OHSAS 18001 & ISO 9001 Implementation - help!
rocks
I have recently joined a Company (in PNG) as the SHEC & QA Adminsitrator. Part of my role will be implementing ISO 18001 and 9001 systems forthe business. I have experiences in developing and implementing these ISO systems in previous companies I have worked with. However my issue here is that this organisation is a Corporate Company (with 37 employees) and governs 7 other business groups.(I have illustrated this in the attachment where XY is the organistion am working for and A, B, C etc are the business groups. Business D is ISO 9001 & AS/NZ 4801 certified.) Company XY is planning towards achieving IS0 Certification for both standards in 2015.
I need guidance from expertise on this situation.
1. Where do I start?
2. I understand the the scope will be Company XY, since main function of Company XY is to govern businesses A, B, C etc, how do these businesses fit into the scope of these ISO certification?
I hope I am making myself clear for your feedbacks.
Rocks
K
kgott
Re: ISO 18001 & 9001 Implementation - help!
Rocks
I'll try to help with the last question first. Knowledge of certification scope is not something I know much about but I think all locations can be certified if they all comply and they are all included in the scope of certification audit. You many also want to consider certification for each site so that a failure in one does not affect the others.
Where to start?
Start with a gap analysis of each standard you need to apply to your busienss. Look in the green Post Attachments List at the top of this page for gap analysis tools that others have posted in the past.
Go through each standard and ask how do we currently meet this requirement, what do we do that meets this requirement.
Some things may need to change (tweek) to meet the requirements of the standard. You should find most things the standard requires is being done anyway but probably not documented.
Develop processes and documents to fill the gaps. Again look in the Post Attachments List above to find documents you use to suit your business.
let the process cycle through a few times and then audit them to ensure the process is being carried out the way the documented way says it should be done. Tip, document the process they way its done in reality building in the requirements of the standards that are not currently being done.
You may like to consider using flow charts for describing 'how xyz gets done.' they are good for this. You might like to consider including a brief 'who does what' to make 'what happens' in each flow chart box.
Where something requires much more explanation you may like to either use another flow chart or a text document, to describe how that part of the process gets done in detail.
Hope this helps
Colin
To add to Kgott's answer to the "where do I start" question, I personally always start with the 9001 requirements. This will allow you to determine the processes and the sequence & interactions etc.
Once you have the framework of the system in place you can build in the OHS elements. I am not suggesting you ignore 18001 at first but I usually find it easier to get the QMS in place first.
Jen Kirley
Quality and Auditing Expert
Being corporate can confuse things because of limited responsibility to design and measure performance of production processes, engineering/administrative/personal controls to mitigate safety risks in production etc.
So I was wondering what is the extent of the corporate function's responsibility? Is your site considering a corporate certification that also covers manufacturing sites, or do the manufacturing sites have their own certifications, or are there separate sites at all?
rocks
Hi Jennifer,
Corporate is the parent company and does not trade in its own right. Its primary function is to provide management processes and services that create more value for the individual business units and the group as a whole than the individual business unit can do on their own.
The Corporate intends to go for Corporate Certification as well as spearheading Certification for individual Business Units. B/Unit D is already ISO 9001/HACCP Certified
Below is an overview of the business structure
Corporate (Parent Company)
- B/Unit A (Contractual Mining Services)
- B/Unit B (Construction)
- B/Unit C (Drilling Services)
- B/Unit D (Catering & Camp Management)
Colin
I think the simplest solution is to get separate certifications for each unit and 1 for corporate (if necessary). You could save some money by going down the multi-site route but I think it would get messy.
There is no reason why each unit couldn't share parts of the system like internal audit and management review etc but I would go for independent certifications in this case.
Why not invite a couple of CB's in for a chat? let them give their views on the best route.
DarrenG
Has anyone got a sample manual integrating ISO 9001 and OHSAS 18001 only. I can get fully integrated for 9001, 18001 and 14001.
