One-Time parts separate from QMS?
Russ
We have an ISO9000 certification. We do quite a few one part job shop things here along with our regular production. Is there any reason why we could not separate those small 1-2 part lots into a streamlined "One-Off" process?
Reg Morrison
Actually you have a certification to ISO 9001 (not ISO 9000).
It is a mistake to think parts should be run outwith of a QMS. The key is to have agile, lean, cost effective processes WITHIN the QMS to run the low quantity orders.
Quality processes have to be scalable and adaptable to the needs of the customer and product.
somashekar
You do quite a few one part job as you say.
So I am sure you have a system in place just as much necessary for one-off.
The process is no different but for the scale of system operations.
By separating., tell us what differently you wish to do, which seems to bother you .....
There is no reason why you could not separate those small 1-2 part lots into a streamlined "One-Off" process, as long as you aim and meet the customer requirement and assure quality. This one-off process will simply be within your QMS operation.
Russ
Not wanting to run these outside the system just unsure how to streamline and wondering if anyone else has done this and maybe an example. I know it has to be simple or it will never work here but will be ignored.:frust:
John Broomfield
Russ,
You choose how to define the scope of your management system; what services and products to include and exclude.
You can eliminate this service from the scope of your certification.
The bigger question is assuming that quality services and products cost more than the alternative.
John
somashekar
John.
There is nothing to say that the one-part job is not in the scope of the certified QMS.
The questions seems simple and straight.
Can they implement two processes, one that covers small 1-2 parts and other perhaps the volume parts. Perhaps the OP is running into difficulty in certain processes of their QMS that they have more aligned with volume parts.
Touching the scope here perhaps is deviating.
John Broomfield
Somashekar,
Deviating from what?
The scopes of the management system and its certification are determined by the organization provided the certification scope is no larger than the scope of the management system.
And, I agree, that the management system's processes and controls should be tailored according to the needs of the customer as a result of planning (7.1).
For some reason the latter seems not to be happening.
Perhaps Russ will advise.
John
Ninja
Looking for Reality
Hi Russ,
As John mentioned, you CAN run these outside of the QMS...but I'm not sure why you would do so.
Run them outside of SPC, CpK and other things built for an ongoing production line, sure. But there is no reason to run outside of your QMS.
Example: If the one-off part ships and the customer complains about it...how would you handle the complaint? The customer feedback would go right into your QMS processes wouldn't it?
It is easy enough to document that jobs meeting {X criteria} will be handled "this way", totally within your QMS.
Not knowing what you're doing, so drawing from my own one-off things instead, it could be a single document defining how job-shop items are handled. It does not have to be a whole suite of procedures.
Picture a single document stating that
"Short run fabrication as defined by the Production controller {or equivalent} shall be handled as follows: ...."
(and remember that it is always best to have a positive record that 'this job' was defined as short-run....a $10 Rubber Stamp "Short-Run" and an initial on the job ticket would get it done)
It doesn't need to be complicated.
Jen Kirley
Quality and Auditing Expert
Job shops need the QMS to cover the "onesies and twosies" at least as much as places who make thousands of assembly line products because there is no room for error.
But process realization does not need to be difficult. A work order/traveler can start with a template and be filled out to contain all of the specific criteria for receipt inspection, set up, first article and final inspection criteria, and even special shipping instructions. The work order/traveler can have blanks for responsible persons to sign completion and acceptance, plus which instruments were used to measure or test the produced items. The work order/traveler can then be filed by customer name along with the PO, raw material invoices, CofAs, prints etc. plus whatever other communication took place, to refer to later as needed. As always, if there are changes to the criteria in the work order/traveler I would expect them to be approved by a person with defined authority.
A central list of approved suppliers and customer satisfaction data should still be used, and corrective actions, if any, should refer to the customer name/work order number from an index, etc. for tractability's sake.
In this way you can avoid making a bunch of, or long and complicated procedures and test/inspection methods. Filing can be largely centralized. All of the standard and customer requirements can be met and you can pull out these files for auditors who ask about purchasing information, inspection criteria and results, etc.
I hope this helps!
Russ
Hi Russ,
Thanks! I was kinda thinking along those lines so I believe I will do just that. I want to keep them in the QMS, now I just have to come to an agreement here on the content.
Thanks to all for your input, it really helped me think it through!!!!:applause:
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
S Why do suppliers submit bad parts // Quality Incoming Inspection Supplier Quality Assurance and other Supplier Issues 12
M PCB polymeric parts marking RoHS, REACH, ELV, IMDS and Restricted Substances 0
L CQI-9 Special Process: Heat Treat System for Sinter parts IATF 16949 - Automotive Quality Systems Standard 0
Y Disposition of First/Last-Off Parts IATF 16949 - Automotive Quality Systems Standard 3
H Electronic Replacement parts need CE? CE Marking (Conformité Européene) / CB Scheme 0
R DCMA Sampleing for CAI Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
R Aviation Spare Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L PACCAR Parts Supplier Portal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Patient connection and accessible parts - enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
B Pressure containing and pressure controling parts for ball valves Oil and Gas Industry Standards and Regulations 0
T Counterfeit parts training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
Q AS9100 Counterfeit Parts Prevention/Mitigation Work Instruction? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Spare parts of medical device need CE mark? EU Medical Device Regulations 0
G Injection Molded Parts in Verification & Validation Other Medical Device and Orthopedic Related Topics 3
bryan willemot Chain of custody form for counterfeit parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Cleaning Process for Delicate Parts Manufacturing and Related Processes 4
C Mistake Proofing Winding Direction Stamped Metal Parts Manufacturing and Related Processes 8
M Is PPAP suitable for Inhouse parts? Manufacturing and Related Processes 4
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S EU MDR-Replacement Parts when not manufacture is not yet EU MDR compliant US Medical Device Regulations 2
P IMDS Multiple parts RoHS, REACH, ELV, IMDS and Restricted Substances 6
E How to isolate multiple APPLIED PARTS IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
H Better to retain previous made parts or one part that is perfect Reliability Analysis - Predictions, Testing and Standards 2
K Looking for a tape to perform cross hatch test on powder coating parts Reliability Analysis - Predictions, Testing and Standards 3
A Are defective returned spare parts to be considered as a complaint? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
G Lifecycle / Expected Service Life of Steel Parts Other Medical Device and Orthopedic Related Topics 5
G Shipping Validation of Non-Sterile Parts? Other Medical Device and Orthopedic Related Topics 9
L En 62368 How to complete with incomplete parts details CE Marking (Conformité Européene) / CB Scheme 4
R MSA on set of parts with low variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
H Project management for automotive parts IATF 16949 - Automotive Quality Systems Standard 7
Q BMW Supplied Parts Quality Management -> Is there any new supplier quality manual? Customer and Company Specific Requirements 0
M Declaration of Conformity and Spare Parts EU Medical Device Regulations 0
T Accessible metal parts connected to secondary ground IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Metal parts bonding/grounding on Class II, internally powered with functional earth? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Flammability requirements for applied parts as per 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K Initial capability studies on similar parts APQP and PPAP 7
Evelyn7E The fastest way to get supplier to ship good parts to you Supplier Quality Assurance and other Supplier Issues 10
B Cl. 9.2 - Moving parts - Applicable only to machinery? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B How to test operator to see if they can catch the defective parts? Manufacturing and Related Processes 8
P Interchangeable/alternative parts in BOM (medical device) Manufacturing and Related Processes 4
T Is handling chemically treated parts safe? RoHS, REACH, ELV, IMDS and Restricted Substances 18
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
aleexander Grounding of metallic accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
