OEE (Overall Equipment Effectiveness) Downtimes Calculation
michu
We've monitored OEE for one year. The most common problem we experienced is fact that the operators artificialy increse downtimes time in order to improve performance ratio.
I'd like mention two things:
Performance index has a big innfluence on its monthly salary
Operators calculates downtimes itself
Have you got any ideas how to change this sistuation
Stijloor
Re: OEE downtimes calculation
Hello Michu,
There are ways to automate the data collection.
Here is a link to a company that provides such a system.
(NOTE: I am not associated with this company)
Aside from this, it seems that you have a operator-management issue here. Has this process been subject to internal audits? Not knowing all the specifics, this is obviously a serious problem.
Are these OEE scores used in a punishment/reward-type system? Because whatever it takes, operators will make sure that the numbers come out right. Is it possible that the OEE scores are impacted by process issues over which the operators have no control?
Just some questions for consideration.
Stijloor.
anrice
Hi Michu,
I've worked with OEE for many years and would need more information to try and help you. It can be resolved using different means and will depend on how you collect the current information. Ability to tie in with automation is also an option.
How do you currently calculate OEE? Do you collect information by Shift? What are you measuring? Even though you know that they are over reporting downtime do you know what downtime they are over-reporting?
If you record downtime by shift then displaying a trend analysis of say unplanned downtime should display a discrepancy across the shifts whereas the downtime reasons on a trend across shifts should even itself out.
Also if they are overreporting are you seeing speed gains (i.e. Performance > 100%?).
If you can provide more information I may be able to give further assistance.
N
ngkjrs
OEE is the cumulative product of Availability Rate, Performance rate and Quality Rate.
Irrespective of your downtime, OEE can vary only if the accepted production lot (count) varies. If the downtime goes down, performance increases. From your mail it makes clear that you have two separate teams for production and maintenance.
Club them together. Those who produce will be responsible for the functioning of the equipment and the quality of the product. Get rid of "you make i fix" syndrome.
Then such issues can be resolved.
alokb
Dear Sir,
First of all let us understand why OEE is calculated?
Answer to this question ,as far as my understanding goes, is.
To improve
1. Availability
2. Performance /speed
3. Quality output
Basic idea it is not only maintenance that is responsible for production / productivity ,there is something else which is needed to be looked for improvement.
It appears that your system is again falling into the trap of blaming maintenance.
If your performance factor is 100 % why calculate OEE than.
Go back to calculate Availability only and let maintenance department take all the responsibility.
Thanks.
Alok
N
ngkjrs
OEE is calculated to identify where the loss had occured. whether in time, speed or quality.
So, one needs the right input so that the corrective actions are rightly planned and impelemented.
swapnilmarne
You can split the downtime into different types as :
1) Quality
2) Power off
3) Setting
4) Shortage
5) No Operator
6) Maintenance
7) Others ( Has To specify the reason)
So that operator can not put downtime blindly as the above data represents particular department's contribution in downtime .
You can also form same analysis like average setting time, Inspection time according to depts.
This will help you to share the OEE load within the organisation not only upto you.
Regards
Swapnil
Eric ng
I had the similar problem when I first introduced OEE for the equipment maintenance group in a Electronic product manufacturing plant. All the maintenance personnel including the section head and manager in charge were trained in the methodology. The section head has the responsibility to ensure that all the key parameters are properly defined, and a baseline OEE for each individual equipment was defined and documented, especially downtime. A year later, the section head left the company, and the company experienced throughput problem, so the manager in charge changed the definition of downtime to make it looks good, and tried to shift the problem to quality or engineering. This was discovered during one of the monthly performance review presentation which prompted me to audit the method of OEE calculation.
In short, data integrity must be maintained at all times and that depends on the integrity of the person in charge of the operation.
