Optical epoxy for LED having good thermal shock resistance.
somashekar
Helloo experts ....
We are developing a new emitter for our customer for a new range of sensors
We make emitters used in the sensors of patient monitors.
Red and IR LED are mounted and wire bond on the gold plating in a ceramic substrate. The substrate has a small cup for the devices mounting, wirebonding and the optical epoxy fill.
We use a single part optical epoxy Bondline 6570 at present and cure per spec in oven @ 90'C.
We face a challenge here in the soldering process of the sensor cable wire to the ceramic pads, which are on the reverse side of the ceramic substrate. It is observed that the heat on the gold pads during the soldering has an effect on the optical epoxy that we use. In sense, it is noticed after soldering that the epoxy shows signs of separation from the ceramic cup.
We are now looking for a good optical epoxy (single or 2 part) to be able to withstand short term thermal shock.
Do anyone have experience of similar application and a solution....
:thanx:
Marc
Hunkered Down for the Duration
Does anyone here have any background / experience that can shed some light on this person's problem?
arios
Your Mexican Amigo
It's not my area of experience but, Have you considered conductive epoxies instead of soldering? It looks like conductive epoxies are more friendly to temperature sensitive components and you may not need to worry about the temp. shock
It's just a thought so you will need to explore more.
I found this example doing a quick search:
http://www.mgchemicals.com/products/8331.html
Dear modetarors and other folks from the Olimpus: this is not a commercial so please let Somashekar take a look.
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
S Optical coherence tomography (OCT) device - Do we need to apply IDE? Other US Medical Device Regulations 0
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
J NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
J TOPCON PP-70 Optical Comparator - User Manual Needed General Measurement Device and Calibration Topics 0
G Optical Comparator Light Bulb Wear question General Measurement Device and Calibration Topics 1
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
D Using a "broken" measurement device in a TS 16949 company - Optical comparator IATF 16949 - Automotive Quality Systems Standard 4
C Uncertainty Estimation for Spark Optical Emission Device Measurement Uncertainty (MU) 1
Marc Mind-bending optical illusion paintings Coffee Break and Water Cooler Discussions 3
T Optical Comparator measuring of Position of a Threaded Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Basic International Standards required for a Manufacturing Industry (Optical Media) Other ISO and International Standards and European Regulations 4
C Optical Comparator Uncertainty Budget Measurement Uncertainty (MU) 2
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
A Best Way for SPC via Optical Comparator with output to Computer for Data Analysis Statistical Analysis Tools, Techniques and SPC 4
M Typical values of MTBF for Optical Avionic Networks Reliability Analysis - Predictions, Testing and Standards 1
F Optical Gaging Systems - Shadows, debris, etc. cause parts to measure out of spec Measurement Uncertainty (MU) 7
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
J How to measure the True Position on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Optical Emission Spectrometer Calibration General Measurement Device and Calibration Topics 0
3 Vision System Optical Calibration Standard General Measurement Device and Calibration Topics 6
B Optical Steel Surface Inspection System (best hardware to recommend) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Checking the Theoretical Sharp of a Flush Head Bolt on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Optical Emission Spectrometer Calibration to a National or International Standard Various Other Specifications, Standards, and related Requirements 4
J Uncertainty Budget for the Optical Microscope - Deriving Linearity Uncertainty Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S GR&R (Gage R&R) for an Optical Comparator or Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J MU (Measurement Uncertainty) for an Optical Microscope Measurement Uncertainty (MU) 7
M Methods for Verification/Calibration of Video (Optical) Extensometer General Measurement Device and Calibration Topics 2
A Optical Magnification Checking Graticule - Starrett 400-360 (P-10089) General Measurement Device and Calibration Topics 2
Q Validating the AOI process (Automated Optical Inspection) Reliability Analysis - Predictions, Testing and Standards 9
Frank T. How to inspect the 5 different dimensions using an optical comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
quality1 PCBA Visual Inspection Tools & Methods - discounting Optical Tools Manufacturing and Related Processes 11
M Serial Numbers for Product - Common sense? Optical Components for Telecommunications Manufacturing and Related Processes 9
Marc Email in the 18th Century - The Optical Telegraph After Work and Weekend Discussion Topics 0
K GR&R for an Automatic Optical Inspection Machine (AOI) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
ScottK Moving an optical comparator - recalibration needed? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Jim Wynne Checker Square Optical Illusion Coffee Break and Water Cooler Discussions 14
samer Some Optical Illusion Examples Coffee Break and Water Cooler Discussions 6
B Can I calibrate Optical Comparators internally? General Measurement Device and Calibration Topics 22
ScottK Automating variable inspection - Calipers, micrometers, and optical comparators Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q What is the best optical comparator? General Measurement Device and Calibration Topics 14
H Attribute Gage R&R for Repair Station Operators - AOI (Automated Optical Inspection) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Calibration of Optical Comparator Overlays - Radius, Thread and Angle General Measurement Device and Calibration Topics 11
M How to use FC-30 optical compartor? General Measurement Device and Calibration Topics 6
N Ocr (OPTICAL CHARACTER RECOGNITION) Scanners Quality Assurance and Compliance Software Tools and Solutions 4
M How can I evaluate/measure backlash on an optical comparator General Measurement Device and Calibration Topics 1
D Optical flats - "FLATNESS INTERPRETATION CHART, Light Wave Band Pattern Guide" General Measurement Device and Calibration Topics 4
M Gage R&R for Optical System - Measurement Parameters and Resolution of the system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Where can I find a copy of ISO 10110? Optics and Optical Instruments Other ISO and International Standards and European Regulations 3
NDesouza Connectors Rejected for Excessive Epoxy Manufacturing and Related Processes 1
