OPRP or HACCP Plan - Opinions and Practical Example Wanted
Sveta
Hello!
One of the examples I’ve heard a lot of times to understand difference between operational PRP and HACCP plan is example with metal detector. Last metal detector on the production line is a CCP and managed by HACCP plan and all other metal detectors are not CCP and managed by operational PRPs. Theoretically all is clear. Let’s see what we get in practice. In practice we don’t have any difference in managing all these metal detectors, we check them let’s say every 2 hr with the same samples (same critical limits), corrective actions are also the same. ISO 22000 doesn’t require critical limits for operational PRP, but in this example we have it anyway. So what is the point in this case to have two documents (operational PRP and HACCP plan)?
Any comments?:thanx:
Bilijaf
Re: OPRP or HACCP plan - practical example
I think all metal detectors are to be considered as CCP's, since they are installed to eliminate metal traces and no further step will eliminate them.
If you think that metal hazard are not significant at any of the processing lines and you placed metal detectors for more security, in that case you can consider them as OPRP where frequent monitoring is not necesary.
I all cases ask yourself the questions: Is it possible to monitor the control measure in such a way that corrective actions can be taken immediately when there is a loss of control? Is it possible to establish critical limits for the control measure at this step? , if both answers are yes so this point is a CCP, otherwise it is an OPRP.
Sveta
Hi Bilijaf!
Thanks for reply.
I am not sure that all metal detectors are to be considered as CCP's. If 3 metal detectors ate installed in one production line then only after last of them there is no further step to eliminate the hazard.
So it must be decided upon results of analysis.
Moreover, according to ISO 22000 it doesn’t matter what way of managing of control measures you will choose as anyway they should be:
7.4.4“…capable of preventing, eliminating or reducing these food safety hazards to defined acceptable levels”
8.2 “Prior to implementation of control measures to be included in operational PRP(s) and the HACCP plan and after any change therein (see 8.5.2), the organization shall validate (see 3.15) that
a) the selected control measures are capable of achieving the intended control of the food safety hazard(s) for which they are designated, and
b) the control measures are effective and capable of, in combination, ensuring control of the identified food
safety hazard(s) to obtain end products that meet the defined acceptable levels.”
And one more point, you put only two questions to categorize between operational PRP(s) and HACCP plan, though according to ISO 22000 sec.7.4.4 there are many others:
“The selection and categorization shall be carried out using a logical approach that includes assessments with regard to the following:
a) its effect on identified food safety hazards relative to the strictness applied;
b) its feasibility for monitoring (e.g. ability to be monitored in a timely manner to enable immediate corrections);
c) its place within the system relative to other control measures;
d) the likelihood of failure in the functioning of a control measure or significant processing variability;
e) the severity of the consequence(s) in the case of failure in its functioning;
f) whether the control measure is specifically established and applied to eliminate or significantly reduce the
level of hazard(s);
g) synergistic effects (i.e. interaction that occurs between two or more measures resulting in their combined
effect being higher than the sum of their individual effects).
Marc
As reference for those who are not 'literate' in this, but follow the topic for educational purposes:
Critical Control Point (CCP) - A critical control point is the point (or step) at which a control measure must be applied. It is a point that is critical or essential to safety. It is the point where a control measure can be used to prevent or eliminate a food safety hazard or to reduce it to an acceptable level.
OPRP = Operational Prerequisite Programs
HACCP = Hazard Analysis & Critical Control Points
Bilijaf
hi bilijaf!
Thanks for reply.
I am not sure that all metal detectors are to be considered as ccp's. If 3 metal detectors ate installed in one production line then only after last of them there is no further step to eliminate the hazard.
i am not sure if it is worthy to have metal detector at earlier stages of processing. The best location for it is directly before final wrapping or packaging where a further physical hazard is excluded.
moreover, according to iso 22000 it doesn’t matter what way of managing of control measures you will choose as anyway they should be:
8.2 “prior to implementation of control measures to be included in operational prp(s) and the haccp plan and after any change therein (see 8.5.2), the organization shall validate (see 3.15) that
not in that sense, i can understand a ccp as having higher level of control than oprp where you have define control limits at close intervals of monitoring. I would not use examples here since we need to consider the full flow and not individual processing step. and one more point, you put only two questions to categorize between operational prp(s) and haccp plan, though according to iso 22000 sec.7.4.4 there are many others:
“the selection and categorization shall be carried out using a logical approach that includes assessments with regard to the following:
b) its feasibility for monitoring (e.g. Ability to be monitored in a timely manner to enable immediate corrections);
level of hazard(s);
g) synergistic effects (i.e. Interaction that occurs between two or more measures resulting in their combined
effect being higher than the sum of their individual effects).[color="red"right. [color="red[color="red"]"]i was talking only about how to differenciate between them. Above points are assessment criteria or approach used for both ccp and oprp.[/color][/color]
[/color]
Robert jr
As far as I am aware a number of food manufacturers do not consider metal detection as CCP or removed it recently from being CCP.
