OEE (Overall Equipment Efficiency) and Downtime
P
phil1234
#11
What we have decided to do is to account for the machines 24/7/365 = 100% utilisation, which makes sense. (This sort of incorporates TEEP as well), all downtimes will be noted to make up the balance of 100% minus run time.
Our OEE will only be 100% if we work 24/7/365 with no downtimes (if throughput and quality = 100%), so running 3 x 8 hour shifts 5 days a week, the max OEE would be (3x8x5)/(24x7) = 71.4% and so on.
We will achieve a higher OEE by working "overtime" and our $ turnover will be correspondingly higher.
adrianpask - 2011
#12
Hi Phil, great logic - see where you're going with that. Many sites would call that measure "Asset Utilisation" and would not normally measure it below senior manager level based on the principle that some sites don't want teams to have a lower number because they have no volume to produce. Check out this diagram and see what you think - it's our OEE 6 loss model: http://oeejourney.optimumfx.com/wp-content/uploads/oee_white3.jpg
Ade.
D Scott G
#13
Greetings;
I see many posts about OEE use, but not real direction for the posted issue. What I see as being asked is what "OEE rules" do you use? We use the above posted formula but with the Company twists. The rules are not posted anywhere at work and thru many questions some have been understood.
Mainly for your question if a machine goes down during a shift we assign the proper downtime code for the issue and take the OEE hit. The next shift we do not enter anything into our system or use an unscheduled code and we do not take a hit OEE wise. This is not side stepping our system because I also run a machine utilization report that accounts for the lost production time.
I would use the utilization report for their accounting of the $25,000 that they spent.
OEE Rant:
Too much focus is on the OEE % and not enough on the three factors that calculate our loved OEE %. This is what I mean above by the "company twists" each company has different ways to calculate the three variables and understanding them will help you to understand the root cause of a machines low OEE. I myself last year while investigating low OEE found availability to be the root cause. The next step was to focus on what affects the availability calculations or not and it was found that the PM codes and the not scheduled code does not hurt our OEE. Yes I know I just also gave the secret to cheat on ....aww I will let them figure that out but I think the positive outweighs the negs. Our PM crews, for the mold and machines, were not showing their downtime correctly or at all thus whacking my OEE adversely.
OK enough of the rant, I'm out.
Scott
P
phil1234
#14
Hi Scott
I agree with you: There should be a rule book issued by APICS or some one else which covers all issues.
We are going to implement our own system, agreed to by all, in the next financial year (July).
adrianpask - 2011
#15
Spot on Scott - completely agree that the devil is in the loss not the output. Here's a challenge - take your beloved 3 loss up to 6 loss; it makes an awesome difference in the identification of issues. In my sites we capture all losses like this:
1. Minor stops (stops to the critical machine <5min)
2. Major stops (stops to the critical machine >5min)
3. Speed loss (loss in speed when the machine is running i.e. excluding stop time)
These 3 are your perfromance measure
4. Quality loss in running (reject count turned into time)
5. Quality loss in startuo (reject count and loss time on startup - in my bottling and food plants i don't tend to use this category as the downtime is captured in planned downtime and losses 1-3 normally)
These are your quality losses
6. Planned downtime (any event that is not an unplanned stop)
Your availability measure.
We then tend to exclude from OEE the time when the site has no production plan (calling it not required for production - NRFP). This measure is captured in a seperate asset utilisation KPI.
Regards,
Adrian.
Mikael
#16
Re: OEE (Overall Equipment Effectiveness) and Downtime
Thx, time goes, the link to the workgroup does not work anymore.
