Old and New Primary Standards show a difference between them
L
lucasso
Hello all,
I've been searching the forum for two hours and was not able to find a similar topic. So, this is the problem:
Our laboratory had a primary (certified) reference material for a few years. It was bought at and traceable to NPL (UK). As the old one was coming to it's end, recently we bought a new one, also traceble to NPL.
When we compared the two standards in our laboratory, they showed a few percent difference between them.
The difference is bigger than the uncertainty stated on the certification of the CRM.
We also participated in inter-laboratory comparison measurements with the old CRM, so we don't think it is off.
If we start using the new standard as it is, we will face a significant few percent step in our measurements.
Any thought and suggestions, please.
BradM
Hello there!
I see that you compared against the uncertainty stated on the standard certificates. However, I see no mention of any uncertainty of the systems in your lab. I would think that whatever methodology you are using has error in it also, would it not?
It may not be much, but might be enough to create differences between the two samples. :)
L
lucasso
Thank you.
Yes, both suggestions seem reasonable. There is a possibility that both standards are not accurate enough and have different values.
Also, it is possible that the difference is because of our methods.
I also would like to ask a similar question:
Let's say that the difference is tolerable, it is within uncertainty limits, eg:
Both were bought as 50units ±10%.
When measured in our lab:
Old CRM: 51units
New CRM: 49units.
The difference is much smaller than our measurement uncertainty, which is about 20%, but the move from the old to the new one will still create a small drop in measurements.
Are there accepted and established ways to deal with this?
Hershal
Metrologist-Auditor
Reference materials are a bit more challenging than for a simple thing like a primary 1.1VDC standard. For those who may not know me, I was joking a bit there.
Anyway, the original post suggested that the second material may not have been that far off, unless I misunderstood the statement.
If that statement is correct then the first obvious question is what changed at the lab.
However, it is a reference material, so as an accreditation assessor, my first question would be if the two were from the same lot. If they are not, then a difference is expected.
Next, since this is likely not traceable to SI, then also look at the various other requirements of ISO/IEC 17025:2005 Clause 5.9.1, and assure at least a few of those requirements are in place.
BradM
If you are using the actual values of the standards in your baselining activity, why would there be a concern as to the direction of the difference in value? Or, given the particular sample, does that indicate some level of degredation in the standards?
L
lucasso
The concern is not about the direction. The concern is about the fact that there will be a step in the measurements. Let's say we measure a parameter of one item on daily basis and the results are:
45.6 45.7 45.6 45.5 45.6 etc. (±20%)
After we start using the new CRM, it will change to something like this:
43.4 43.5 43.4 43.6 etc (±20%)
It is possible. Although we did participate in interlaboratory measurements with the old one. The other is brand new.
step30044
It doesnt make a difference you are still within the accepatable limits of the new CRM's actual value. I would just list the new standard value in your records.
L
lab_analyst
I have similar problem. Used an old standard as a calibration standard, then used the same standard to verify the calibration. Then we came to know that we need to have a second standard (to verify calibration), so we bought new standard. Both traceable to NIST. Anyway after calibration with new standard, when we tested the old standard (as a verification) the result is quite off. I am sending to another lab for cross check. Any thoughts on this?
Hershal
Metrologist-Auditor
Yes, make sure you keep the results, then compare them including the En score if possible.
Download APLAC PT 001, and in that document are the formulas for calculation of En scores. This will help you determine where an issue may be. You can also document it as an ILC but whether that helps with the next assessment I can't say, your AB will have to determine that.
M Why are EU harmonized particular standards so old & out-of-date? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Interesting Discussion Curious old drawings about electrical shock and safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Marc Interesting Discussion The periodic table is 150 years old - March 2019 Coffee Break and Water Cooler Discussions 3
Marc Old Registered Visitors "Pruned" from the Database - 20180916 Forum News and General Information 0
Marc 200-year-old museum in Rio de Janeiro Destroyed by Fire - 2 SEPT 2018 World News 2
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
Marc Adventures in Design Quality Assurance - Two-week-old Pixel 2 XL displays World News 0
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Canada License Amendment - Old Product to New Product Canada Medical Device Regulations 2
B Old GD&T Symbol "~" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Sources for Searching Old Electronic Parts Specs (Counterfeit Inspection) Quality Manager and Management Related Issues 3
Q Modifying an old printed record? ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Customer wants PPAP on Old Parts to New Standards APQP and PPAP 8
A Technical File Maintenance - Old generation product EU Medical Device Regulations 4
A PUWER (Provision and Use of Work Equipment Regulations) and old machines (UK rules) Occupational Health & Safety Management Standards 4
E I'm looking for old publications of European Quality in pdf Book, Video, Blog and Web Site Reviews and Recommendations 2
J How to Retrofit an old, manual CMM Calibration and Metrology Software and Hardware 5
C Upgrading an old Supermicrometer General Measurement Device and Calibration Topics 3
S Old Medical Device Software Submission Guidance from 1998 Other US Medical Device Regulations 8
G Not quite old news: Statement of Applicability IEC 27001 - Information Security Management Systems (ISMS) 3
R IMDS time frame submission for a very old product APQP and PPAP 1
M Old software and EN 62304 - ECG software for the display of ECG IEC 62304 - Medical Device Software Life Cycle Processes 2
W Where to find the Daimler DBL 6992 10 new (old) standard Customer and Company Specific Requirements 1
P Performance Qualification of old Rapid Mixer Granulator Qualification and Validation (including 21 CFR Part 11) 2
Q IQ Requirements for Old (10 yrs) Commissioned Equipment Qualification and Validation (including 21 CFR Part 11) 2
R Covegratulations to The Cove: 18 years old! Covegratulations 3
N FDA Aspects - No Improvements to 12 Year Old Software ISO 13485:2016 - Medical Device Quality Management Systems 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Old MSDS Sheets vs new HCS Standard - Format Requirements Manufacturing and Related Processes 18
H Digging Up Bones - Inspector Retrieving Very Old Inspection Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V Old 510(k) with no Indication Statement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Retrospective DHF for an old non-registered device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
Randy Looky here - Check out my 9-month old Great-Grandson Hayden Coffee Break and Water Cooler Discussions 4
G Help with an old Spectrum 1000BX FTIR unit - User Manual wanted Manufacturing and Related Processes 2
M AS9100A (old revision) - Required C=0 sampling plans if sampling was used? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Using Curve Fits and Predictions in place of good old Measurements General Measurement Device and Calibration Topics 3
N What to do about very old MSDS Sheets Occupational Health & Safety Management Standards 24
C Hazards of Old Electronics Quality Manager and Management Related Issues 9
D Registrar Requesting Copies of Old Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V We put Old plating spec on supplier prints and need to PPAP to Customer. APQP and PPAP 1
G Old Medical Device Equipment - Compliance with New or Old Standard - What to do? Other Medical Device Related Standards 3
R PPAP requests for old parts that pre-date your PPAP Process APQP and PPAP 2
