OHSAS 18001 Clause 4.4.6 Operational Control Example Procedure
Juliosalinas
Does anyone knows where to get a sample procedure to cover
"OHSAS 18001 4.4.6 Operational Control requirements?"
:thanx:
Regards,
Randy
Re: OHSAS 18001 4.4.6 Operational Control
Very simple...Because Australia has a pretty robust regulatory environment in many ways similar to the US I'll put it out straight
The easiest examples are the documented programs required by your health and safety regulations such as those for hearing protection, eye protection, control of hazardous chemicals in the workplace, confined space entry, driving equipment like forklifts, lock out-tag-out of energized sources, electrical safety and so on.
Marc
Fully vaccinated are you?
If anyone has an example procedure which can be shared we will all appreciate it. Additions to our library here are always appreciated.
K
kgott
:thanx:
Regards,
I dont know anything about this standard or the clause you metion but with operational control I think, and I emphasise I think, it would be referring to the process of risk (or hazard) identificiation, assessment and control. That would mean things like a risk register, risk assessment tool/matrix, JSA, procedures, competency, legislative compliance and records.
As Randy said; make sure you address legislative compliance for the hazrd concerned.
Tip: when writing a procedure or JSA, state the Regualtion number and briefly state what the Regualtion requires, then describe what the organsiation does (or needs to do) to comply with that Regulation.
Add to this by describing how the success of this management process is measured and what data is collected to measure it with.
samsung
:thanx:
Regards,
According to 4.4.6, Operational Controls are necessary, not a procedure. A documented procedure is only necessary "when it's absence could lead to deviations from the OH&S policy and the objectives".
Having said, you have to implement operational controls in order to manage the risk. Operational controls can range from putting up a simple signage/ Do's & Don't's to re-designing an entire process depending upon the risk involved, organization's OHS policy as well as the applicable legal requirements.
If you have identified the hazards and the risk associated with each of the hazards, the next thing to do is to determine the controls necessary to manage the risk within the acceptable limits. These controls are what 4.4.6 talks about. The best of the sources, as Randy pointed out, are none other than the applicable regulations/ rules/ guidelines/ permits/ licenses/ OEM manuals etc. to find out what controls have to be in place to eliminate/ control/ minimise the risk.
Controls can be specified in procedures, work instructions, job descriptions, purchase orders/ specifications, work permits, induction manuals, job orders, Hazard Risk evaluation sheets etc.
Some common examples of operational controls are:
- Regular maint. of equipment/ infrastructure
- Housekeeping
- Hazard warnings/ signage/ Caution boards
- Speed limits
- Periodic testing and calibration of measuring equipment, if it pertains to OHS management,
- Barriers, Hand rails, guards,
- Emergency stop switches
- Availability and access to MSDS, manuals, work instructions etc.
- Exposure and access control
- Exposure limits
- Personal Protective equipments etc. etc.
The list could even be longer.
Hope this helps.
Jen Kirley
Quality and Auditing Expert
It's not mine so I can't attach it, but I can provide a link to the Hydro Tasmania Procedure. Title: Hearing conservation procedure.
It is as Randy said: program controls are generally laid out in policy or procedure, but any procedure can list engineering controls such as the proper position of a guard on a piece of machinery.
darkforce
anyone here have the sample of operation control procedure look like ?
Colin
Here is an example.
  • Contractor rules summary.pdf
samsung
In addition, this page also covers a lot of 'Operational Control Procedures' in the form of regulations/ guidelines for safe work practices.
At the left hand pan, general industrial activities and operations are listed. You may select the relevant activities and find the suggested operational controls.
