CarolX said:
Several models are now available for use on shop floor. But if yours is an older piece of equipment, I would reccomend against it.
Yes, you should check with the manufacturer. If you stray outside the specified temp, humidity and/or contamination borderlines they will not guarantee that the machine provides you with correct results, and you may also wear the machine down much to fast.
The latter is particularly important if your CMM utilizes air cushion bearings.
Slightly
but here's what happened to me with a CMM (in a controlled environment):
On one othewise pleasent morning the machine siezed in one axis during operation. I mean, it
really got stuck! Assuming an air bearing had given up I uttered a few unprintable words and called the manufacturer. A service bloke turned up and we had a hard time releasing the siezed bearing (In the end we had to resort to brute force). To my surprise the machine was fully functional when we got it loose.
What on earth was wrong??? The bearing was obviously not damaged. On further examination we found some kind of dried smear on the bearing surface, in spite of the fact that it had been cleaned the previous day. Now what??? Another clue turned up: Small black thingies inside the machine. Mouse poop!
We had mice in the CMM :mg:
Well, the smear was not poop, but it turned out that the confounded rodent had chosen that spot to take a leak. Mouse pee! On the bearing surface. That bearing needed 0.005mm of air to run, and the mouse had beaten that.
Soon afterwards a rat trap snapped in the night, and we plugged some well hidden holes in the walls. Calm was restored.... But let me tell you good people: That was one very expensive rodent
/Claes
