OHSAS Cl 4.4.3.2 & 4.4.6a - Please guide me in its interpretation
Z
Zubin
Hi, Thought to address a similar situation I am in now..
We are proceeding with the certification - a combined certification on OHSAS and EMS. We are doing the entire certification process of our own and dont have a consultant in between. After the Aspect - Impact - Risk assessment, we started off with procedures. Listed down all the required procedures as per standards. Almost alla re ok, but 2 of them seems little difficult to understand. I request the experienced members to guide me in this context
1. Clasuse 4.4.3.2 (OHSAS) - Reporting: A procedure shall be establisehd for reporting. I can understand that an incident reporting mechanism is required and the procedure by which it works needs to be documented, but is it all what is needed here??
2. Clause 4.4.6.1(OHSAS) - Design and Engineering control. How far wil be this different from Operational control?. Is it mandated to have a separate procedure or shall it be a combined one with Operational Control?
Appreciate if you could spare some time in helping me..
Thanks in Advance
Zubin
harry
Welcome to the Cove.
I moved your post to a new thread to enable it to receive maximum attention.
I believe you are referring to Cl 4.4.6a instead of 4.4.6.1 as posted. I will leave it to the experts in this area to extend their help. Meanwhile, check the OHSAS forum for previous discussions. Example: 4.4.3.2 and 4.4.6
somashekar
Thanks in Advance
Zubin
Hi Zubin.
4.4.3.2 is about participation and consultation. I see no reporting here. It is about your OHSAS implementation and operation, concerning participation and consultation.
How you :
1. get your workers to be active and involved people in your OHSAS
2. consult with contractors when any changes could effect the contractor's OHS
needs to be established and implemented
4.4.6.a) is about the operations controls that are established in the implementation and operation of your OHSAS, for those operations and activities where hazards are identified and risks are managed by these controls.
Design and engineering controls are the OHSAS planning activities where you are to determine controls based on the top down hierarchy of ...
Elimination:
Do not do that operation or activity thereby get rid of the hazard and risk.
If not then ...
Substitution:
Do an other operation or activity in place of the one having some hazards and risks, thereby those hazards and associated risks gets removed and some new and lesser hazards and risks are coming in.
If not then ...
Engineering controls:
Bring in some foolproofing, sensing and activation to prevent harm, hands free operation, any other innovative and practical solution so as to manage risks.
If not then the rest as said in d) and e) and these two are mostly applied together.
samsung
OHSAS does not stipulate any requirement for incident reporting. However, it does require a procedure "to record, investigate and analyse incidents" but not necessarily a documented one although a documented procedure is always better than a non-documented one. You may wish to refer to the attached document for guidance on incident investigation and reporting.
2. Clause 4.4.6.1(OHSAS) - Design and Engineering control. How far will be this different from Operational control?. Is it mandated to have a separate procedure or shall it be a combined one with Operational Control?
Design controls are the built-in controls that a machine/equipment/building must have and are considered at the time of system (plant) design. e.g. an industrial fan equipped with a safety guard and/or a silencer, a hoist with 1.5 times the load bearing capacity than the max. working load, car windshields with 'toughened safety glass' etc. etc. Design controls are generally mandated by the law or standards.
Engineering controls are infact physical & technological controls applied when the existing design controls are not sufficient to mitigate/ control the risk and additional physical controls are required to be put in place. e.g. speed retarders/ beakers on the roads, hand railings, toe guards, putting up water sprinklers along haul roads, sound enclosures, cooling & ventilation systems etc.
Operational Control means controls applied to operations/ activities where hazards have been identified. They can be administrative or engineering, signage & warnings, access control, use of safe work procedures/ MSDS etc.
