Number of people to be interviewed during an internal audit?
dsantos24
How do you determine how many people should be interviewed during an internal department/process audit? Let say the department has 100 employees?
You don't. You define the scope and criteria of the audit first. That will give you an indication. Since the fashionable thing to do its audit a process, that will inform whom you speak with, along with the scope and criteria. Are you planning on auditing a process? Departments have many processes.
Mikey324
As stated above, this department has 100 people. Are the all performing the same process? I would assume all 100 are not working on the same line, for example. if the department consists of multiple processes (blanking, stamping, milling, etc) you would want to audit those processes within the department.
Each would have their own scope. What are the inputs? What are the planned objectives? Are they being accomplished? If not, what was done? Did it work?
Randy
Do what gives you a warm fuzzy, 1, 5, 10 whatever.... How much time do you have will many times dictate the number.
Also what do you plan to ask? Don't ask stuff that they can't reasonably answer and you'd better know the ballpark answer before you ask the question to start with.
Sidney Vianna
Post Responsibly
The basic expectation is that the sample selected is representative of the population; however, the sample size and composition should also take into account the criticality of the process being assessed. For more information, you can peruse Annex A of ISO 19011 for additional guidance on judgement based and statistical sampling in management system auditing.
Using your example, if these 100 people were doing all the same thing, my judgement tells me that interviewing 10 would be representative, but, assuming these 100 people are responsible for different sub processes, the number would be different.
Since this is an internal audit, it's going to depend on the reason for the audit and hence the scope. The "sample" may be one or two people, even in a department of 100. If, for example, you want to find out about a specific issue which happened in processing, that might only have been touched by 3 people. There would be no "sample". Go and talk to all three.
If I was unfamiliar with a particular audit or area I would observe the area from afar for a bit. See who is doing what, which departments were interacting etc. It would sometimes give me a better idea of who to approach especially if something seemed off.
malasuerte
This - determine the scope of the audit, then determine who you need in order to get the answers. For example, I may go to a process area and need a process technician, an equipment technician, an engineer, and their manager if my scope is Product/Processing, preventive maintenance, change control, and management review.
Zero_yield
"You can observe a lot by just watching."
The number of people isn't nearly as important as the purpose behind the people you talk to.
For example, let's say you're auditing a manufacturing line. You'd probably want to talk to technicians on the manufacturing floor and probably technicians who perform different operations. You'd probably want to talk to some of the folks who maintain the equipment, who developed the processes, who package the product, who conduct quality investigations when things go wrong, management, etc.
So even if there are 100 employees who are in some way part of the manufacturing line, there might only be a half dozen people who work in equipment maintenance. If you just talked to them, you'd get a very different view of the process than if you talked with 6 manufacturing floor technicians. If you talk with some people from each operations, group, and function within the organization, you'll get a much better view than if you just hold yourself to a hard number of people to talk to.
M Number of decimal places for measuring General Measurement Device and Calibration Topics 3
M Material Heat Number / Lot Number ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Adding new product code/Catalogue number to existing 510K US Medical Device Regulations 0
J Average number of Nonconformances during internal quality audit for Medical Device Manufacturers Internal Auditing 3
I Restricting scope to one part number for one customer IATF 16949 - Automotive Quality Systems Standard 6
T EN 17141 - number of monitoring locations Other Medical Device Related Standards 2
renenatasha Single Registration Number (SRN) EU Medical Device Regulations 2
Ed Panek ANNUAL FDA Registration - What 510(k) number to use? US Food and Drug Administration (FDA) 1
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
Y CE marking with NB identification number EU Medical Device Regulations 0
H Notified Body Number with CE Mark CE Marking (Conformité Européene) / CB Scheme 4
L How to deal with the model number symbol for X-RAY PRODUCT Other Medical Device Related Standards 1
R UDI Number Identification EU Medical Device Regulations 5
G Number of Destructively Tested Devices Needed for Ethylene Oxide Validation Other Medical Device Related Standards 4
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
Ch00Ch00 Evaluate a process - Issue number Lean in Manufacturing and Service Industries 7
N How to find column number for the last non-empty column? Using Minitab Software 0
S Business Number versus Company ID? Canada Medical Device Regulations 3
B Document Issued with incorrect Document number code Document Control Systems, Procedures, Forms and Templates 3
M Are you allowed to reuse the same asset number if the device was replaced? General Measurement Device and Calibration Topics 10
D Control Number for Class III and IV devices Canada Medical Device Regulations 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Why 'FD&C act section number' and 'section number' in the title of the act are different? US Food and Drug Administration (FDA) 7
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
Q How is Medical Device Number (MDL) assigned to companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D How to get EUDAMED Single Registration Number (SRN) EU Medical Device Regulations 19
M Informational US FDA – Modifications to the List of Recognized Standards, Recognition List Number: 052 Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
F 2017/745 Article 31 Single Registration Number Medical Device and FDA Regulations and Standards News 5
Z Do we still have to put UDI if we have DI and lot number seperately on our product ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Ed Panek GTIN (Global Trade Item Number) for non CE Mark Other Medical Device Related Standards 4
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
G Belgium - How do I get an enterprise CBE Number Other Medical Device Regulations World-Wide 0
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
M Informational USFDA – FDA Modernization Act of 1997: Modifications to the List of Recognized Standards, Recognition List Number: 051 Medical Device and FDA Regulations and Standards News 0
S How to number and control translated SOPs - Three languages Document Control Systems, Procedures, Forms and Templates 4
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Relabeling or Not Relabeling - Adding our internal Part Number barcode label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
lilybef Number of lots required for stability testing of a Class II device in the 510(k) Qualification and Validation (including 21 CFR Part 11) 3
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
