MedicalResp
We have a Class III implant intended for use in a first-in-human study. The surgical procedure involves percutaneous implantation. To reduce friction during implantation, we are considering using "off-the-shelf" lubricant gels. Although the part of the device that comes into contact with the gel will be removed, some gel will inevitably remain inside the body.
We are evaluating two types of technically suitable commercial gels (both are sterile and biocompatible):
To clarify, the use of the gel will not be part of the final product, but we need a solution for this early feasibility stage.
Is there any scope for applying a rational approach or conducting minimal testing to justify this use?
Thank you in advance.
- Wound dressing hydrogels indicated for "for partial and full thickness wounds including pressure ulcers, venous stasis ulcers, diabetic ulcers, first and second degree bums, abrasions, lacerations, skin tears, grafted wounds, donor sites and surgical wounds."
- Lubricating gels indicated for "facilitating the entry of a diagnostic or therapeutic device into a body orifice by reducing friction between the device and body."
