OEE (Overall Equipment Efficiency) and Downtime
P
phil1234
I would like to know how to account for a machine that is broken and unable to produce for an extended period of time.
We have 5 machines and one is going to take a week or more to repair: does this mean that my "Availability" is straight away reduced by 20%, or do I ignore it completely?
I want to ignore the machine and take it out of the system - my bosses say there are financial considerations (depreciation etc.) to take into account. Further, if the machine is not recording a downtime, how do we justify (show) decreased production further up the management ladder?
harry
Re: OEE (Overall Equipment Effectiveness) and Downtime
Welcome Phil,
After you had titled your thread and posted, the forum software will automatically searched and come up with some similar discussions/topic found in the 'similar discussions' box - just scroll down the page. The first thread: OEE (Overall Equipment Effectiveness) Downtimes Calculation may be relevant for you.
Next, you can do a search. I use 'tag' search and found 'oee' - with a number of recent threads (note: we started tagging only recently and what you get from this search are limited to some recent threads - with 7 threads, should be good enough). One good thread is: Overall equipment effectiveness - Computing OEE taking all machines taken together
P
phil1234
Hi Harry
I looked at the other posts but they were mostly old (one going back to 2005!)
I think most people would scan latest posts first (last 24 hours)and take it from there............
I appreciate your advice, thanks.
W
wmarhel
Two factors to contend with. First, when the machine broke down and "halted" production then that would be a factor that affects your OEE. Once it is decided that the machine needs to be removed due to extensive issues such as total failure or a safety risk; then it could be considered as scheduled maintenance. The reality though is that you shouldn't be trying to game OEE because a number drops signficantly. The real purpose of OEE is to benchmark a current state, highlight the issues that reoccur, and monitor the effectiveness of the programs you put in place.
First off, the machine depreciates whether it runs or not so that shouldn't be a factor. What would be more likely is that the machines doesn't run, so your controller it can't absorb overhead. Still silly, but hey; creating bad habits for operations is what accounting does best. The only financial consideration is that you may not be able to meet customer demand; or that the repairs may more costly than the justifiable.
There are anumber of posts here on OEE and aspects related to it, I would recommend you a do search here on The Cove as already mentioned.
Wayne
P
phil1234
Hi wayne
Thanks for your prompt reply:
What you suggest is what I did: The machine incurred downtime for 2 days or so until it was established that the breakdown was severe; at that stage I put out an email stating that the machine was "officially out of service" until further notice and removed it from my calculations. Management are questioning why my figures aren't reflecting a huge increase in downtime (which I am now showing as 12%, across the other 4 machines). They have to justify spending $25000 to repair this machine and WANT the downtime to reflect this.
I feel that I am correct in my calculations, but find it difficult to answer their argument.
Previous posts about downtime have only mentioned short periods, not an extended period such as mine.
harry
Hi Harry
Actually you should be looking for discussions that are relevant to your situation instead of whether a thread is new or old.
Not sure about you but I did come across a post where Wayne was essentially talking about the same thing ie: A machine which is down but not scheduled for production (or taken out from the schedule) cannot be included in your calculations.
On the other hand, if you are taliking to accountants, why use OEE? How many of them really understand? Why not talk about opportunity cost?
Ajit Basrur
Overall Equipment Efficiency (OEE) is a formula that shows the overall performance of a single piece of equipment, or even an entire factory, and is governed by the cumulative effect of three factors: the equipment’s availability (percentage of scheduled production time available), performance rate (percentage of parts produced compared to standard), and quality (percentage of saleable parts produced compared to parts started).
Putting in equation, it would be = Availability (%) x Quality (%) x Performance Rate (%) - for more info, you could have a look at Overall Equipment Effectiveness - Common Interest Workgroup
One of the major shortcoming of OEE is that it doesnot relate labor with equipment and should not be used as a stand alone metric. Also, OEE does not have a comparable cost metric and doesnot take figures such as depreciation and scheduled maintenance.
If you want to consider the financial aspects, consider some other metric.
P
phil1234
Thanks Harry and Ajit :agree1:
It's 11pm Sunday night in Perth, I'm off to bed but will be back soon!
zzzzzzzzzzzzzzzzzzzzzzzzz
Ajit, I know how to calculate run of the mill events regarding OEE, my problem, as stated in the beginning, is how to handle a major machine breakdown, an exceptional event for me - this is the longest outage that I have had to account for, hence my "panic" :D
adrianpask - 2011
If i may throw my thoughts in as well:
What is the intention behind collecting OEE data?
- For me it's to identify the losses to the manufacturing facility - the reasons why you're not producing.
Therefore i would like to offer 3 thoughts:
1. If the machine is down one argument may be that it's limiting the total output of your facility and in the short term whilst it skews your numbers, a reduced OEE is an accurate representation of why your output is reduced. When you look back in 12-24 months time the reduced output is accurate.