Z
Zubin
Thanks Somashekar,
We purchased the standard IS 18001:2004 from BIS (Bureau of Indian Standards). Now I coudlsee that there is marked didfferences in the clauses. For eg: 4.3.1 in the BIS standard refers to Initial OHS Review, which I am sure is not part of the standard as a separate clause. While 4.4.3.2 in BIS refers to "Reporting" (quote: The org shall establish, implement and maintain documented procedures for relevant and timely reporting of .....) but in the other ones it is Participation and consultation. Can this be possible?. I understand that OHSAS being a non ISO standard, there can be different interpretations. But how far is this acceptable?. Are we using a wrong standard (guidance)
As a new entrant may be I am thinking too much...Kindly give your suggestions/guidance..
Zubin
Z
Zubin
Thanks Samsung,
I got a fairly good understanding now. I am stariting off now. But the basic question of BIS Standard or Gudelines for OHSAS is still persisting. I will wait for the answers.
Right now, the below are the procedures which are identified.. Hope this will suffice and will justify..
1 Hazard Identification, Risk Assessment and Risk Control
2 Identification of Legal and Other requirements
3 OH&S Objectives, Targets and Programs
4 Roles, Responsibility, Accountability and Authority
5 Competence Training and Awareness
6 Communication - Internal and External
7 Incident Reporting and Investigation
8 Control of Documents and Records
9 Operational Control
10 Design and Engineering control
11 Emergency Preparedness and Response
12 Performance Measurement and Monitoring
13 Calibration and Maintanance of Measurement equipments
14 Evaluation of Compliance (Legal and Others)
15 Accident, Incident Non Confirmance, corrective action and preventive action
16 Internal Audit and Management Review
Thanks once again,
Zubin
Z
Zubin
Thanks Harry for guidance.. Have a little confusion on the respective clauses in the guidelines we have purchased..
somashekar
Thanks Somashekar,
Zubin
You are just doing fine. These mix-up do happen and then clarity makes things easy.
You must be pursuing towards certification to OHSAS 18001:2007 in which case this stated OHSAS standard is the standard to align with. This and the BIS standard IS18001:2004 can differ as they are from seperate bodies, though they contain common elements.
Z
Zubin
Yes we are going for OHSAS 18001:2007 and the BIS standard we purchased is IS18001:2007. Now I feel I shall get one direcly from OHSAS project group or so to avoid confusion..
Zubin
samsung
I got a fairly good understanding now. I am starting off now. But the basic question of BIS Standard or Guidelines for OHSAS is still persisting. I will wait for the answers.
OHSAS 18001:2007 is the only standard you must concentrate on since it's a certifiable standard whereas IS 18001:2004 is a specification (like previous version of OHSAS) although you may seek guidance from other documents such as ILO-OSH, IS 18001:2004, ILO codes of practices etc.
I would advise you to have a copy of OHSAS 18002:2008 which do contain all the requirements of OHSAS 18001 plus a lot more on how to implement it.
Thanks.
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
B Multi-site certification (IAF MD1) - for 9001, 14001, OHSAS/45001 ISO 14001:2015 Specific Discussions 16
Q Correspondence between ISO 14001:2015 & OHSAS 18001:2007 ISO 14001:2015 Specific Discussions 2
D I heard that there is no new version of ISO 18001 OHSAS after 2017 version Occupational Health & Safety Management Standards 3
R OHSAS 18001:2007 Section 3 - Controlling Work Place Risks Occupational Health & Safety Management Standards 3
x-files Naming convention: OHSMS or OHSAS Occupational Health & Safety Management Standards 13
S OHSAS 18001: 2007 Evaluation of Compliance Occupational Health & Safety Management Standards 7
D Key steps to OHSAS 18001 Implementation Other ISO and International Standards and European Regulations 1
drgnrider Is there a specific OHSAS 18001 sign format? Occupational Health & Safety Management Standards 4
S OHSAS 18001 - 4.3.2 Legal and Other Requirements - Working document or template Occupational Health & Safety Management Standards 2
