Numbering or Naming (Identification) of Generic Company Specifications?
Q
QAMTY
Hi all
One point in doubt, please feed me back
In our company, we have implemented a Quality System also established the naming for documents. e..g PRO-ENG-0001, PRO-HR-0002,ect
But in the last time we have had the need to produce specifications (e.g. Painting practices) for our projects.
The idea is this spec should be used for all the projects.
My question is: How this spec. should be numbered? Could be like "Specification of painting"? or give it a name of ISO documents? e.g.
PRO = procedure
WI =work instruction
SP-ENG-001
(spec-eng. area-consecutive)
What is your point of view?
Pancho
wikineer
Re: Numbering of Generic Specifications?
Reading this and your other questions about numbering, makes me wonder what you are intending your numbering system to help you with.
How do you currently store and retrieve your documents? Do you have paper binders, or a file server, a database or something else? Do you use the numbers to actually find a document? If so, how?
We may be better able to advise once we understand your storage/retrieval/usage system for your docs.
Q
QAMTY
Thanks Pancho
Well, I store the documents in a file server organized by levels lets say ín folders named Level 1
level 2, Level III
Inside of them, for example in the III level
Are stored the documents in this way
PRO-ENG-001 Development and design
WIS-ENG-002 How to number engineering documents
and so on....
they are easy to retrieve by browsing into the folders
Muy Main doubt is about standard specifications, how are to
be named, following ISO numbering or just the name?
Important is to note that these specs are to be used
in all the projects (are like standards)
Regards
Pancho
wikineer
QAMTY,
I think comment #7 in this other thread addresses this question, but it may require a change in the platform that you use to store your documents.
If you are constrained to a hierarchy of folders in a server, then I'd think that you'd place all your specs into a single folder. The document names should be short but clearly indicative of the contents. IMHO, codes are not very useful to anyone but the person that came up with the code.
I wouldn't use the ISO clauses to name or refer to any of my QMS documents regardless of what method of storage we were using.
Good luck!
Pancho
x-files Hardcopy and Electronic Forms for same purpose vs. Naming and Numbering System Document Control Systems, Procedures, Forms and Templates 1
Q Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 6
G Re-numbering or editing Dynamic Stamps in Adobe Acrobat Document Control Systems, Procedures, Forms and Templates 0
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
K Document Numbering (Identification) System Document Control Systems, Procedures, Forms and Templates 10
H Numbering for documents with same content but different language ISO 13485:2016 - Medical Device Quality Management Systems 4
P Re-Numbering Documents from the last Standard to Department and Title Document Control Systems, Procedures, Forms and Templates 11
L Page Numbering requirement for DHR Report Records and Data - Quality, Legal and Other Evidence 3
D Organization Chart Document Numbering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
S Form and Form/Record Numbering in an Excel Spreadsheet Excel .xls Spreadsheet Templates and Tools 2
C Document Numbering Matrix showing how to number all documents by type Document Control Systems, Procedures, Forms and Templates 2
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
I Batch Numbering for medical tape EU Medical Device Regulations 1
M Please help to change the numbering in level 3 of structure Document Control Systems, Procedures, Forms and Templates 1
W UL standard for Lead wire - meaning of UL numbering, AWG#, no. of conductor, etc Various Other Specifications, Standards, and related Requirements 1
alonFAI Document Numbering System For ISO/Quality Management Document vs. All Other Documents Document Control Systems, Procedures, Forms and Templates 48
Q Control Of Documents and Forms - Formats and Numbering Document Control Systems, Procedures, Forms and Templates 3
S Document Numbering and Identification Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
S Quality Plan Revisions and Numbering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
E ISO 9001 Clause Numbering System Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Numbering of Pages in a Revised Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Document Numbering and Hierarchy Requirements for ISO 13485 Document Control Systems, Procedures, Forms and Templates 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
B Corrective Action Numbering and Indexing Best Practice Nonconformance and Corrective Action 2
G Requirement for Form Numbering (Document Identification) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Document Revision Numbering and Related Requirements Document Control Systems, Procedures, Forms and Templates 12
D Multiple Format Document and Part Numbering Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Corrective Action Documents - Numbering Records and Policies? Document Control Systems, Procedures, Forms and Templates 6
Q What is your ISO Documentation Numbering (Identification) System ? Document Control Systems, Procedures, Forms and Templates 1
V Document Numbering Systems Question Document Control Systems, Procedures, Forms and Templates 5
T Performance Document vs. Project Document Numbering Convention Document Control Systems, Procedures, Forms and Templates 4
S Document Numbering and Identification Systems Advice wanted Document Control Systems, Procedures, Forms and Templates 14
bgot62 Work Instruction Numbering System Document Control Systems, Procedures, Forms and Templates 6
N Unique Document Identification Numbering System Document Control Systems, Procedures, Forms and Templates 69
Y MS Access Report Numbering not Ascending Quality Assurance and Compliance Software Tools and Solutions 2
A Tool Modification Drawing Change Control and Numbering Document Control Systems, Procedures, Forms and Templates 1
S Advice on numbering of KPC's, please APQP and PPAP 4
A Multiple Lot Numbering EU Medical Device Regulations 4
W Procedure Clause ?Level? Numbering System explanation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Large Projects, large number of partners? Document Numbering/Identifying Issues Benchmarking 6
Y ISO: Help With Records Numbering System & Log in Excel or Access Document Control Systems, Procedures, Forms and Templates 12
Q Technical Documents Numbering System - Manuals, Procedures and Wi's Document Control Systems, Procedures, Forms and Templates 42
O Simple process for providing Serial/Lot Numbering for our product Document Control Systems, Procedures, Forms and Templates 5
CarolX Blueprint numbering for 1st Article submission Misc. Quality Assurance and Business Systems Related Topics 13
D Production and Service Provision - AS9100 vs. ISO 13485 - Numbering Issues ISO 13485:2016 - Medical Device Quality Management Systems 2
3 Numbering system for inventory of bolts, washer, and nuts Manufacturing and Related Processes 1
T Confused by chapter numbering scheme in new standard (IEC EN-60601-2-37:2007) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Batch / Lot Numbering - Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 3
