Since ISO 9001:2015, all the Risk mentality was incorporated into ISO, including the fact that Risks are not only negative, but also POSITIVE risks, also called Opportunities.
But ISO 9001 already had for a long time used the term Opportunity for Improvement, the OFI.
Is there any REAL, tangible relation between them? Should the identification of a positive risk create an OFI? Or should we not even consider Positive Risks, just create an OFI if a risk is positive?
Without much analysis, it seems to be both are a little different, in that OFIs would be used for smaller things, sometimes almost like "suggestions for improvement".
While a Positive Risk (opportunity) would be more formal, maybe on a more strategic level. With maybe analysis of a trigger of the event, probability, impact, etc.
Any insight into this?
Taken form 0.3.3
Opportunities can arise as a result of a situation favourable to achieving an intended result, for
example, a set of circumstances that allow the organization to attract customers, develop new products
and services, reduce waste or improve productivity. Actions to address opportunities can also include
consideration of associated risks. Risk is the effect of uncertainty and any such uncertainty can have
positive or negative effects. A positive deviation arising from a risk can provide an opportunity, but not
all positive effects of risk result in opportunities
Roger
I'm doing it very easy in this way:In swot, got negative and positive
For Negative I created a procedure for the management, on where I consider ,Risk value, R= PxI probability and impact, depending of the
value I define action plans. and do the following, the residuaal risk evaluation and the closeout if applicable.
For positive, I manage what I call improvement projects, in this way if an opportunity emerges, this project is shown
to top management and is evaluated if it is convenient or not, giving him data like: cost of investment, benefits, timeframe, etc.
But OFIs not neccessarily are small things, consider 9.3, f Opportunities for improvements, in here, is very common the
need of "Big Things".
But don´t worry too much on this, since the standard is not too clear, just define a simple criteria and put it to run.
Hope this helps
Hurry up to clear up this issue, haven´t you had recent audits, Have the audits detected Nonconformities on this issue?
