Operator understanding of what Control Plans are and how they are used
CMfgT
Right now our inspection sheets are on the shop floor and our control plans are just quality documents we keep internally…and if an auditor asked our operators if they use the control plan, they would say “what is a control plan”. I am new to this position, but I know the control plan should be a living document with our inspection sheets and the operators should have a control plan so they know what to do if a problem arises. What do you guys/gals do at your facility? Do you have control plans in the factory? If so how do you use/manage them for operator use?
Does anyone have control plans and inspection sheets combined on one document? I guess I am looking for suggestions or examples on how to implement this. In a perfect world, as you edit an inspection sheet in a data base such as excel, the control plan will update on another sheet or same sheet. Just don’t know how feasible this is.
Thanks,
harrysons
Realistic Quality
Re: Control Plans & Inspection Sheets
My experiences The Control plan between inspection sheet separated. we kept the control plan at the distribution department, the operator won't keep the control plan such as inspection sheet, we used the control plan to identified each process step till inspection.
Jen Kirley
Quality and Auditing Expert
The control plan is the master plan for controls throughout the production cycles, including inspection. The control plan is used by engineering and management to develop routers, special instructions and yes, inspection plans, but operators and inspectors are not typically shown these master documents so they usually don't know what they are.
Jen Kirley
Welcome to the Cove! :bigwave: Thank you for sharing your experience. I look forward to seeing you around!
Thanks,
On the assumption that you're referring to the AIAG control plan, the format isn't particularly user-friendly and they're often used (a) to satisfy customer requirements and/or (b) as so-called "master" documents that form the basis for shop-floor documentation.
So long as there is a current control plan and the shop documents don't contradict it, there's no auditor should have an issue with there being no copies in the shop, or operator awareness of it. Note that I'm not saying that it's a good idea for operators to be ignorant of the existence of a control plan.
CMfgT
Thanks for all of the replies.
I guess Jim Wynne, you hit the nail on the head. I don't want the operators to be ignorant of the control plans. I want them to now what action to take when a problem arises. I need to find a balance between inspection sheet and control plans...and most of all a way to manage them.
There are ways other than a control plan to make people aware of the requirements. You can integrate the "reaction plan" into the shop floor documentation, or you can provide supplemental training and instructions. For example, you should already have a procedure for handling nonconforming material, and your operators should be aware of it.
In any case, if you feel that a copy of the control plan itself is the best way to go, then that's what you should do.
C.R.V.G.
Quality Engineer
Hello!
Long time no posting on this forum... but, I would like to raise another question related to this issue: has anyone here any systematic of keeping only one document covering all information from "AIAG control plan" and "shop floor process sheet" in place?
I mean, it would be easier to manage the updates if we work with only one source of information, right? Otherwise some information could be missed or mismatched from one document to another in an updating situation.
I appreciate any feedback on this point!
Regards,
- Bruno
Ron Rompen
Hello!
Regards,
- Bruno
There is (as far as I know) available a disk or CD which contains all the recommended AIAG documents (PFMEA, Control Plan, APQP documents, Dimensional Report, PPAP warrant, etc etc) which are contained in a linked Excel spreadsheet. Cant recall who published/sold it, but I am sure there is someone here who still has access to it, and can provide that information.
The only document I recall as being missing from the package was the in-process inspection sheet - this is something that you would add, and create the links within the document, and then have a complete package. If you create the links properly, then when you update one document, you update ALL of the documents at the same time.
Control Plans on the floor has been a debate at most places I worked since 1992 and still it rages on. I actually have a question about Control Plans on the shop floor as well. I had a customer audit me using what he said was some version of a VDA audit though when I looked through it I think it was more of a Frankenstein audit where he pulled select questions from of a few different audits that I have seen over the years. Anyway though I personally prefer NOT to have CP's on the floor because it is a controlled document latest revision non-conformance just waiting to happen, we have them in the job books. When the customer audited the job book he saw the CP and quickly asked the operator if he knew what it was and if he understood or was ever trained on the document. Of course the Op said no and we were written up for it because the customer said that all documents in the Job Book need to be clearly understood by the operator. My question is this a real requirement or his requirement? He is the customer and he is requiring it so I guess it makes it kind of a customer requirement but is this a requirement listed in any of the recognized standards?
