cncmarine said:
I treat all Observations has warnings and therefore issue corrective actions.
OFI's are not the same as observations. In fact I believe that OFI's should not even be allowed.
It consulting.
We could be just mincing words here.
Warnings about what? There is either compliance, or not. If not, then correction or corrective action is required. If in compliance, then a corrective action is meaningless. There is nothing to correct.
I write observations (I use that term synomously with OFI) under four conditions.
1) The situation is compliant, but close. There is a good possiblity that a nonconformance will occur.
2) I believe there to be a nonconformance, but it is out of scope. I will also schedule a supplemental audit for the activity in about 30 days.
3) A nonconformance might exist, but for some reason, I cannot make the call. Maybe there is not enough time for me to complete the investigation. Once again, a supplemental audit would be scheduled.
4) I find something an issue where an improvement can be made. This is a simple case of a suggestion for better performance.
Now, about the consulting issue. Absolutely it is consulting. However, my audits are strictly internal, and as such my role is to determine if the system (QMS) works, and to find ways to "continually improve its effectiveness" (4.1).
Thank you for bring that up. My comments are only intended for internal auditing.
MShell, are we talking internal or external. Probably should have asked that first.
