OEE (Overall Equipment Effectiveness/Efficiency) Help
8balluk
Hi there,
Ive been asked to set up OEE on a few machines which im more than happy to do. Never done it before and nor as the company.
Having read up on it now for a couple of hours it seems like an impressive tool of which if applied correctly we can definately yield benefit from.
From a newbie in this field the initial issues i can see are:
1. The gathering of the numbers. To me the numbers need to be generated automatically (hence some software package). For instance if i am reliant on operators filling out time sheets telling when and how long the machine is down its destined to fail before it starts.
2. Quality of the product might not be an instant feedback, as we have an inspection department. what happens if the product is made but it sits on a rack for 2 days and only then does it come to light that there is an issue.
Thanks in advance for any advice
c
somashekar
I believe that, if the operator is not taken into confidence and made a part of the OEE exercise, its destined to fail sooner than later...
The focus here is equipment churning out parts / or not and how effectively it is being used or begging to be used, 24 x 7.
That the parts made are good is an other exercise and run concurrently.
8balluk
thanks for the reply.
yes i understand that the operator needs to be part of the excercise and will be but from my experience operators filling out forms will die sooner rather than later and the numbers can not be trusted.
concerning my statement about about quality, what you say isnt really answering my question. one of the 3 major catorgories being 'defect losses', i need to understand what the rework and rejects. but if i dont have that number till later whats my way around it.
thanks
I
ianpearce
We have done the OEE in excel, I have attached an example of our OEE hope this is what you are looking for
Ian Pearce
  • Overall Equipment Effectiveness.xls
Duy Efeso
Dear 8BALLUK
I have similar issues like you. The workers not fill the losses data as it needs. If they do that, you will see the "gap". Theorically the OEE plus losses must be equal 100%. Then we cross check with them and make some correction actions.
Best regards,
Duy
Sometimes we over measure and under improve.
I have found the amount of improvement is inversely related to the sophisticaion of the measurement formulas, data collection and reporting methods.
The measure I use is simple: number of manhours/number of units out. (you are paying the operators even if they are doing nothing - for whatever reason) In the end that's the only thing that counts. in my experience, every other refinement of the measure is just obfuscation of where the true problems lie.
sad, but true.
dickgent
I used this excel application 10 years ago when I was in manufacturing. It is still an excellent tool. Take a few moments to familiarize yourself with the content (an hour should do it) and you can customize this to your manufacturing processes. Good Luck!
  • Downtime Tracking.xls
Chennaiite
Never-say-die
I don't think Quality of the parts produced can be taken out of equation in calculating OEE. In fact, what is effectiveness without Quality?
8balluk,
If the parts are lying in rack for inspection, which I assume is normal for your process, why not measure OEE at an interval that is suitably fixed to accomodate inspection results.
somashekar
8balluk,
While quality of the parts is the essence without which there is no effectiveness, the focus in the case of OEE must be machine utilization (meaning it simply churns out acceptable parts) and unlike manpower, the machine is there installed and commissioned to work 24x7x365 days. Optimizing this is the purpose of OEE and it also throws up the non effective time which the management will have to take notice of and plan to feed load.
How much is set-up time and how to reduce set up time, How much is idle time (missed opportunity to get output from the equipment, as it is there begging for load), How to optimize maintenance down time to get maximum equipment uptime = optimum effectiveness ... these must be visible from the OEE.
M Can OEE (overall equipment effectiveness) exceed 100%? Manufacturing and Related Processes 2
M Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
L OEE (Overall Equipment Effectiveness) and Cost Savings Manufacturing and Related Processes 2
S Measuring OEE (Overall Equipment Effectiveness) for each Job, not for Machine Lean in Manufacturing and Service Industries 2
D Overall Equipment Effectiveness (OEE) Calculations Manufacturing and Related Processes 4
AnaMariaVR2 OEE (Overall Equipment Efficiency) on Pharma Packaging Lines Lean in Manufacturing and Service Industries 8
Y OEE (Overall Equipment Efficiency) help Lean in Manufacturing and Service Industries 6
S OEE (Overall Equipment Efficiency) - One question Manufacturing and Related Processes 17
S OEE Software - Automating the collection of Overall Equipment Efficiency data Statistical Analysis Tools, Techniques and SPC 8
P OEE (Overall Equipment Efficiency) and Downtime Manufacturing and Related Processes 17
V Overall Equipment Efficiency (OEE) calculation of 2 different scenarios. Manufacturing and Related Processes 5
M OEE (Overall Equipment Effectiveness) Downtimes Calculation Manufacturing and Related Processes 8
E Control Charts for OEE (Overall Equipment Efficiency) Statistical Analysis Tools, Techniques and SPC 19
D Definition OEE definition - Overall Equipment Effectiveness - Definition of A (Availability) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
Marc Definition OEE (Overall Equipment Effectiveness) - Initials and Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Overall equipment effectiveness - Computing OEE taking all machines taken together Manufacturing and Related Processes 12
H OEE (Overall Equipment Effectiveness) and Run at Rate IATF 16949 - Automotive Quality Systems Standard 5
A OEE - Overall Equipment Effectiveness QS-9000 - American Automotive Manufacturers Standard 1
A OEE - Overall Equipment Effectiveness - A Ford Requirement Customer and Company Specific Requirements 7
F IATF 16949 Clause 8.5.1.5 - OEE, MTTR, and MTBF Calculation IATF 16949 - Automotive Quality Systems Standard 2
C OEE and In-process Inspection Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
M OEE - The meaning of the single number Quality Tools, Improvement and Analysis 12
M Overview of the relations between OEE and SCOR Quality Tools, Improvement and Analysis 1
J Correlation between OEE and FMEA FMEA and Control Plans 2
P How to clean paint area tile faster and improve OEE Manufacturing and Related Processes 3
R Building an OEE System to our Production Lines - New concepts to me Lean in Manufacturing and Service Industries 12
somashekar Information sharing: Week 22, 2010 (TPM, OEE) The Reading Room 1
M Calculating OEE Performance Measurement for a CNC Plasma Cutter Manufacturing and Related Processes 19
C Has anyone ever heard of Informance software? Monitors machine uptime/downtime (OEE) Preventive Action and Continuous Improvement 11
A OEE for Food Manufacturing - Non Dairy creamer manufacturing Manufacturing and Related Processes 1
P OEE - Is there a company that offers a better display than others? And how effective Lean in Manufacturing and Service Industries 19
L Determining Coordinate Measuring Machine (CMM) OEE General Measurement Device and Calibration Topics 2
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
I Estimation of overall residual risk. How to? EU Medical Device Regulations 11
I Realization processes input into overall risk ISO 14971 - Medical Device Risk Management 2
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 12
K Overall residual risk according to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 5
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
Marc US wind capacity surpasses hydro, overall generation to follow World News 0
K Is there an overall standard for calibration of items used in TS 16949 Certified Co. IATF 16949 - Automotive Quality Systems Standard 3
Sam Lazzara ISO 14971 Clause 7 - Evaluation of Overall Residual Risk Acceptability ISO 14971 - Medical Device Risk Management 3
P Overall Cpk for Different Parts to Same Customer Statistical Analysis Tools, Techniques and SPC 6
Q Availability Calculation for monitoring Overall Equipment Efficiency Manufacturing and Related Processes 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
D QA's Role in the Overall Picture of the Organization and in Day to Day Activities Misc. Quality Assurance and Business Systems Related Topics 10
