One-factor and multiple-response Minitab optimization
Hi.
I have an application in which I have a dataset (> 100,000) with the following variables: velocity (m/min), production (kg), scrap (kg) and consumption (kWh). I'd like to use Minitab to optimize multiple responses. My independent variable is velocity (X) and the others are response variables. I need to know which velocity delivers: higher production (Y1), lower scrap (Y2) and lower consumption (Y3).
In the table below some data to exemplify the database:
Code:
Velocity Production Scrap Consumption
1760        1934    237    1960
1760        1934    0        1728
1760        1944    0        1739
1760        1932    0        1732
1760        1951    0        1734
1760        1928    287    2024
1760        1967    128    1876
1760        1949    0        1730
1760        1938    0        1727
1761        1938    0        1877
1761        1925    155    1877
1760        1923    0        1751
1760        1900    0        1723
1765        1922    0        1723
1765        1910    219    1963
1765        1954    162    1899
1770        1944    0        1728
1770        1942    0        1727
1770        1931    33      1749
1770        1922    0        1707
1770        1923    0        1698
1770        1906    0        1697
1770        1918    0        1715
1770        1920    0        1709
1769        1920    0        1710
1770        1926    0        1702
I checked Minitab's Optimization tool, but what I've seen it depends on 2-factors and in my case I only have one-factor (velocity) and multiple response.
I would like to know how I can do this analysis in Minitab if anyone can help me I appreciate it.
Regards,
A.Berg
Hi.
Code:
1760        1934    237    1960
1760        1934    0        1728
1760        1944    0        1739
1760        1932    0        1732
1760        1951    0        1734
1760        1928    287    2024
1760        1967    128    1876
1760        1949    0        1730
1760        1938    0        1727
1761        1938    0        1877
1761        1925    155    1877
1760        1923    0        1751
1760        1900    0        1723
1765        1922    0        1723
1765        1910    219    1963
1765        1954    162    1899
1770        1944    0        1728
1770        1942    0        1727
1770        1931    33      1749
1770        1922    0        1707
1770        1923    0        1698
1770        1906    0        1697
1770        1918    0        1715
1770        1920    0        1709
1769        1920    0        1710
1770        1926    0        1702
Regards,
A.Berg
Did you manage to get help with this? I am looking for a solution to a similar problem.
Thanking you in advance.
Laura
I did not see the original post, but Minitab can optimize that problem. You have to perform the regression on all three variables simultaneously first.
I Multiple Comparisons for a Random Factor Using Minitab Software 2
P Is the second factor authentication (2FA) required for external users? Qualification and Validation (including 21 CFR Part 11) 1
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
S Is Human Factor Testing required as part of Design Control Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C FOS (Factor of Safety) Medical Device Other Medical Device and Orthopedic Related Topics 4
E IEC 60601-1 Tensile Load Safety Factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E GR&R ANOVA 3rd Factor for Fixture Nests Using Minitab Software 3
N 3 factor - 3 level experiment with DoE and Minitab Using Minitab Software 10
S Human Factor Summative Study Class III Device RA Checklist wanted Human Factors and Ergonomics in Engineering 2
M DOE: Significant factor or not Using Minitab Software 2
F Can be several measurement in a repl considered as nested factor in Minitab analysis Using Minitab Software 14
A Coverage factor in calibration certificate for a multimeter General Measurement Device and Calibration Topics 4
M Taguchi Analysis of Discrete Factor Using Minitab Software 10
N Minimum Design factor for CE Marking for machinery CE Marking (Conformité Européene) / CB Scheme 2
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
Z A DOE in Minitab - 3 factors and 3 levels for each factor Using Minitab Software 12
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
B DOE Question: 3 factors with 2 levels and 1 factor with 3 levels Six Sigma 2
Z Help with running 3 factor DOE factor optimization Using Minitab Software 2
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
P How to analyze DOE: 2 Factor, 4 Level Experiment Six Sigma 7
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
M Multi-factor Anova with Minitab Using Minitab Software 1
K Human Factor Assessment for IRB (Institutional Review Board) Approval? EU Medical Device Regulations 7
L DOE with 2 factors (3,4 levels) and optimized factor Using Minitab Software 12
P Multi-factor Anova with Minitab Using Minitab Software 11
R What is a Z Value/Factor and where is it most useful? Statistical Analysis Tools, Techniques and SPC 4
T 4 Factor Optimization using Minitab Using Minitab Software 7
I How GUM Uncertainty is calculated and where I locate the multiplication factor b Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Filled examples of a Factor Tree (PDCA-FTA) Analysis or a Training Document wanted Problem Solving, Root Cause Fault and Failure Analysis 2
N Test for Equal Variances - Two factor data set - Minitab Using Minitab Software 3
S Surface Finish - Conversion factor to transform Rz Jis in Rz Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Influence of the Coverage Factor - Worksheets based on the Average and Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
T Setting up a Standard Experimental Plan for Food where Factor Levels are Different Statistical Analysis Tools, Techniques and SPC 2
C DoE and ANOVA - 4 factor and 3 levels Taguchi design with 2 replicates Using Minitab Software 14
C Design of Experiments or Factor analysis using existing data Quality Tools, Improvement and Analysis 7
Y Acceptable Fatigue Safety Factor for Testing Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 2
Marc TV Viewing Distance Factor After Work and Weekend Discussion Topics 9
M Control Chart for Dependent obs - One factor for each category weekly Statistical Analysis Tools, Techniques and SPC 7
C What can I treat as an input factor in Minitab? Using Minitab Software 38
R What's the cause of tailing factor in High Performance Liquid Chromatography (HPLC)? General Measurement Device and Calibration Topics 6
P Difference between Fault Tree and Factor Tree Analysis Quality Tools, Improvement and Analysis 1
B Calculating Dissipation Factor (Df) for Air Capacitor Standards Reliability Analysis - Predictions, Testing and Standards 2
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
D Minitab DOE - 4-factor, 2-level, 8 trial, level IV fractional DOE help needed Using Minitab Software 5
R One Factor - Determining if Temperature is a contributing factor Six Sigma 9