2. What is the reason for the machine breaking. If the cause is related to a lack of maintenance/lack of lubrication. Then in my opinion these are losses that should hurt your team as they are responsible. If the reason it's broken is down to what one of customers calls "an act of god" then they believe it's right to remove from the numbers.
3. People like numbers that they can hit. What's your intention for measuring OEE - if it's to motivate people and they can't effect the output then that can be a tricky message. One of my sites needs to invest capital to repair a machine part that causes slow running. They say their oee should be weighted whilst they're waiting for approval and in the meantime why should they be penalised for the poor performance? Again - this is a choice and i encourage them to think long term - in 24 months time they are doing no favours by hiding the loss.
With any number my belief is that it should be honest, consistent, transparent, and representative. As soon as you start weighting or changing due to environmental reasons you've lost it!
M Can OEE (overall equipment effectiveness) exceed 100%? Manufacturing and Related Processes 2
M Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
L OEE (Overall Equipment Effectiveness) and Cost Savings Manufacturing and Related Processes 2
S Measuring OEE (Overall Equipment Effectiveness) for each Job, not for Machine Lean in Manufacturing and Service Industries 2
8 OEE (Overall Equipment Effectiveness/Efficiency) Help Lean in Manufacturing and Service Industries 17
D Overall Equipment Effectiveness (OEE) Calculations Manufacturing and Related Processes 4
AnaMariaVR2 OEE (Overall Equipment Efficiency) on Pharma Packaging Lines Lean in Manufacturing and Service Industries 8
Y OEE (Overall Equipment Efficiency) help Lean in Manufacturing and Service Industries 6
S OEE (Overall Equipment Efficiency) - One question Manufacturing and Related Processes 17
S OEE Software - Automating the collection of Overall Equipment Efficiency data Statistical Analysis Tools, Techniques and SPC 8
V Overall Equipment Efficiency (OEE) calculation of 2 different scenarios. Manufacturing and Related Processes 5
M OEE (Overall Equipment Effectiveness) Downtimes Calculation Manufacturing and Related Processes 8
E Control Charts for OEE (Overall Equipment Efficiency) Statistical Analysis Tools, Techniques and SPC 19
D Definition OEE definition - Overall Equipment Effectiveness - Definition of A (Availability) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
Marc Definition OEE (Overall Equipment Effectiveness) - Initials and Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Overall equipment effectiveness - Computing OEE taking all machines taken together Manufacturing and Related Processes 12
H OEE (Overall Equipment Effectiveness) and Run at Rate IATF 16949 - Automotive Quality Systems Standard 5
A OEE - Overall Equipment Effectiveness QS-9000 - American Automotive Manufacturers Standard 1
A OEE - Overall Equipment Effectiveness - A Ford Requirement Customer and Company Specific Requirements 7
F IATF 16949 Clause 8.5.1.5 - OEE, MTTR, and MTBF Calculation IATF 16949 - Automotive Quality Systems Standard 2
C OEE and In-process Inspection Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
M OEE - The meaning of the single number Quality Tools, Improvement and Analysis 12
M Overview of the relations between OEE and SCOR Quality Tools, Improvement and Analysis 1
J Correlation between OEE and FMEA FMEA and Control Plans 2
P How to clean paint area tile faster and improve OEE Manufacturing and Related Processes 3
R Building an OEE System to our Production Lines - New concepts to me Lean in Manufacturing and Service Industries 12
somashekar Information sharing: Week 22, 2010 (TPM, OEE) The Reading Room 1
M Calculating OEE Performance Measurement for a CNC Plasma Cutter Manufacturing and Related Processes 19
C Has anyone ever heard of Informance software? Monitors machine uptime/downtime (OEE) Preventive Action and Continuous Improvement 11
A OEE for Food Manufacturing - Non Dairy creamer manufacturing Manufacturing and Related Processes 1
P OEE - Is there a company that offers a better display than others? And how effective Lean in Manufacturing and Service Industries 19
L Determining Coordinate Measuring Machine (CMM) OEE General Measurement Device and Calibration Topics 2
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
I Estimation of overall residual risk. How to? EU Medical Device Regulations 11
I Realization processes input into overall risk ISO 14971 - Medical Device Risk Management 2
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 12
K Overall residual risk according to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 5
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
Marc US wind capacity surpasses hydro, overall generation to follow World News 0
K Is there an overall standard for calibration of items used in TS 16949 Certified Co. IATF 16949 - Automotive Quality Systems Standard 3
Sam Lazzara ISO 14971 Clause 7 - Evaluation of Overall Residual Risk Acceptability ISO 14971 - Medical Device Risk Management 3
P Overall Cpk for Different Parts to Same Customer Statistical Analysis Tools, Techniques and SPC 6
Q Availability Calculation for monitoring Overall Equipment Efficiency Manufacturing and Related Processes 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
D QA's Role in the Overall Picture of the Organization and in Day to Day Activities Misc. Quality Assurance and Business Systems Related Topics 10