M Probability vs. Likelihood in OHSAS 18001 Clause 3.21 Occupational Health & Safety Management Standards 13
K OHSAS 18001 - Clause 4.4.3 Communication "...shall be documented..." Occupational Health & Safety Management Standards 5
Raffy OSHA vs. OHSAS 18001 vs. Work Environment - Clause 6.4 Occupational Health & Safety Management Standards 16
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
Q Correspondence between ISO 14001:2015 & OHSAS 18001:2007 ISO 14001:2015 Specific Discussions 2
D I heard that there is no new version of ISO 18001 OHSAS after 2017 version Occupational Health & Safety Management Standards 3
R OHSAS 18001:2007 Section 3 - Controlling Work Place Risks Occupational Health & Safety Management Standards 3
S OHSAS 18001: 2007 Evaluation of Compliance Occupational Health & Safety Management Standards 7
D Key steps to OHSAS 18001 Implementation Other ISO and International Standards and European Regulations 1
drgnrider Is there a specific OHSAS 18001 sign format? Occupational Health & Safety Management Standards 4
S OHSAS 18001 - 4.3.2 Legal and Other Requirements - Working document or template Occupational Health & Safety Management Standards 2
Chennaiite Is Audit of Employee Canteen Food within the scope of OHSAS 18001? Occupational Health & Safety Management Standards 17
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
S OHSAS 18001 Typical Input and Output Examples Occupational Health & Safety Management Standards 4
S OHSAS 18001 Gap Analysis Template wanted Occupational Health & Safety Management Standards 5
SATHYABALARAMAN OHSAS 18001:2007 4.4.1 Top management appointee Occupational Health & Safety Management Standards 8
M IMS - Integrated ISO9001, ISO14001 & OHSAS 18001 Internal Audit Checklist Internal Auditing 5
L OHSAS 18001 Participation and Consultation - Incident investigation under 4.4.3.2 Occupational Health & Safety Management Standards 15
R Does "establish, implement and maintain a procedure" require a Document - OHSAS 18001 Occupational Health & Safety Management Standards 1
S Evaluation of legal compliance to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 18
C OHSAS 18001 and a site visit - All our work is on client sites Occupational Health & Safety Management Standards 4
A R2 Certification vs Self Declaration to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 3
D Integration of ISO 9001 and OHSAS 18001 - Management Manual Occupational Health & Safety Management Standards 5
R OHSAS 18001 & ISO 9001 Implementation - help! Process Maps, Process Mapping and Turtle Diagrams 7
K OHSAS 18001 Scope and Legal & Other Requirements Occupational Health & Safety Management Standards 3
Claes Gefvenberg Done... OHSAS 18001 registration Occupational Health & Safety Management Standards 9
A Multi-Site Certification to ISO 9001, 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
K Why is OHSAS 18001 not an ISO (IOS) Standard? Occupational Health & Safety Management Standards 8
D What is required in a combined ISO 9001, ISO 14001 and OHSAS 18001 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B OHSAS 18001 - Requirements for Auditing Procedure Occupational Health & Safety Management Standards 17
C ISO 14001 and OHSAS 18001 Registrar Auditor Credentials Career and Occupation Discussions 8
K Auditing OHSAS 18001, ISO 9001 & ISO 14001 for 4 Business Units General Auditing Discussions 2
O Requirements under OHSAS 18001 for the Control of Risks Occupational Health & Safety Management Standards 8
T Procedures Cited in OHSAS 18001 Appendix Occupational Health & Safety Management Standards 4
N Does OHSAS 18001 require organization to have AED (Automatic External Defibrillator) Occupational Health & Safety Management Standards 4
S Airborne Survey Legal Compliance - OHSAS 18001 Occupational Health & Safety Management Standards 2
S Logo Marking for Marketing purpose - ISO 9001, ISO 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S OHSAS 18001 Safety Management System (SMS) Implementation Plan Occupational Health & Safety Management Standards 7
E Auditor wants to review our OHSAS 18001 Implementation Programme Occupational Health & Safety Management Standards 5
I ISO 14001 & OHSAS 18001 Questionnaire for Internal Auditor Certificate Other ISO and International Standards and European Regulations 2
S Building and Warehouse requirements of OHSAS 18001 Occupational Health & Safety Management Standards 8
P Risk Rating approaches (OHSAS 18001 - For Office Environments) Occupational Health & Safety Management Standards 6
P Scope Statement Content for OHSAS 18001 Occupational Health & Safety Management Standards 10
W Project for our Risk Management class - OHSAS 18001 Help Occupational Health & Safety Management Standards 6
H Crossing from OHSAS 18001 to ILO OSH Occupational Health & Safety Management Standards 11
JoCam Reputable, UK based Consultant for the Health & Safety standard OHSAS 18001 Consultants and Consulting 14
D ISO 9001, OHSAS 18001, ISO 14001 Management Review Template Document Control Systems, Procedures, Forms and Templates 5
B CB Certify OHSAS 18001:2007 without AB - Why CB no need AB? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
GStough Integrating 3 System Standards - ISO 9001, ISO 14001, OHSAS 18001 Other ISO and International Standards and European Regulations 20
