Opening Up Tolerances - We have over 6000 live drawings - help please
Sentinel
I work for a company and we have over 6000 live drawings. We have recently reviewed the general tolerance / open tolerance on the drawings to open it up, because the previous tolerances were unrealistic and just way too tight.
To up-issue every drawing individually is a huge task and would be very time consuming for our limited resource.
Is there a quick way that we could issue something to override the general tolerace box on the drawing and apply the relaxed general tolerance whilst failling in line with good configuration practice?
Any help, advice or ideas would be much appreciated.
Thank-you.
DrM2u
Thank-you.
This could probably involve an engineering change or similar, depending on what controls you have in place. The change request can be broad enough to encompas all drawings assuming that these are internal drawings and do not require customers' approvals. In such an instance the change can specify a general tolerance change across the board. Another approach to consider is creating a 'design specifications' document that will allow you to specify general tolerances and only special tolerances on the individual prints. This is along the lines of Carol's suggestion. You could state that the new document supersedes the title block tolerances. For example GE has such a manual that specified tolernaces based on dimensions, processes, finish, defects, etc.
You are a little stuck if the changes require customers' approvals. In such a case you'll have to follow your customers' guidelines.
Hope this helps a little.
Caster
An Early Cover
....We have recently reviewed the general tolerance / open tolerance on the drawings to open it up, because the previous tolerances were unrealistic and just way too tight.....
Wow good for you!
"Tight specs loosely enforced are the death of quality."
I quote this all the time, but I can't recall where I got it? Was it Juran?
Sentinel
Thank-you for your suggestions. The supplemental specification seems a good way forward I think. I am talking to our 3rd party assessor along these lines.
We are the definition of tight specs loosely controlled, when they don't need to be tight in the first place!!
P
Phil Fields
Thank-you.
By overiding the general tolerance block, how do you know that you will not open up the tolerance too much? Could this possilby result in quality issues?
Phil
Sentinel
Phil,
We have considered this, and it still remains a slight risk. The majority of components we have an issue with, have specific tolerances on the key dimensions which affect the fit or the way we interface product.
The fact that suppliers supply product away from this is another topic. We are fortunate in that we still have goods inwards inspection which does capture these issues, and we are now starting to manage suppliers properly.
I am new to the company and my remit from the Directors is to get us back working to drawing. Hence the original question, as at the moment, we end up raising any number of concessions.
Thanks.
E Responsibilities opening new markets outside EU Medical Device and FDA Regulations and Standards News 0
M Quality checklist for opening a second location Document Control Systems, Procedures, Forms and Templates 5
Marc Problem Opening Attachments Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 4
M Apply for a job when no opening is posted? Career and Occupation Discussions 64
R Opening pressure of one-way valve in anaesthetic workstation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
shimonv Re-Sterilizing a Device which requires Re-Opening and Repair EU Medical Device Regulations 3
Marc Opening certain Boeing Supplier Documents Document Control Systems, Procedures, Forms and Templates 10
S Template of Opening Meeting for Internal Audits Internal Auditing 7
Q Tips on how to conduct a good Internal Audit Opening Meeting Internal Auditing 19
N Symbol for Medical Device Sterile Packaging - "Inspect Seal Before Opening" Other Medical Device Related Standards 5
L What typical items do auditors bring to Opening Meetings Internal Auditing 4
Jim Wynne Baseball Opening Day--A Sure Sign Of Spring Coffee Break and Water Cooler Discussions 3
S Auditing the Top Management during the Opening Meeting of Internal Audit Internal Auditing 21
BradM 29th Olympics in China - Beyond the opening Coffee Break and Water Cooler Discussions 82
Ajit Basrur China kicks off 29th Olympics Opening Ceremony Coffee Break and Water Cooler Discussions 38
P Should the audit objectives be discussed in the opening meeting? General Auditing Discussions 15
W Opening Small Shop in Mexico - Does ISO Still Apply? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Quality Department Job Opening - High Point, North Carolina Career and Occupation Discussions 0
Q Quality Job Opening at Toyota Career and Occupation Discussions 1
A Does anyone conduct opening & closing meetings for their internal audits? Internal Auditing 19
C Opening a new Calibration Laboratory - Need help General Measurement Device and Calibration Topics 8
L Opening Design Limits to Accomodate Process Capability Statistical Analysis Tools, Techniques and SPC 5
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 0
R Tolerances for Analytical Balances General Measurement Device and Calibration Topics 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
W Key functional characteristic definition - Tolerances and Deviations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
DietCokeofEvil What is the general consensus on Caliper tolerances? General Measurement Device and Calibration Topics 1
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S MSA (Measurement System Analysis) - Process Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Tighter Tolerances than Control Plan FMEA and Control Plans 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
G MSA (Measurement System Analysis) and Dimensional Tolerances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Changing dimensional tolerances to approve rejected product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Tolerances on Drawing Title Block Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
V GD&T Interpreting Datums in Two Single Segmented Position Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C ZZ Pin Gage Tolerances and Calibration General Measurement Device and Calibration Topics 2
W Thread Micrometer Standard Tolerances General Measurement Device and Calibration Topics 4
D ISO 8062-3 Angle Tolerances - The drawing states ISO 8062-3 DCTG 11 Other ISO and International Standards and European Regulations 1
M Thread Gage Tolerances ?Who?s The Authority?? General Measurement Device and Calibration Topics 9
N Injection Molded Nylon Part Tolerances Manufacturing and Related Processes 6
A Ppk Issue - Some Products have Unilateral Tolerances Capability, Accuracy and Stability - Processes, Machines, etc. 24
H GD&T - How to measure these Positional Tolerances on a CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Improper Use of Tolerances & SPC Practices, or not? Misc. Quality Assurance and Business Systems Related Topics 5
M Vinyl and Cloth Cut Parts Tolerances? (Car Seats) Manufacturing and Related Processes 8
G Geometric Tolerance - Swedish Drawing which states that all tolerances are to NS 1430 Manufacturing and Related Processes 2
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S S-Type Tolerances: How to calculate Cs? Control Limit(s)? Statistical Analysis Tools, Techniques and SPC 8
