Objectives of Internal Audit 8.2.2 (a) - Explanation needed in plain English!!
G
gspyrou
Hi everyone,
This is my first post and still trying to find myway through this forum sight.
I must say that I have obtained through existing threads some very usefull explanations regarding various matters relating to ISO 9001 that I was a bit confused with.
I am not sure what the element 8.2.2 (a) regarding Internal Audit means exactly:
Determine whether the QMS conforms to the planned arrangements (see 7.1) . Does this mean to deternime whether the QMS conforms with the services provision processes planned and developed by the company? In other words "Are the proceesses developed and used in providing our services identical to those described in the QMS?"
Determine whether the QMS conforms to the QMS requirements establised by the organisation. Here I find it difficult to get the meaning. :frust:
My company is a service provider.
Any help will be much appreciated.
AgnieszkaSz
in very plain English and from bitter experience - it means checking whether all these beautiful declarations and process descriptions and instructions are really implemented. Whether they are alive - or just slogans.
Jokes aside - with really good process owners, the lead auditor should agree the objectives of a particular internal audit (at preliminary meeting, when fixing the date); a process owner usually knows gaps in his or her own area and - ideally - would want to repair them somehow.
As for objectives of audit programme for a given year - I had an objective for 2009 "to review the system after implementation of big organizational changes". This depends on your company's needs.
G
gspyrou
Internal Audit ISO elem 8.2.2 (a) - Interpreatation needed in plain English!!
Many thanks for your explanation.
I was actully hoping to receive from someone a specific interpretation for each of these 2 requirements of ISO 9001 element 8.2.2.
I guess I did not phrase my post title accurately. I therefore changed it accordingly.
Thanks once again
alspread
1. Are all of the systems working as planned. You need to go around and witness and collect evidence periodically to assure yourself (and a certification auditor) that everything is working as planned. A checklist of questions with pass or fail results and corrective actions for deficiencies found.
2.) At the seme time you need to make sure that it is compliant to both the requirements of the ISO standard and any requirements you may have deemed appropriate for your own organization.
You need to plan this activity (i.e. some kind of schedule that you intend to follow). The people doing the checking (auditors) can't check their own work or area.
Good luck
samsung
In addition to above, two more important aspects of auditing that I can recall, are to determine
(1) if the established system will continue to conform to the requirements now & in future.
(2) if there's an improvement (no matter how much) or atleast there exists some signs of improvement from the previous stage.
I
ISO 9001 Guy
Does the system conform to the planned arrangements in 7.1.? In other words, "Does the system conform to the service provision planning required of 7.1?" Are we doing realization the way we planned? (A separate but related question is, "Is the way we are doing it effective/efficient/in need of improvement?" Just because you are doing it as planned--conforming to planned arrangements--does not necessarily mean that "how you do it" is effective or efficient.)
"Are the processes developed and used in providing our services identical to those described in the QMS?" This is a loaded question and a good one. It depends upon how your QMS is structured. Often times, processes described in QMS documentation do NOT reflect the processes being operated, instead they reflect requirements pertaining to processes being operated. (This is a common, standard-based approach.) If QMS documentation is based upon the standard instead of being based upon processes, then the processes developed and used in providing your services are not identical to those described in the QMS.
G
gspyrou
Thanks you all for your assistance.
The information I received through this thred has been very enlightening.
:thanx:
JaneB
Gspyrou, Here's an example to illustrate the difference between ISO 9001 requirement and one that your organisation has set:
Assume you're auditing one of your service delivery processes:
1. You might audit to see that all personnel on the assignment(s) had the required competencies - most likely via revieweing the records that your organisation has that demonstrate this, eg, job descriptions, qualifications, etc etc (clause 6.2)
2. Assume your service includes giving weekly written reports to the client. Your organisation has mandated the use of a particular template & format for those reports to go in, and that a manager (in your company) must first review the report pre-client delivery. That's an 'in-house requirement'. You would then audit to see whether all those things were being done for your audit sample(s).