L Economic Operator based in UK EU Medical Device Regulations 10
B How to test operator to see if they can catch the defective parts? Manufacturing and Related Processes 6
Melissa CAR is not good enough! Operator Error! ISO 13485:2016 - Medical Device Quality Management Systems 39
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Nonconforming parts accepted by operator with intention Human Factors and Ergonomics in Engineering 33
H EU MDR Economic Operator notifications? EU Medical Device Regulations 1
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Economic operator responsibilities - when the Importer is also Distributor - Article 13 EU Medical Device Regulations 1
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
R Operator's manuals as prevention design control FMEA and Control Plans 2
M Informational EU – M2M Data Exchange available services for accessing MDR EUDAMED data available for Economic Operator (EO) organisations Medical Device and FDA Regulations and Standards News 0
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
T Root causes - operator's actions Problem Solving, Root Cause Fault and Failure Analysis 17
K Article 23 (Parts and components) - Economic Operator EU Medical Device Regulations 1
shrutisancheti EU User manual / operator manual / service manual guidance document(s) CE Marking (Conformité Européene) / CB Scheme 2
GoSpeedRacer How to handle operator involvement in the non conformance ISO 13485:2016 - Medical Device Quality Management Systems 5
Fender1 Operator process buy-in - how to get it? Manufacturing and Related Processes 6
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
C ISO 9001:2015 - Non Applicable Design and Development (Power Plant Operator) Design and Development of Products and Processes 2
A Failure Mode from Operator "Components Fallen but Loaded" FMEA and Control Plans 3
A 21CFR807.25 (d) Owner-Operator Contact question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
U USB Connector Operator Protection (MOPP) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
somashekar Adding an other process into the system - Authorised Economic Operator (AEO) Scheme ISO 13485:2016 - Medical Device Quality Management Systems 4
L Warning Letter adressed to owner/operator or facility? US Food and Drug Administration (FDA) 1
B How to change the FDA Device Registration and Listing Module - Owner/Operator Other US Medical Device Regulations 10
M Template for Quality Awareness Training to all Operator Document Control Systems, Procedures, Forms and Templates 6
P Countermeasure For CMM Operator Error Problem Solving, Root Cause Fault and Failure Analysis 4
I Operator Initialling on Paperwork - FDA Good Documentation Practices Other US Medical Device Regulations 11
M Can I continue using IEC60601-1 Ed2 PSU for MOOP (Means Of Operator Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M Operator Mistakes (Errors) and responding to CAR (Corrective Action Requests) Nonconformance and Corrective Action 20
K Poka Yoke for Leaf Spring placement by Operator Misc. Quality Assurance and Business Systems Related Topics 2
D Nonconformance or Misinterpretation - When an operator does a Nonconformance Report Nonconformance and Corrective Action 31
shimonv Operator vs. Manufacturer Relationship and ISO 13485 / CE Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
D If a control operator add a photo as a visual aid, can you improve Occurrence? FMEA and Control Plans 12
C Operator Forgot to Follow Procedure - Now What? Manufacturing and Related Processes 6
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
L Decision Matrix to help Operator driven Continuous Improvement Lean in Manufacturing and Service Industries 3
I Corrective Action Reply to a Customer - Operator Error Nonconformance and Corrective Action 50
M Voluntary Action by Human Operator Influences Availability? Reliability Analysis - Predictions, Testing and Standards 2
J Standardized Operator Work Practices - Work Instructions - To what Level ? Manufacturing and Related Processes 8
optomist1 Nested Gage R & R One Operator One Sided Spec Using Minitab Software 5
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S SPC Gap Analysis for Operator Training Needs Training - Internal, External, Online and Distance Learning 6
C Authorised Economic Operator Status (EU) - HMRC (Her Majesty's Revenue and Customs) Other ISO and International Standards and European Regulations 6
M Operator/Patient Leakage Current IEC 60601 - Battery Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
Q Adding Malicious Operator to FMEA? Quality Manager and Management Related Issues 12
S Control Plan Details vs. Operator Instruction Sheets - Document Contents IATF 16949 - Automotive Quality Systems Standard 9
