Operator Error - Fact or Fiction?
Wes Bucey
Here's my take:
"operator errors" come from two sources:
  1. intended error (sabotage)
  2. management failure to provide training, tools, and processes to eliminate the chances for confusion by operator, resulting in a nonconforming product.
Once you are able to eliminate intended sabotage from the cause, you are left (as Sherlock Holmes would say) with the answer, no matter how improbable to believe, that the management is at fault for not eliminating "opportunities for error."
Sometimes, management needs outside help in identifying and remedying the problem, but most often, the solution is to merely ask the workers, "what can we do to help you prevent making such errors?"
Good sources to look at for clues to possible glitches in your processes which can be eliminated include:
http://dept.lamar.edu/industrial/Underdown/org_mana/The_Red_Bead_Experiment.htm
http://www.campbell.berry.edu/faculty/jgrout/pokayoke.shtml
plus, google the terms "mistake proofing" and "Poka Yoke"
I hope this helps - come back and keep us up-to-date on your progress.
This is a false dichotomy, based apparently on the fanciful belief that there are not times when it is impossible to eliminate human error, and there are other times when it is not fiscally responsible to do so.
I fully believe that management is responsible for most process problems but even Deming estimated "only" 85%. If that number is accurate, do you ascribe the remaining 15% to sabotage?
In my opinion, two of the greatest myths in manufacturing are that human error can be eliminated or consistently predicted in all manufacturing processes operated by humans, and that "zero defects" is a reasonable goal. When we formulate plans based on mythical presuppositions, we shouldn't be surprised when the unpredictable happens.
David Hartman
QChas said:
Remember there are no "Oerator Errors" ..... only "Management Errors". If the procedures are not adequete change them. If they are then it is managements responsibility to make sure they are followed. Allowing the inmates to run things is not the answer!
Is it just me, or isn't there just a bit of irony in this statement as it is presented here?
If there is no such thing as "Operator Error", what "Management Error" contributed to the typo in this posting (or was it sabotage)?
:D
Wes Bucey
JSW05 said:
[/list]This is a false dichotomy, based apparently on the fanciful belief that there are not times when it is impossible to eliminate human error, and there are other times when it is not fiscally responsible to do so.
Good points. So, with your take on the situation, the original poster could eliminate about 85% of his current nonconformances by fine tuning the management functions, huh? That seems like an admirable goal to me!
Randy Stewart
Interesting discussion.
Wes, how do we eliminate human error? Is it by eliminating the human then? If so would that be the human management for confusing the operator or the human operator for making a mistake?
Let's get back to the real world here. With all the training that the members here have had, do we still make mistakes? Is it our General Managers fault for not providing adequate training? Is it the fault of the university for not having adequate corriculum?
I think we are back to the argument where we blame the bartenders for people driving drunk, or we blame the fast food place because we eat too much junk.
I agree that management is responsible to ensure the operators have appropriate equipment, but I don't see where it is value added to have a second set of eyes to ensure they don't make mistakes.
Wes Bucey
OK, OK! I was being a little facetious.
The point to be gleaned by reading between the lines of most of the posts here is that management's design of the process and the tools and training have an incredible amount of effect upon "error rate." Employees do not have the power to change the process - only management has that power.
If you are not familiar with Deming's Red Beads, you should be before trying to "correct" employee errors.
Often, managers are too myopic to see the process glitches which contribute to errors. They compound the problem by unilaterally determining ALL problems are employee or operator based. They never consult with the operators on "how" to change the process to eliminate opportunities for error.
In most cases, the situation could be alleviated by a REAL "root cause investigation." Major drawback: many managers do not perform root cause investigation in a systematic, scientific way and therefore never really get to the root cause of a problem.
Until a manager with authority has the AHA! moment (when he says "AHA! That's the reason things are not getting fixed!), nothing will improve and morale will continue to go downhill.
I agree with all of this. In fact, I think that perhaps the "sabotage" thing might not be that far off base after all. If management has designed processes that have been proven to work as intended, and employees have been A) trained in operation of the processes and B) imbued with a sense of the importance of following them, then casual failure to follow the process could be seen as sabotage--i.e., malicious failure to get with the program.
That would leave "innocent" error as the only uncontrollable factor, and in terms of numbers, those are relatively rare, and seldom repeated.
I have seen only one instance of a large company wherein the quality system is accepted by hourly workers as received knowledge, and people who don't follow it are brought in line by their peers. That's one way you can tell that the system is, well, systemic.
Randy Stewart
Whew, for a moment there I thought Wes had been replaced by a Cylon. But that discussion belongs in the SciFi forum.:lol:
This is where the Plan, Do, Check, Act program is important. Management Plans the process, operators Do the process, supervisors Check the process and all Act on the results.