G
gspyrou
JaneB thanks for your examples which are quite illustative. How would you define "Planned Arrangements" in the context of internal auditing (i.e. to explain to the auditee during the opening meeting of internal audit this requirment of ISO).
I have made some research and having combined the various versions of definitions given I have reached this concusion:
Planned arrangements are all the arrangements made by the company to meet the requirements of the external and internal parties that directly affect or are affected by the company such as, clients, suppliers, regulatory bodies, management etc. They include agreements, contracts, proposals, laws, regulations policies, strategies, objectives e.t.c., and the prescriptive and descriptive documents derived therefrom. The audit establishes whether the QMS has been designed and includes all the necessary processes to implement and meet those requirements.
What is your opinion?
Thanks in advance
How would you define "Planned Arrangements" in the context of internal auditing (i.e. to explain to the auditee during the opening meeting of internal audit this requirement of ISO).
I'm not sure you need to! An internal audit shouldn't be addressing - directly - the requirements of the ISO standard. The scope, criteria etc should be your organizations qms - those planned arrangements - not anything that ISO 9001 (13485 etc) states...
A clue is that if you find yourself having to interpret 'Iso-speak' there's something wrong!
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
K Defining Internal Audit Process Goals & Objectives Internal Auditing 49
T Process Internal Audit - Requirement on Monitoring Objectives & Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M FSMS Targets and Objectives in SMART planning Food Safety - ISO 22000, HACCP (21 CFR 120) 4
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
I Quality Policy and Objectives examples Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 5
M Specific Values of Quality Objectives Benchmarking 7
Q Quality Objectives Not Met - Resources promised by investors ISO 13485:2016 - Medical Device Quality Management Systems 4
V What plans have been put in place to achieve quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Objectives in Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Farley.0 QMS Sales Goals & Quality Objectives Manufacturing and Related Processes 22
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
V Discussion of ISO 9001:2015 - "Quality Objectives" term ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A ISMS implementation - ISO 27001: 2013 Company Objectives IEC 27001 - Information Security Management Systems (ISMS) 1
R ISO 9001:2015 - KPI (Key Performance Indicators) vs. Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Quality Department Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
S Process Measurable Objectives Imported Legacy Blogs 3
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
R ISO 13485:2016 - Quality Objectives Regulatory Requirement Examples ISO 13485:2016 - Medical Device Quality Management Systems 1
J Business Continuity - ISO 22301 BCMS Strategic and Tactical Objectives Business Continuity & Resiliency Planning (BCRP) 3
Q Additional KPI to Top Management beside Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Examples of Quality Objectives related to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Objectives for Receiving Inspection (Resources) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Identifying Objectives & Targets for Quality Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Calibration Laboratory Objectives Achievement Report or Plan Management Review Meetings and related Processes 1
D Measurable objectives for our in-house calibration department General Measurement Device and Calibration Topics 6
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
dubrizo If Quality Objectives are not known to employees, is it a Nonconformance? General Auditing Discussions 7
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Creating goals and objectives with targets and measurables for self-evaluations Management Review Meetings and related Processes 2
T Corrective Action for Quality Objectives which are not Measureable Nonconformance and Corrective Action 7
I AS9100 5.4.1 - Typical objectives of different functions and levels AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Best place in QMS to manage Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L What is the difference between Objectives and Responsibility ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Balancing between Strategic Objectives & Short Term Priorities Quality Manager and Management Related Issues 2
Q Quality Objectives for Quality Control and Quality Assurance functions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Usability Objectives and Verification & Validation Plan IEC 62366 - Medical Device Usability Engineering 6
K Are Quality Objectives applicable on HSE Department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Will these Quality Objectives cover the Product Requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Colin Objectives Form - Format for Documenting Information Security Objectives IEC 27001 - Information Security Management Systems (ISMS) 2
S Presentation for tracking Quality Objectives across sites Preventive Action and Continuous Improvement 3
