OQ (Operational Qualification) for Electropolish - Orthopedic Cutting Tools
L
Loren_apex
My company is a orthopedics cutting tool manufacturer. Now we are required by one of customer to do process validation on electropolish and other special process. For OQ protocol of electropolish, does anybody have any suggestion on what should be the output of electropolish. My question is what we need to test to evaluate the performance of electropolish. My customer requires me to test cytotoxicity to make sure there is any acid residual after electropolish, but I don't think it is necessary.
:thanks:
somashekar
Re: OQ for electropolish
Welcome here ...
I am not talking about electropolishing, as this is a seperate process for surface polishing or passivating, that required a process validation.
However if your customer needs a "No acid residue" on the electropolished surface, you need to establish a protocol that ensures that the cleaning process after electropolishing meets this requirement consistantly.
If your requirement is polishing, then a measure of the surface roughness is an output indicator. If it is passivation, then an accelerated chamber test for corrosion resistance would do.
Same time considering customer requirement of "No acid residue" the cleaning process after passivation could be devised and merged within the electro polishing validation process.
Cytotoxicity is a biocompatibility test per specific standards which your processess will be able to meet and perhaps this is more the domine of your customer who has to get his products tested and determine that you freeze your electro plating operation per the protocol that made the biocompatibility test a pass.
L
Loren_apex
Somasnekar, thank you. Our process flow is electropolish--laser marking--passivation--final cleaning. we are validating electropolish, passivation and final cleaning separately. Corrosion resistance will be tested in passivation and cytotoxicity will be tested in final cleaning.
The electropolish I mentioned here is polishing, so roughness should be one output, but we have to ensure there is no acid residual which may damage the part after electropolish. I have no idea what should be tested to verify acid residual. My customer suggest cytotoxicity, but I think it is not reasonable.:thanks:
somashekar
I am not clear how you would be doing this .. ? It is an elaborate testing process which also includes animal specimen.
If your final cleaning process cycle has a base wash cycle and then demineral water rinse (you mention that you are validating electropolish, passivation and final cleaning separately) then I guess a pH test of the final cleaning media that is drained out should give you a proof that there is no acid residue if you always end up with a neutral pH result.
Z Operational Qualification for Injection Molding Supplier Quality Assurance and other Supplier Issues 6
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Heated Sealed Packages - Sample Size for OQ (Operational Qualification) and PQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
E Operational Qualification of a Drug Box Coding Device in Production Other Medical Device and Orthopedic Related Topics 1
J OQ (Operational Qualification) for Liquid-Water Isotope Analyser Other Medical Device and Orthopedic Related Topics 2
B Usage of Parts from OQ (Operational Qualification) Mold Validation ISO 13485:2016 - Medical Device Quality Management Systems 4
B OQ (Operational Qualification) of a Freeze Dryer Qualification and Validation (including 21 CFR Part 11) 2
S Barcode Scanner IOPQ (Installation/Operational/Performance Qualification) Requirement Qualification and Validation (including 21 CFR Part 11) 9
M Determining Sample Size needed for Operational Qualification (OQ) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 24
W Packaging / Heat Sealer Validation - IOQ (Installation/Operational Qualification) Qualification and Validation (including 21 CFR Part 11) 15
Q Operational Qualification of a CNC machine ISO 13485:2016 - Medical Device Quality Management Systems 4
D Laser Weld Operational Qualification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Operational Qualification for injection molding process Qualification and Validation (including 21 CFR Part 11) 2
C CNC Machine Operational Qualification Recoverability Testing Other Medical Device and Orthopedic Related Topics 1
W IQ, OQ, PQ (installation, operational & performance qualification) compared to PPAP ISO 13485:2016 - Medical Device Quality Management Systems 5
H Basic questions about Installation, Operational & Performance Qualification - PCBA Qualification and Validation (including 21 CFR Part 11) 11
C ISO 13485 and IQ (Installation Qualification), OQ (Operational Qualification) ISO 13485:2016 - Medical Device Quality Management Systems 30
C Generate IQ, OQ & PQ (installation/operational/performance qualification) Report Document Control Systems, Procedures, Forms and Templates 11
H Operational planning and product and service provision when things happen so fast ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Operational (free) simulation games for manufacturing and quality Lean in Manufacturing and Service Industries 5
Richard Regalado Top 10 operational risks of 2019 for business continuity planning Business Continuity & Resiliency Planning (BCRP) 6
I ISO 22000:2018 - Operational Prerequisite Program Examples Food Safety - ISO 22000, HACCP (21 CFR 120) 2
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L OpEx (Operational Excellence) Documents in QMS? Document Control Systems, Procedures, Forms and Templates 0
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
M Informational UK – Brexit operational readiness guidance for the health and care system in England Medical Device and FDA Regulations and Standards News 3
T Operational setup of how FIFO / Process Map on Lithium Batteries is done Manufacturing and Related Processes 1
C AS9100D, Clause 8.1 - Operational Planning and Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Q Management control Procedures & Operational Control Procedures ISO 14001:2015 Specific Discussions 1
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Quality Department - Operational Framework Service Industry Specific Topics 2
A Operational Procedure for an IT Service Industry Quality Department Service Industry Specific Topics 1
M Integrated Phased Processes - AS9100D cl. 8.1 Operational Planning - Clarification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A IT Managed Services Company Quality Department - Operational Document ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G How have you addressed Cl 4.4.6 Operational Control ISO 14001:2015 Specific Discussions 4
I Quality and Operational Excellence Training Institutes in Europe Training - Internal, External, Online and Distance Learning 1
W ISO 14644 Cleanroom Validation - "Operational" Other Medical Device Related Standards 3
M Quality Manual - ISO 17025 required Mandatory and Operational Procedures ISO 17025 related Discussions 7
J OHSAS 18001 Clause 4.4.6 Operational Control Example Procedure Occupational Health & Safety Management Standards 9
G Evaluation of Training for Operational Staff Training - Internal, External, Online and Distance Learning 8
K Operational Prerequisite Programmes (oPRP) Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S What does "Operational Review" mean as tool - Effectiveness of Internal Control Risk Management Review Meetings and related Processes 3
A ISO 14001:2004 Clause 4.4.6 - Operational control (in English) ISO 14001:2015 Specific Discussions 2
D Good operational definition for Schedule Variance Software Quality Assurance 2
A Sample Documented Procedures that satisfy 4.4.6 Operational Control wanted ISO 14001:2015 Specific Discussions 2
D Procedures in Communication, Operational Control, etc. - ISO 14001 Document Control Systems, Procedures, Forms and Templates 12
V Identification of Operational Prerequisite Programs (oPRP) for ready to eat products Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P Operational QMS (Dubai) vs. compliant QMS (UK) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Operational Excellence Assessment of multiple sites - Seeking examples Excel .xls Spreadsheet Templates and Tools 6
