Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Classification of a product according to MDR EU Medical Device Regulations 3
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
J Possible to get ISO 13485 certified with only OEM Product? ISO 13485:2016 - Medical Device Quality Management Systems 4
Felony Melony New Product Launch - Safe Launch Customer and Company Specific Requirements 1
Marcel DS How do I know if my product is required be RoHS certified? REACH and RoHS Conversations 6
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
A ISO 11135:2014, B.1.4, BI resistance x product bioburden ISO 13485:2016 - Medical Device Quality Management Systems 6
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
R Product Recall - medical devices in the hospital warehouse Canada Medical Device Regulations 2
A Software bug fixes after shipping a product EU Medical Device Regulations 3
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