Thanks,
Q Correspondence between ISO 14001:2015 & OHSAS 18001:2007 ISO 14001:2015 Specific Discussions 2
D I heard that there is no new version of ISO 18001 OHSAS after 2017 version Occupational Health & Safety Management Standards 3
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
S Evaluation of legal compliance to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 18
A R2 Certification vs Self Declaration to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 3
D Integration of ISO 9001 and OHSAS 18001 - Management Manual Occupational Health & Safety Management Standards 5
A Multi-Site Certification to ISO 9001, 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
K Why is OHSAS 18001 not an ISO (IOS) Standard? Occupational Health & Safety Management Standards 8
D What is required in a combined ISO 9001, ISO 14001 and OHSAS 18001 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C ISO 14001 and OHSAS 18001 Registrar Auditor Credentials Career and Occupation Discussions 8
K Auditing OHSAS 18001, ISO 9001 & ISO 14001 for 4 Business Units General Auditing Discussions 2
S Logo Marking for Marketing purpose - ISO 9001, ISO 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I ISO 14001 & OHSAS 18001 Questionnaire for Internal Auditor Certificate Other ISO and International Standards and European Regulations 2
D ISO 9001, OHSAS 18001, ISO 14001 Management Review Template Document Control Systems, Procedures, Forms and Templates 5
GStough Integrating 3 System Standards - ISO 9001, ISO 14001, OHSAS 18001 Other ISO and International Standards and European Regulations 20
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
eternal_atlas Audit of Management Representative Functions (ISO 9001 & OHSAS 18001) Occupational Health & Safety Management Standards 9
J ISO 9001, ISO 14001, OHSAS 18001 Power Plant Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Integration of ISO 14001 & OHSAS 18001 with ISO 9001:2008 REACH and RoHS Conversations 5
F How to Integrate Audits and Audits Schedule - ISO 9001 and OHSAS 18001 Occupational Health & Safety Management Standards 2
A Integrated Manuals that cover ISO 9001, ISO 14001 and OHSAS 18001 Quality Management System (QMS) Manuals 9
D I wish to know about ISO 28000, ISO 14001 and OHSAS 18001 Other ISO and International Standards and European Regulations 7
G Incorporating OHSAS 18001 with ISM and ISO 14001 Occupational Health & Safety Management Standards 13
C OHSAS 18001 vs. ISO 14001 - Differences in Training Occupational Health & Safety Management Standards 5
N Cross-Referencing ISO 9001/ISO 14001/OHSAS 18001 Occupational Health & Safety Management Standards 17
C IMS (ISO 14001/ BS OHSAS 18001) combined Audit Checklist & Schedule ISO 14001:2015 Specific Discussions 1
S Need Integrated Management System Manual (ISO 9001, 14001 & OHSAS 18001) Document Control Systems, Procedures, Forms and Templates 11
D Internal Audit Training Material covering ISO 9001, ISO 14001 & OHSAS 18001 Training - Internal, External, Online and Distance Learning 1
R GAP Analysis for an ISO 9001, ISO 14001 and OHSAS 18001 system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H OHSAS 18001 is not an ISO standard yet. ¯\_(ツ)_/¯ Now it is! March 2018 Occupational Health & Safety Management Standards 102
P Combined ISO 9001, ISO 14001 and OHSAS 18001 Manual and System Quality Management System (QMS) Manuals 8
M Integration of ISO 17025 with TS 16949, ISO 14001 and OHSAS 18001 ISO 17025 related Discussions 8
J Possibility of certifying to IMS (ISO 9001, ISO 14001 & OHSAS 18001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I Combined ISO 14001 / OHSAS 18001 Implementation ISO 14001:2015 Specific Discussions 16
G Health & Safety Executive - ISO 14001 and OHSAS 18001 Confusion Occupational Health & Safety Management Standards 6
G Hazard Identification Categories - ISO 14001 vs OHSAS 18001 Occupational Health & Safety Management Standards 3
M Integrating ISO 14001 & 9001 into OHSAS 18001 Occupational Health & Safety Management Standards 65
T ISO 9001, ISO 14001, ISO 27001 & ISO 27002 and OHSAS 18001 Standards Gap Analysis General Auditing Discussions 39
L Integrated (ISO 9001 & 14001 and OHSAS 18001) Management Review Meetings Management Review Meetings and related Processes 50
Colin Integrated Systems Assessment for ISO 9001 / ISO 14001 / BS OHSAS 18001 Other ISO and International Standards and European Regulations 19
W Auditing multiple standards - TS 16949, ISO 14001 & OHSAS 18001 General Auditing Discussions 12
Antonio Vieira World Wide Certifed Power Plants study - ISO 9001, ISO 14001 and OHSAS 18001 Registrars and Notified Bodies 10
O Videos on OHSAS 18001 and ISO 14001 EMS either in VHS or DVD format Occupational Health & Safety Management Standards 2
H What are the Current OHSAS 18001 & ISO 14001 Revisions & Combined Systems Various Other Specifications, Standards, and related Requirements 37
S ISO 14001 and OHSAS 18001 powerpoint .ppt presentations Training - Internal, External, Online and Distance Learning 3
S Making an Environmental Park - What it should contain? ISO 14001 & OHSAS 18001 Occupational Health & Safety Management Standards 11
G Examples of Integrated ISO 14001:2004 and OHSAS 18001: 1999 policy manuals Occupational Health & Safety Management Standards 13
F I need templates for ISO 9000, ISO14001 & OHSAS 18001 Occupational Health & Safety Management Standards 5
C Will OHSAS 18001 will follow the same revision trail as ISO 14001? Occupational Health & Safety Management Standards 5