Chennaiite Is Audit of Employee Canteen Food within the scope of OHSAS 18001? Occupational Health & Safety Management Standards 17
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
S OHSAS 18001 Typical Input and Output Examples Occupational Health & Safety Management Standards 4
S OHSAS 18001 Gap Analysis Template wanted Occupational Health & Safety Management Standards 5
SATHYABALARAMAN OHSAS 18001:2007 4.4.1 Top management appointee Occupational Health & Safety Management Standards 8
M IMS - Integrated ISO9001, ISO14001 & OHSAS 18001 Internal Audit Checklist Internal Auditing 3
S How does each element of OHSAS contribute to management of work place safety & health Occupational Health & Safety Management Standards 7
L OHSAS 18001 Participation and Consultation - Incident investigation under 4.4.3.2 Occupational Health & Safety Management Standards 15
R Does "establish, implement and maintain a procedure" require a Document - OHSAS 18001 Occupational Health & Safety Management Standards 1
S Evaluation of legal compliance to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 18
C OHSAS 18001 and a site visit - All our work is on client sites Occupational Health & Safety Management Standards 4
A R2 Certification vs Self Declaration to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 3
D Integration of ISO 9001 and OHSAS 18001 - Management Manual Occupational Health & Safety Management Standards 5
R OHSAS 18001 & ISO 9001 Implementation - help! Process Maps, Process Mapping and Turtle Diagrams 7
K OHSAS 18001 Scope and Legal & Other Requirements Occupational Health & Safety Management Standards 3
Claes Gefvenberg Done... OHSAS 18001 registration Occupational Health & Safety Management Standards 9
A Multi-Site Certification to ISO 9001, 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
J What is Exposure Assessment Strategy - Annex D of OHSAS 18002? Occupational Health & Safety Management Standards 6
K Why is OHSAS 18001 not an ISO (IOS) Standard? Occupational Health & Safety Management Standards 8
D What is required in a combined ISO 9001, ISO 14001 and OHSAS 18001 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B OHSAS 18001 - Requirements for Auditing Procedure Occupational Health & Safety Management Standards 17
C ISO 14001 and OHSAS 18001 Registrar Auditor Credentials Career and Occupation Discussions 8
K Auditing OHSAS 18001, ISO 9001 & ISO 14001 for 4 Business Units General Auditing Discussions 2
O Requirements under OHSAS 18001 for the Control of Risks Occupational Health & Safety Management Standards 8
T Procedures Cited in OHSAS 18001 Appendix Occupational Health & Safety Management Standards 4
N Does OHSAS 18001 require organization to have AED (Automatic External Defibrillator) Occupational Health & Safety Management Standards 4
S Company Structure for OHSAS Certification - Holding Company with Subsidaries Occupational Health & Safety Management Standards 5
S Airborne Survey Legal Compliance - OHSAS 18001 Occupational Health & Safety Management Standards 2
S Logo Marking for Marketing purpose - ISO 9001, ISO 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S OHSAS 18001 Safety Management System (SMS) Implementation Plan Occupational Health & Safety Management Standards 7
E Auditor wants to review our OHSAS 18001 Implementation Programme Occupational Health & Safety Management Standards 5
I ISO 14001 & OHSAS 18001 Questionnaire for Internal Auditor Certificate Other ISO and International Standards and European Regulations 2
S Building and Warehouse requirements of OHSAS 18001 Occupational Health & Safety Management Standards 8
P Risk Rating approaches (OHSAS 18001 - For Office Environments) Occupational Health & Safety Management Standards 6
V Internal Audit Material for OHSAS in ppt wanted Occupational Health & Safety Management Standards 0
P Scope Statement Content for OHSAS 18001 Occupational Health & Safety Management Standards 10
J OHSAS 18001 Clause 4.4.6 Operational Control Example Procedure Occupational Health & Safety Management Standards 9
W Project for our Risk Management class - OHSAS 18001 Help Occupational Health & Safety Management Standards 6
H Crossing from OHSAS 18001 to ILO OSH Occupational Health & Safety Management Standards 11