In terms of OPRP or HACCP, the OPRP is foundation for HACCP in an overall food safety management programme. A proper and well designed prerequisite programme allows the HACCP team to focus and concentrate on the hazards directly applicable to the product and the processing procedures without undue considerations and repetition of protection from hazards from the surrounding environment.
A HACCP Plans - OPRP's and CCP's - Difference, please Food Safety - ISO 22000, HACCP (21 CFR 120) 10
G Question about OPRP and PRP with regards to HACCP and ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 4
R Still confused on OPRP and CCP in an ISO 22000 Catering Business Food Safety - ISO 22000, HACCP (21 CFR 120) 3
F ISO 22000 Clause 7.4.4 to determine whether a control is a CCP or and OPRP Food Safety - ISO 22000, HACCP (21 CFR 120) 2
L oPRP or CCP? Practical example Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S OPRP in ISO 22000 vs. CP in BRC - Food Food Safety - ISO 22000, HACCP (21 CFR 120) 6
K Operational Prerequisite Programmes (oPRP) Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K When, whom, how to conduct hazard analysis of PRP?s, OPRP?s and CCP?s? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
V Identification of Operational Prerequisite Programs (oPRP) for ready to eat products Food Safety - ISO 22000, HACCP (21 CFR 120) 4
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
D HACCP question Imported Legacy Blogs 1
Q HACCP Plan under ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D HACCP Internal Audit Template wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
D Pesticides in Food Process Areas - HACCP in a Restaurant Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M HACCP Plan without CCPs Food Safety - ISO 22000, HACCP (21 CFR 120) 3
M HACCP vs. ISO 22000 Documented Procedure requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 1
C I am looking for a GMP / HACCP Checklist Quality Manager and Management Related Issues 2
S Source of Online or Home Based HACCP - FSSC22K Training Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Food Services Hygiene - ISO 22000 Certificate or HACCP Certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Evidence of Management Commitment to HACCP Food Safety - ISO 22000, HACCP (21 CFR 120) 3
P HACCP for Poultry Slaughter House Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Locating HACCP Training and Certification Resources Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P HACCP Product Description Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 3
F HACCP Certification for Single Use Disposable Food Contact Grade Gloves Food Safety - ISO 22000, HACCP (21 CFR 120) 1
R HACCP for Packaging, Labeling and Warehouse of Food Products Food Safety - ISO 22000, HACCP (21 CFR 120) 13
P Food Safety - Presentations and Information pertaining to Food Safety & HACCP Manufacturing and Related Processes 1
6 Catering HACCP/Food Safety - Traceability from Receipt to Finished Product Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J HACCP and ISO22000 - Brewery and Warehouse Food Safety - ISO 22000, HACCP (21 CFR 120) 13
L Implementation of GMP and HACCP on a Spice Packaging Facility Food Safety - ISO 22000, HACCP (21 CFR 120) 7
C HACCP for Pizza Restaurants Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S HACCP Implementation Issues Food Safety - ISO 22000, HACCP (21 CFR 120) 4
K Can tobacco companies be certified against HACCP/ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 12
M ISO 22000 - HACCP plan for ingredients like Egg Powder, Strawberry Flavour and Butter Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J ISO 22000, PAS 220 and HACCP Combination. Food Safety - ISO 22000, HACCP (21 CFR 120) 10
S HACCP for Animal Feed - Writing a form and report about Animal Feed Food Safety - ISO 22000, HACCP (21 CFR 120) 10
V Certified Quality Improvement Associate vs. CSSGB, About HACCP Professional Certifications and Degrees 7
B Implementing an HACCP system - Scheme for company Food Safety - ISO 22000, HACCP (21 CFR 120) 3
K General HACCP (Hazard Analysis Critical Control Point) Questions Food Safety - ISO 22000, HACCP (21 CFR 120) 8
K HACCP Document Control vs. ISO 9001 Document Control Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 20
A HACCP Flow Diagram for Powdered Milk? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S Quality Control Processes in a Mineral Water Company and HACCP Food Safety - ISO 22000, HACCP (21 CFR 120) 20
P Differences between Codex, HACCP and ISO Food Safety - ISO 22000, HACCP (21 CFR 120) 3
E HACCP in our Dairy Farm (Milk Processing) Food Safety - ISO 22000, HACCP (21 CFR 120) 4
C HACCP in Egg Production - Controlling hazards at the farm level Food Safety - ISO 22000, HACCP (21 CFR 120) 6
B Safe-Menu - System used in restaurants based on HACCP called Safe-Menu Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S HACCP on Time and Temperature Control - Microbiological Contamination Food Safety - ISO 22000, HACCP (21 CFR 120) 3
B HACCP plan for Frozen Shrimp - Required toxicity tests Food Safety - ISO 22000, HACCP (21 CFR 120) 6
D Difference between ISO 22000 certificate and HACCP certificate Food Safety - ISO 22000, HACCP (21 CFR 120) 4
B What we must do to transfer from HACCP to ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 7