M Can OEE (overall equipment effectiveness) exceed 100%? Manufacturing and Related Processes 2
M Where does OEE (Overall Equipment Effectiveness) belong? Quality Tools, Improvement and Analysis 11
L OEE (Overall Equipment Effectiveness) and Cost Savings Manufacturing and Related Processes 2
S Measuring OEE (Overall Equipment Effectiveness) for each Job, not for Machine Lean in Manufacturing and Service Industries 2
8 OEE (Overall Equipment Effectiveness/Efficiency) Help Lean in Manufacturing and Service Industries 14
D Overall Equipment Effectiveness (OEE) Calculations Manufacturing and Related Processes 4
AnaMariaVR2 OEE (Overall Equipment Efficiency) on Pharma Packaging Lines Lean in Manufacturing and Service Industries 8
Y OEE (Overall Equipment Efficiency) help Lean in Manufacturing and Service Industries 6
S OEE (Overall Equipment Efficiency) - One question Manufacturing and Related Processes 17
S OEE Software - Automating the collection of Overall Equipment Efficiency data Statistical Analysis Tools, Techniques and SPC 8
V Overall Equipment Efficiency (OEE) calculation of 2 different scenarios. Manufacturing and Related Processes 5
M OEE (Overall Equipment Effectiveness) Downtimes Calculation Manufacturing and Related Processes 8
E Control Charts for OEE (Overall Equipment Efficiency) Statistical Analysis Tools, Techniques and SPC 19
D Definition OEE definition - Overall Equipment Effectiveness - Definition of A (Availability) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
Marc Definition OEE (Overall Equipment Effectiveness) - Initials and Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Overall equipment effectiveness - Computing OEE taking all machines taken together Manufacturing and Related Processes 12
H OEE (Overall Equipment Effectiveness) and Run at Rate IATF 16949 - Automotive Quality Systems Standard 5
A OEE - Overall Equipment Effectiveness QS-9000 - American Automotive Manufacturers Standard 1
A OEE - Overall Equipment Effectiveness - A Ford Requirement Customer and Company Specific Requirements 7
C OEE and In-process Inspection Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
M OEE - The meaning of the single number Quality Tools, Improvement and Analysis 12
M Overview of the relations between OEE and SCOR Quality Tools, Improvement and Analysis 1
J Correlation between OEE and FMEA FMEA and Control Plans 2
P How to clean paint area tile faster and improve OEE Manufacturing and Related Processes 3
R Building an OEE System to our Production Lines - New concepts to me Lean in Manufacturing and Service Industries 12
somashekar Information sharing: Week 22, 2010 (TPM, OEE) The Reading Room 1
M Calculating OEE Performance Measurement for a CNC Plasma Cutter Manufacturing and Related Processes 19
C Has anyone ever heard of Informance software? Monitors machine uptime/downtime (OEE) Preventive Action and Continuous Improvement 11
A OEE for Food Manufacturing - Non Dairy creamer manufacturing Manufacturing and Related Processes 1
P OEE - Is there a company that offers a better display than others? And how effective Lean in Manufacturing and Service Industries 19
L Determining Coordinate Measuring Machine (CMM) OEE General Measurement Device and Calibration Topics 2
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
I Realization processes input into overall risk ISO 14971 - Medical Device Risk Management 2
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 8
K Overall residual risk according to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 5
C What is the difference between "Overall Risk" and "Risk"? (ISO 14971) ISO 14971 - Medical Device Risk Management 10
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
Marc US wind capacity surpasses hydro, overall generation to follow World News 0
K Is there an overall standard for calibration of items used in TS 16949 Certified Co. IATF 16949 - Automotive Quality Systems Standard 3
Sam Lazzara ISO 14971 Clause 7 - Evaluation of Overall Residual Risk Acceptability ISO 14971 - Medical Device Risk Management 3
P Overall Cpk for Different Parts to Same Customer Statistical Analysis Tools, Techniques and SPC 6
Q Availability Calculation for monitoring Overall Equipment Efficiency Manufacturing and Related Processes 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
D QA's Role in the Overall Picture of the Organization and in Day to Day Activities Misc. Quality Assurance and Business Systems Related Topics 10
O Using SPC to determine overall Thread Quality Manufacturing and Related Processes 16
B Overall Process Capability - Simple question if you know how to answer it! Statistical Analysis Tools, Techniques and SPC 3