Eric Ng
M Can OEE (overall equipment effectiveness) exceed 100%? Manufacturing and Related Processes 2
M Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
L OEE (Overall Equipment Effectiveness) and Cost Savings Manufacturing and Related Processes 2
S Measuring OEE (Overall Equipment Effectiveness) for each Job, not for Machine Lean in Manufacturing and Service Industries 2
8 OEE (Overall Equipment Effectiveness/Efficiency) Help Lean in Manufacturing and Service Industries 17
D Overall Equipment Effectiveness (OEE) Calculations Manufacturing and Related Processes 4
AnaMariaVR2 OEE (Overall Equipment Efficiency) on Pharma Packaging Lines Lean in Manufacturing and Service Industries 8
Y OEE (Overall Equipment Efficiency) help Lean in Manufacturing and Service Industries 6
S OEE (Overall Equipment Efficiency) - One question Manufacturing and Related Processes 17
S OEE Software - Automating the collection of Overall Equipment Efficiency data Statistical Analysis Tools, Techniques and SPC 8
P OEE (Overall Equipment Efficiency) and Downtime Manufacturing and Related Processes 17
V Overall Equipment Efficiency (OEE) calculation of 2 different scenarios. Manufacturing and Related Processes 5
E Control Charts for OEE (Overall Equipment Efficiency) Statistical Analysis Tools, Techniques and SPC 19
D Definition OEE definition - Overall Equipment Effectiveness - Definition of A (Availability) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
Marc Definition OEE (Overall Equipment Effectiveness) - Initials and Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Overall equipment effectiveness - Computing OEE taking all machines taken together Manufacturing and Related Processes 12
H OEE (Overall Equipment Effectiveness) and Run at Rate IATF 16949 - Automotive Quality Systems Standard 5
A OEE - Overall Equipment Effectiveness QS-9000 - American Automotive Manufacturers Standard 1
A OEE - Overall Equipment Effectiveness - A Ford Requirement Customer and Company Specific Requirements 7
C OEE and In-process Inspection Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
M OEE - The meaning of the single number Quality Tools, Improvement and Analysis 12
M Overview of the relations between OEE and SCOR Quality Tools, Improvement and Analysis 1
J Correlation between OEE and FMEA FMEA and Control Plans 2
P How to clean paint area tile faster and improve OEE Manufacturing and Related Processes 3
R Building an OEE System to our Production Lines - New concepts to me Lean in Manufacturing and Service Industries 12
somashekar Information sharing: Week 22, 2010 (TPM, OEE) The Reading Room 1
M Calculating OEE Performance Measurement for a CNC Plasma Cutter Manufacturing and Related Processes 19
C Has anyone ever heard of Informance software? Monitors machine uptime/downtime (OEE) Preventive Action and Continuous Improvement 11
A OEE for Food Manufacturing - Non Dairy creamer manufacturing Manufacturing and Related Processes 1
P OEE - Is there a company that offers a better display than others? And how effective Lean in Manufacturing and Service Industries 19
L Determining Coordinate Measuring Machine (CMM) OEE General Measurement Device and Calibration Topics 2
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
I Estimation of overall residual risk. How to? EU Medical Device Regulations 11
I Realization processes input into overall risk ISO 14971 - Medical Device Risk Management 2
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 12
K Overall residual risk according to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 5
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
Marc US wind capacity surpasses hydro, overall generation to follow World News 0
K Is there an overall standard for calibration of items used in TS 16949 Certified Co. IATF 16949 - Automotive Quality Systems Standard 3
Sam Lazzara ISO 14971 Clause 7 - Evaluation of Overall Residual Risk Acceptability ISO 14971 - Medical Device Risk Management 3
P Overall Cpk for Different Parts to Same Customer Statistical Analysis Tools, Techniques and SPC 6
Q Availability Calculation for monitoring Overall Equipment Efficiency Manufacturing and Related Processes 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
D QA's Role in the Overall Picture of the Organization and in Day to Day Activities Misc. Quality Assurance and Business Systems Related Topics 10
O Using SPC to determine overall Thread Quality Manufacturing and Related Processes 16