One more thought or comment here. I believe the important issue is to promote the sense of ownership with the operators. If you own it you take care of it. I think most of us have heard that phrase "nothing parties like a rental". I see that same "attitude" from operators who have no input on how their jobs are done. They don't own the process therefore they don't really care about the output. Give me my paycheck and let me go home.
P Countermeasure For CMM Operator Error Problem Solving, Root Cause Fault and Failure Analysis 4
I Corrective Action Reply to a Customer - Operator Error Nonconformance and Corrective Action 50
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
S Operator Error - How to do a Corrective Action Nonconformance and Corrective Action 14
michellemmm Thoughts on issuing a CAR for Operator Error General Auditing Discussions 15
L Can Operator error ever be used on an 8D (Corrective Action)? Nonconformance and Corrective Action 2
M Toyota Approach to Root Cause Analysis - Operator Error trend Problem Solving, Root Cause Fault and Failure Analysis 9
M Informational Nonconformances and Defects - Operator Error, System Error, or both? Nonconformance and Corrective Action 180
J Need Root Cause Verbiage - What to say when it's Operator Error? Problem Solving, Root Cause Fault and Failure Analysis 38
D Operator Error - Not an Acceptable CAR (Corrective Action Request) Response Nonconformance and Corrective Action 26
D Is 'Operator Error' as Root Cause ever acceptable? Problem Solving, Root Cause Fault and Failure Analysis 227
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Nonconforming parts accepted by operator with intention Human Factors and Ergonomics in Engineering 33
H EU MDR Economic Operator notifications? EU Medical Device Regulations 1
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Economic operator responsibilities - when the Importer is also Distributor - Article 13 EU Medical Device Regulations 1
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
R Operator's manuals as prevention design control FMEA and Control Plans 2
M Informational EU – M2M Data Exchange available services for accessing MDR EUDAMED data available for Economic Operator (EO) organisations Medical Device and FDA Regulations and Standards News 0
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
T Root causes - operator's actions Problem Solving, Root Cause Fault and Failure Analysis 17
K Article 23 (Parts and components) - Economic Operator EU Medical Device Regulations 1
shrutisancheti EU User manual / operator manual / service manual guidance document(s) CE Marking (Conformité Européene) / CB Scheme 2
GoSpeedRacer How to handle operator involvement in the non conformance ISO 13485:2016 - Medical Device Quality Management Systems 5
Fender1 Operator process buy-in - how to get it? Manufacturing and Related Processes 6
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
C ISO 9001:2015 - Non Applicable Design and Development (Power Plant Operator) Design and Development of Products and Processes 2
A Failure Mode from Operator "Components Fallen but Loaded" FMEA and Control Plans 3
A 21CFR807.25 (d) Owner-Operator Contact question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
U USB Connector Operator Protection (MOPP) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
somashekar Adding an other process into the system - Authorised Economic Operator (AEO) Scheme ISO 13485:2016 - Medical Device Quality Management Systems 4
L Warning Letter adressed to owner/operator or facility? US Food and Drug Administration (FDA) 1
B How to change the FDA Device Registration and Listing Module - Owner/Operator Other US Medical Device Regulations 10
M Template for Quality Awareness Training to all Operator Document Control Systems, Procedures, Forms and Templates 6
I Operator Initialling on Paperwork - FDA Good Documentation Practices Other US Medical Device Regulations 11
M Can I continue using IEC60601-1 Ed2 PSU for MOOP (Means Of Operator Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Operator Mistakes (Errors) and responding to CAR (Corrective Action Requests) Nonconformance and Corrective Action 20
K Poka Yoke for Leaf Spring placement by Operator Misc. Quality Assurance and Business Systems Related Topics 2
D Nonconformance or Misinterpretation - When an operator does a Nonconformance Report Nonconformance and Corrective Action 31
shimonv Operator vs. Manufacturer Relationship and ISO 13485 / CE Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
D If a control operator add a photo as a visual aid, can you improve Occurrence? FMEA and Control Plans 12
C Operator Forgot to Follow Procedure - Now What? Manufacturing and Related Processes 6
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
L Decision Matrix to help Operator driven Continuous Improvement Lean in Manufacturing and Service Industries 3
M Voluntary Action by Human Operator Influences Availability? Reliability Analysis - Predictions, Testing and Standards 2
J Standardized Operator Work Practices - Work Instructions - To what Level ? Manufacturing and Related Processes 8
optomist1 Nested Gage R & R One Operator One Sided Spec Using Minitab Software 5
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
